Question about Cycling
How do I adjust the height of the handlebars on a Kranked js2010 bike
  • 6 Answers
SOURCE: how to adjust handlebars
http://www.parktool.com/
Posted on Apr 25, 2009
  • 74 Answers
SOURCE: diamondback rm 20 kids bike. Can you adjust the handlebars?
Yes, there is an allen screw on the top of the stem of the handle bars.....it may also be a bolt with a head on it that can be turned with a socket or cresent wrench.
Loosen the bolt 3 or 4 complete revolutions and then wiggle the bars back and forth from side to side while pulling up. Be careful not to completely remove the screw as the piece that it is connected to will fall off and you will have to remove the bars completely to fix.
Posted on May 03, 2009
  • 193 Answers
SOURCE: 20'' Mongoose BMX - How can i adjust handlebar height?
You need to unscrew the circular nut like thing on the stem all the way off and pull up hard on the bars and it should come up, try spraying some lucricant on the stem to loosen it if needed.
Posted on Jun 20, 2009
  • 6 Answers
SOURCE: I cannot adjust the height of the handlebars on the 20" Mongoose
some bikes u cant only the seats can adjuct
Posted on Jul 20, 2009
dunnbiker
  • 8546 Answers
SOURCE: Can the handlebar height be
The stem could be flipped over if the rise change would result in a hgiehr handlebar, but it would be minimal. That style of stem requires the steerer tube to be cut at the time of assembly and spacers are usually installed that would allow lowering the bars but not raising them since steerer tube length can't be increased.
Or, get a stem with a steeper rise.
Posted on Aug 22, 2010
Trayl bike owners manual. or how do I adjust the height of the handle bars?
Your bike has a modern "threadless headset" which usually allows very little vertical adjustment. See this page for an explanation of how to change height on that style:
How to adjust handlebar height BikeRadar
If you can't adjust enough that way you can try buying a shorter stem or one with a steeper angle,. The final option is to buy a "stem riser" - Google the term for more info - needs to have correct dimensions for your bike
It's best to get advice at a bike shop as to what option is best for you..
Jun 04, 2017 | TRAYL Cycling
How can you raise the handlebar height?
Robert, Below I have posted links showing how to adjust handle bar height for most, some bikes bars are not adjustable and are welded. If the links do not help I suggest you do a google search. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Raise Bicycle Handlebars
How to Adjust Your Bike Handlebar Height
How to Adjust Handlebars
Tech Talk How to Raise your Handlebars
Aug 20, 2016 | Cycling
Adjust handle bar height ?
looking at some pictures of this model, most appear to be using an "Aheadset" style handlebar stem, there is not any way to raise this type of stem. Your alternative is to go online or to a local bike shop and purchase a new stem that will fit your fork and handlebar that has a higher pitch angle to it, or a compatible adjustable stem that pivots. Expect to pay $25-$50 or more for a new handlebar stem, not including labor to install.
Apr 06, 2016 | Marin Belvedere Commuter Road Bike
How do you raise the handlebars on a next bike
Loosen the center post bolt and wiggle the handlebar back and forth while pulling up. There isn't much height adjustment. You can get a longer center post from a bike shop if you can't get a comfortable adjustment.
Sep 24, 2014 | Cycling
How to adjust the handlebars on a bike
To adjust the handlebar position on your Raleigh, loosen the nut on the bottom of the stem extension. Use a 13mm or 14mm wrench, whichever fits. Do not use pliers or Vicegrips! It is upside down, so be careful to turn it counter-clockwise while looking at it from the bottom. To change the handlebar height, you need to loosen the bolt on top of the vertical part of the stem. You may need to tap it with a small hammer to break it loose after it is loosened about 1/4 inch. Now you can adjust the handlebar height, being careful not to exceed the maximum height engraved on the stem. You should also carefully align the bars with the front wheel before tightening the bolt. If you do not understand the terms used here, you should take the bike to a bicycle repair shop.
Feb 26, 2013 | Raleigh Krush 16 Girls Bike 2012 - bikes
Adjust handlebar height on Schwinn Varsity
I'm answering 7 years later. I have a Schwinn Varsity 2500 Bike made probably in 2015. The Schwinn Varsity Bike is not set up the same way as a traditional bike. I loosened the center compression bolt and the two side stem clamp bolts and it came loose where I can adjust it up or down but, there's nothing to tighten the slack up below. I did some research. My original post here was to add or remove a spacer. I think you can remove a spacer to lower but, I don't think the stem is long enough to add another one. I've seen they sell an extension that you can add-on to make the handle bars higher.
Jun 25, 2012 | Schwinn Cycling
Handlebar adjustment
Threadless stems limit what you can do with height.
http://www.sheldonbrown.com/handsup.html
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
If you had purchased the bike at a reputable Bicycle Shop they would have fit the bike to you before you took it home.
Jul 09, 2011 | Apollo Evolution XC
How do you raise the handlebars for the animator first bike by Giant bikes?
David-
To raise or lower the handlebars, first loosen the hex screw on the top of the stem. One or two turns is all that will be necessary. Next, you will need to stand in front of the bike with the front wheel between your legs to brace it, and give the handlebars a forceful twist to the left or right. This action will break the friction of the handlebar stem and the headtube (the headtube is part of the frame where the front forks and the handlebar stem meet...). With the handlebars loosened you can adjust the handlbars up or down. Keep in mind that the stem has only a specific amount of adjustment available...there is a limit to how far it can be extended up, as indicated by a line marked on the stem shaft. Once adjusted to the desired height, check that the handlebars and front fork and wheel are aligned. Tighten the screw in the top of the stem and you're done!
Hope this helps.
DIYpro
May 03, 2011 | Cycling
Need to adjust height of handlebar on a jeep sahara bicycle
Most bikes use an allen key to adjust the height of the handle bars. Typically 6mm. But be careful most bikes do not have much adjustment that can be done to the height of the handle bars. The handle bar stem will have a line on it of the "minimum insertion". That line must be below the top of the head set nut for safety reasons. Look for the line as you adjust the height.
Oct 03, 2009 | Jeep Cycling
Cycling Logo
150 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
