Question about Reliance & 40 Gal Electric Mobile Home Water Heater
I'm looking for the drain **** or spigot on a 1991 reliance 501 gas water heater - is it behind the shield?
  • 455 Answers
YES
Posted on Aug 20, 2010
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
Reliance 501 Hot Water Heating element for 30 gal tank, where to purchase
You do not need special parts.
Wattage is printed on end of each element.
Buy generic elements at hardware store.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Apr 21, 2012 | RELIANCE ELECTRIC WATER HEATER
How can I find out what the Energy Rating is on my Reliance 501 w/h?
Reliance is AO Smith company.
http://www.reliancewaterheaters.com/prod/gas.html
http://waterheatertimer.org/Water-heater-manufacturers.html
1) Reliance does not post the 501 manual any more and I've written and asked for that manual, and they sent generic manual. Model 501 is both gas and electric.
2) That tells me the old energy factor is probably lower than .54 approximately, but it will be even less because energy factors are for new water heaters in perfect operating order under ideal conditions.
3) Energy factor is a measure of how efficiently the water heater turns energy BTUs into hot water.
Gas water heaters have higher energy factor because gas burner has more BTU punch than electric element, and can heat water faster.
4) However, energy factor is not measure of actual cost. It is merely a way to compare giant water heaters with smaller heaters, and gas with electric, without considering cost of heater, installation cost, repair costs, parts costs, life expectation of unit, disposal/recycling cost, or replacement cost.
5) You can improve your true energy factor by buying small cheap heater and maintaining it yourself so it lasts many years beyond manufacturer's warranty.
http://waterheatertimer.org/Replace-anode-rod.html
6) If someone buys a bigger water heater because it has better energy factor, it will not pay back the higher purchase cost. Same size to same size, the difference with higher energy factor is a few dollars per year.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
7) If you have sediment inside of tank, the energy factor is out the window.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 02, 2011 | Reliance Water Heaters
I have a reliance 501 propane gas water heater how do i change a thermostate
To change a gas hot water heater thermostat you will need to first buy a new gas valve for your hot water heater. The gas vaive and the thermostat are integrated into one unit.
To replace the thermostat on a gas hot water heater you must follow these procedures....
1. Turn off the incoming water and drain the water heater.
2. remove the pilot tube, the burner gas tube and the thermocouple from the gas valve. Turn off the gas line and remove from the gas valve.
3. get a pump pliers or a wrench in behind the gas valve and turn the whole assembly CCW to remove it from the tank.
4. After appliying pipe dope or tape to the new gas valve threads, turn the new gas valve into the tank by turning in a CW direction. Be careful not to damage the small wires to the ECO. They are the little red wires on the back. If you break them the assembly is irreparably damaged.
5. reinstall the gas line, thermocouple, burner tube, and the pilot tube to the gas valve.
6. Fill tank with water. Make sure to open a hot water faucet and purge all air from the tank.
7. Check for leaks where the gas line hooks up with soapy water.
8. Relight pilot light and check operation.
9. Set the new temperature setting to a medium setting and then adjust the temperature to your likeing from there and adequate time for heating completely.
heatman101
Feb 23, 2011 | RELIANCE ELECTRIC WATER HEATER
I need to replace the drain valve at the bottom of the tank,can I buy a replacement valve? Are they all the same size?
There are 2 sizes; 1/2 inch and 3/4 inch. Remove the old one after draining the water heater and shutting off the water supply then take your old one to a plumbing supply outfit like George Morlan's. Make sure you wrap the new threads with teflon tape at least 3 wraps while holding the spigot in your left hand so the tape won't come off as you install the spigot. Good luck!!
Dec 15, 2010 | RELIANCE ELECTRIC WATER HEATER
Need to empty reliance 501 hot water heater how?
1) Shut the breaker off to it at the panel. 2) Hook a hose up to it (the bottom has a drain). 3) Close the valve to the water heater (on the cold water supply). 4) Open drain on the bottom of water heater. 5) Open the relief valve to allow air into the tank (it won't drain otherwise - think if you put your finger on one end of a straw - the liquid stays in until you let go). Why are you draining it by the way?
Jan 26, 2010 | RELIANCE ELECTRIC WATER HEATER
I have a Reliance 501 gas hot water heater that needs a tank cleaning. Scale is showing up in faucet aerators. Is it still comon practice to delime hot water heater tanks? If so any recomendations?
hook up garden hose to faucet @ the bottom of the tank and drain the hose to the outdoors or down a floor drain and open the valve , leaving the cold supply valve on , let it run until it runs clear , this will get rid of some of the sediment deposit that form at the bottom of tank , is the most effective way i know , good luck
Dec 31, 2009 | RELIANCE ELECTRIC WATER HEATER
Reliance & 40 Gal Electric Mobile Home Water Heater  Logo
65 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
