Question about GE WPRB9110WH Top Load Washer
MY GE PROFILE WASHER WPRB9110 QUIT DURING A WASH CYCLE. I HAVE UNPLUGGED IT SEVERAL TIMES AND TRIED TO RESTART BUT NOTHING HAPPENS. PLEASE ADVISE.... IT IS CURRENTLY FILLED WITH WATER AND CLOTHES
SOURCE: GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Posted on Feb 01, 2008
JULIANFIX
  • 975 Answers
SOURCE: GE Washer stops during cycle
CHECK THE SENSOR SWITCH underneath the washer where the door closes , it could be loose or damaged, hope this helps AJ
Posted on May 09, 2008
MNTECH
  • 1543 Answers
SOURCE: I have a GE Profile
Hey cissy, sounds like your pump is plugged. Could be rubber backing from a cheap throw rug, other lint type item, or object like a coin or hair pin.
Remove power, take two screws out from the very bottom front edge of machine. remove access panel to gain access to pump. Remember, disconnecting hoses to pump will cause remaining water in tub to come out, be prepared. Remove obstruction from pump. Reassemble. Fixed!
Posted on Sep 03, 2008
kram26
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
GE WASHER LIGHTS FLASHING BUT NOT WORKING
It won't change because the cycle was incomplete and the safety control is preventing a restart. Until you get professional onsite service; unplug the washer; make certain all of the water is drained out, and disconnect the hoses. Have someone help you tilt the washer forward and lay on the front side. Pick it up again and reach into the tub area and spin the tube around, and kind-of move it side to side. Hook it back up, plug it into the power supply and reset the timer to start a short wash. Try to start and see if you get any action. If after all of that; nothing changed, the timer on the circuit board is stuck where you left off when the unbalanced load shut it down.
Dec 23, 2013 | GE Profile WPRE6100G Top Load Washer
I have a ATF7000FS1 washer that has been pausing the wash cycle on it's own. I will have to press the start/pause button during the cycle to restart. This happens several times during a wash cycle. How...
some machine will stop before spin its called crease guard if you are useing a low temp cycle its there to give you the option to stop your cloths wrinkling try another cycle
Nov 08, 2011 | Frigidaire Affinity ATF7000E Front Load...
GE Profile WPRE6100G Top Load Washer My washer is 2 yrs old and has started to make a loud metalic banging noise during the wash cycle. It does not during the spin cycle. Doesn't seem to matter whether...
Hi!!
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90323.PDF
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 03, 2010 | GE Profile WPRE6100G Top Load Washer
Washer stops several times in the middle of cycle
possibly it could be your un-balance switch getting very sensitive to any type of movement of the machine, normally they only actuate during the spin cycle when you have a very off balanced load of clothes
Oct 03, 2009 | GE Profile Prodigy WPSE4200A
GE Profile washing machine not finishing cycles
the OL error is for over load.that is when you over load the clothes in the washing machine. If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
May 07, 2009 | GE Profile WPRE6100G Top Load Washer
Washer pauses at various times during the cycle
Did you find a solution? Mine just started doing the same thing.
Jan 30, 2009 | GE WWSE5200B Top Load Washer
Washer pauses during spin cycle
Check the filter. I have the same problem and I found an string (slip) in the filter. The filter is back of the front pannel (under the door).
Oct 02, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Harmony Washer Beeping
first I would to a hard reset unplug washer and dryer for 30 sec then plug back in... also check the wire that connects the washer and dryer ....if this don't wark let me know I can tell you how to get the error codes out of it... let me know
Sep 13, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE WPRB9110WH Top Load Washer Logo
87 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
