Question about GE Spacemaker JVM1540 Microwave Oven
My microwave key pad was accidentally cleaned with a microfiber rag, which left tons of tiny scratches. How can these be removed or minimized? It looks terrible and it is a new microwave . . .HELP!
  • GE Master
  • 9,047 Answers
I'd first try something like jeweler's rouge or Flitz or Twinkle brand polish on a soft cotton cloth to smooth it out.
If that doesn't work, you'll need to replace the control panel frame assembly, which comes with a new keypad and display window.
It's actually a pretty easy do it yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Let me know if I can help further.
Posted on Aug 21, 2010
Testimonial: "Thank you ! You have given me options and I am hopeful the jeweler's rouge, Flitz or Twinkle will work. Thanks for your input - it was valuable to me"
Unable to eliminate odour from previous cooking despite the fact that I wipe the microwave with a soapy cloth & then with a clean cloth each time to Microwave is used
  1. Fill a plastic bowl with 1 qt. of warm water. Add 2 tbsp. of liquid dish soap and 1/4 cup of chlorine bleach to the water. Thoroughly mix the solution.
  2. Dampen a clean cotton rag in the solution. Wipe all inside surfaces of the microwave with the soapy rag to remove food debris and stains. Scrub stubborn residue with a nylon scrub brush.
  3. Moisten another cotton rag with warm water. Wipe the microwave surfaces with the rag to wash away soap and loose food debris. Thoroughly rinse the inside of the microwave.
  4. Dry the microwave's interior surfaces with paper towels. If odors remain in the microwave, fill a microwave-safe bowl with 1 cup of cool water. Add to the water 2 tbsp. of baking soda, half of a chopped lemon (including pulp and rind) and four whole cloves.
  5. Place a microwave-safe plate on the microwave turntable. Set the bowl on the plate.
  6. Heat the microwave on high for three minutes. Operate the microwave according to the manufacturer's directions. Keep the bowl in the microwave for 15 minutes.7
  7. Remove the bowl from the microwave. Wipe the microwave's interior surfaces with clean paper towels to remove steam moisture.
  8. Leave the microwave door open overnight to completely air out any remaining odors.
  • Sep 05, 2012 | LG LTM9000 Microwave Oven
    I have accidentally locked my microwave oven (profile performance convection oven). I was cleaning the front. Can you tell me what to do?
    Got you covered. Here you go:
    Microwave - Explanation of the Child Lock Out Feature
    Many microwave control panels can be locked to prevent accidental use or access by children.
    There are two different ways to lock the control panel:
    1. Press and hold the CLEAR/OFF pad for 3 seconds. The display will show "LOCK" and then revert to the time of day.
    A small "L" will appear in the corner of the display as a reminder that the control panel is locked. If anyone tries to use the microwave, the display will show "LOCK".
    2. On some models, press and hold the 5 and 7 pads simultaneously for 3 seconds.
    To unlock the control: Repeat the procedure which was used to lock the control. (Press and hold the CLEAR/OFF pad for about 3 seconds or hold the 5 and 7 pad simultaneously for 3 seconds.)
    That info is from GE
    Hope that does the trick.
    Regards, Farmerbear at FixYa.com
    Sep 13, 2010 | General Electric Microwave Oven
    Key pad not working
    First of all try this - - unplug Microwave and remove the back panel to gain access the the control panel. There is a ribbon connector that connects keypad to control. Remove the key pad from control and use a pencil eraser and clean the end of this ribbon connector wher it fits into control . Reconnect and see if that corrects the problem, If this will not works then You'll have to replace the control (key pad control).
    Good Luck!!
    Thanks
    Aug 24, 2009 | Magic Chef Microwave Ovens
    Microwave is scratched
    You will need the following:
    Polishing compound, jeweler's rouge or whitening toothpaste
    Electric buffer
    Lamb's wool buffing pad
    2 ounces of ammonia
    2 quarts of water
    Rubber gloves
    Safety goggles
    Lint-free paper towels or cloth
    Step 1:
    Apply polishing or jeweler's rouge to a lambs wool buffing pad. You can either buff the scratch by hand using a circular motion or with an electric buffer on medium speed.
    Step 2:
    Wash the polishing compound, jeweler's rouge or whitening toothpaste off from time to time in order to check on the progress of the scratch removal.
    Step 3:
    Mix two ounces of ammonia with two quarts of water. You may want to be sure to hold your nose closed during this process! Also, always wear rubber gloves and safety goggles when working with ammonia.
    Step 4:
    Clean the glass surface with the ammonia water with a clean soft sponge.
    Step 5:
    Dry the glass with a lint free towel. If the scratches are not completely gone, they should at least be less apparent. If there is no significant difference, consider contacting a glass company to replace or rebuff the glass.
    Jul 27, 2009 | Frigidaire FMV156DC Microwave Oven
    The keypad does not work. The display screen says "Press -----k". I'm assuming it's telling me to press clock to set time. But none of the keys work when I press any. Earlier only the Start/Pause key...
    try powering down for 30 seconds. if that doesn't work the keypad is shorted or open. do not spray cleaner directly onto key pad when cleaning. it will short it out. rather spray cleaner onto a rag then wipe.
    Jul 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Front of microwave door scratched
    3M 7447 pads get at auto parts store or more aggressive 180 grit sandpaper going with the grain of course. For daily cleaning use DeBruce Polish, it is non-toxic and odorless. DeBruce polish is also non-abrasive, also use DeBruce Polish on glass/ceramic cook tops. We get DeBruce Polish at debrucepolish.com
    Feb 27, 2009 | Frigidaire FMV156DC Microwave Oven
    SERVICE STICKER LEAVES MARK ON FRONT DOOR OF MICROWAVE
    if you spray wd 40 or a light oil on a rag and work it into the glue this will break down the glue and make it easier to clean up.
    Hope that helps...
    Lbcoaster
    Dec 29, 2008 | Sharp R-1610 Microwave Oven
    Bosch HES435U - Stove Keypad is Locked
    Locking or Unlocking the oven control panel
    1. Access Select Function Menu
    2. Turn knob clockwise until Lock Keys is flashing
    3.Touch Start. Key Pad locked is displayed.
    4. To unlock keypads, touch cooking mode and hold for 5 seconds. Display will read unlocking key pad
    5. When unlocked the clock will again appear in the display.
    Apr 29, 2008 | Bosch HLK4525GB Convection/Microwave Oven
    Scratches on microwave door
    We have an over the range GE microwave and my wife was cooking some pasta on the stove and used the vent fan on the microwave to dissipate the steam and when we were done eating she noticed that the steam from the pasta had gotten in between the glass on the microwave door, how can we get rid of this any ideas.
    Jan 07, 2008 | Viking DMOR205SS Microwave Oven
    GE Spacemaker JVM1540 Microwave Oven Logo
    169 people viewed this question
    Top GE Microwave Ovens Experts
    D. E. Hev
     Larry
    Larry
    Shekar Avadhani
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
