Question about Dishwashers
My electrolux SB915WJ dishwasher doesn't heat water anymore. Ican't find any details on this model.
    Problem Solver:
  • 6 Answers
This usually means the motor is broken.Can cost a lot if not under guarantee.You need to contact the manufacturer.
Posted on May 03, 2008
Why is water not heating in cycle?
Hello Kevin, thank you for your post!
From my understanding your Electrolux dishwasher is not fully dissolving the detergent tablet. It may not be an issue with the water heating up it could be a possible problem with the water not receiving adequate pressure or not enough water. Does your dispenser have any build up inside of it? Have your spray arms been recently cleaned? I would recommend cleaning the dispenser and spray arms out. I can also provide you with information regarding any heater inside of your dishwasher. In order to do so I need your model number. You can locate your model number on the inside wall of your dishwasher. With this information I would be happy to assist you further. -Matt
Feb 02, 2016 | Electrolux Dishwashers
Water isn't draining and display light not working?
what is the model number to your dishwasher? Geraldine
Oct 01, 2013 | Electrolux Dishwashers
Electrolux dishwasher not heating water
If your Ohms are at "0" then the heater is open.
Jul 31, 2012 | Electrolux Dishwashers
My electrolux 302 dishwasher does not seem to heat the water anymore, is it expensive to repair the heater
it can be the element is cheap enough but 9 times outta ten it,ll be a circuit board fault which can be exspensive.
May 18, 2010 | Electrolux Dishwashers
DO I NEED TO RUN HOT WATER IN THE NEAREST FAUCET TO START THE DISHWASHER
This model does have an inline heater to heat the water to the proper temperature, but it does take a long time and you are recommended to run the tab on the faucet from which the dishwasher water line is tapped from. This clears all the cold water from the line
Jan 30, 2010 | Electrolux 24 in. EDW5505EPS Stainless...
Our SB915WJ doesn't heat water though the heating element is ok, I checked with my multimeter. Is there a mains relay or something i need to change in the circuitry to fix this problem? Does anyone out...
tHERE IS A HIGH TEMPERATURE CUT OFF SWITCH WHICH LOOKS LIKE THE BAK OF A STAINLESS STEEL WATCH IT HAS TWO LUGS THAT THE HEATER ELEMENT IS ATTACHED TO. IF YOU TEST IT YOU WILL FIND THAT IS IS OPEN CERCUIT. I'M NOT SURE WHERE IT IS ON THAT MODEL BUT IF YOU HAVE MANAGED TO TEST THE ELEMENT YOU CLEARLY HAVE THE THING TO BITS.
Nov 05, 2009 | Westinghouse Dishwashers
In built dishwasher, Electrolux ESI6220, is not heating the water and therefor not washing the cutlery properly. What may be the problem and how does one remidy same?
You have to test the heating element with an ohm-meter. It should read very low ohms. If the element seems ok, you have to test the controller to see if it is powering the element (probably should be 120 volts)
May 05, 2009 | Electrolux Dishwashers
Electrolux ESL 6225
before you operate the dishwasher get your water as hot at the sink as you can this will prevent filling the dish washer with cold water and i would use powder or liquid now if you not sure of your heating element turn your washer to dry close the door for about 2-3 minutes get a glass of cold water open the door and pour water on the element if it sizzles its working
Feb 12, 2008 | Electrolux 23 in. ESL624 Built-in...
I have a dx302. its not heating the water or drying.
My six year old Electolux Dishlex DX 403 dishwasher stopped heating the water. I found comments on the internet about burnt out solder joints in the control box. A friend opened the control box and found a blackened area on the back of the circuit board. Once the connection was re-soldered the water heated again. We also found that quite a few wires leading to the control box had overheated and the insulation had melted. Considering that this dishwasher was the top model from Electrolux at the time, I was not impressed. I had previously had a Vulcan Dishlex for almost 20 years.
Thanks to those people who previously posted information about this fault.
Feb 10, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Dishwashers Logo
158 people viewed this question
Top Dishwashers Experts
