I've just bought the URC-7210 TV controller. It worked well at first but a few keys didn't match their desciption so we decided to follow the set-up instructions. Now nothing works at all. No box is displayed to enter the 4 digit number. It has put our TV on analogue channels and we can't change it to digital or do anything in fact.
    President:
  • 2,712 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 03, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    IrishDruid
Codes for urc
What is the brand name to the TV, you want setup codes?
Jun 01, 2013 | Televison & Video
Tip
One For All URC-1050 Code Entry To program your One For All URC-1050 remote...
To program your One For All URC-1050 remote control to operate your TV you can use the direct code entry function.
To enter for a code for your TV follow these steps:
  1. Turn on your TV.
  2. On the remote, press the TV key once.
  3. Press and hold SET until the LED blinks twice, then release SET.
  4. Enter the first four-digit code from the code list. The LED will blink twice. If it does not blink twice, go back to step 2 and try the same code again.
  5. Aim the remote at the TV and press POWER. The device should turn off. If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
____________________________________
One For All URC-1050 Manual
One For All URC-1050 Code List
One For All URC-1050 Code Search
One For All URC-1050 Reassign Key
on May 30, 2010 | One For All URC-1050 Remote Control
Tip
One For All URC-1030 Code Entry To program your One For All URC-1030 remote...
To program your One For All URC-1030 remote control to operate your TV you can use the direct code entry function.
  1. Turn on your TV.
I hope that helps.
One For All URC-1030 Manual
One For All URC-1030 Code List
One For All URC-1030 Code Search
One For All URC-1030 Reassign Key
on May 30, 2010 | One For All URC-1030 Remote Control
I use URC-3021 w/ Magnavox TV. I bought a
It sounds like you would like to re-assign one of the function buttons on the remote to control a different device. If you would like to program the CBL/SAT button to control a DVD player, here are the steps:
  1. On the remote, press and hold SET until the LED blinks twice, then release SET.
  2. Enter 9 9 2. The LED will blink twice.
  3. Press DVD/VCR once.
  4. Press CBL/SAT once. The LED will blink twice. The CBL/SAT key is now ready to be set up to control your DVD player.
To setup the CBL/SAT button to control your Magnavox DVD player, follow these steps:
  1. Turn on your DVD.
  2. On the remote, press the CBL key once.
  4. Enter the first four-digit code from the following list: 0503, 0675. The LED will blink twice. If it does not blink twice, go back to step 2 and try the same code again.
  5. Aim the remote at the DVD and press POWER. The device should turn off. If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Dec 09, 2009 | One For All URC-3021 Remote Control
All for one remote urc-3021boo for
Try reprogramming the remote with the control codes again.
To control a White Westinghouse TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0463, 0623
5) Aim the remote at the TV and press POWER.
I hope that helps.
Tip
One For All URC-4021 Code Entry To program your One For All URC-4021 remote...
To program your One For All URC-4021 remote control to operate your TV you can use the direct code entry function.
  1. Turn on your TV.
I hope that helps.
One For All URC-4021 Manual
One For All URC-4021 Code List
One For All URC-4021 Code Search
One For All URC-4021 Reassign Key
on May 30, 2010 | One For All URC-4021 Remote Control
Tip
One For All URC-3300 Code Entry To program your One For All URC-3300 remote...
To program your One For All URC-3300 remote control to operate your TV you can use the direct code entry function.
  1. Turn on your TV.
I hope that helps.
One For All URC-3300 Manual
One For All URC-3300 Code List
One For All URC-3300 Code Search
One For All URC-3300 Reassign Key
on May 30, 2010 | One For All URC-3300 Remote Control
I have a one for all big easy remote control. I want to program it to use with my Emerson flat screen TV. What is the 4-didget set up code?
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3021
or
http://www.sparky-uk.com/one-for-all-tv-big-easy-urc-7210-universal-remote-control-85-p.asp
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Dec 22, 2007 | One For All URC-3021 Remote Control
Tip
One For All URC-4605 Code Entry To program your One For All URC-4605 remote...
To program your One For All URC-4605 remote control to operate your TV you can use the direct code entry function.
  1. Turn on your TV.
I hope that helps.
One For All URC-4605 Manual
One For All URC-4605 Code List
One For All URC-4605 Code Search
One For All URC-4605 Reassign Key
on May 30, 2010 | One For All URC-4605 Remote Control
Televison & Video Logo
195 people viewed this question
Top Televison & Video Experts
