Question about Whirlpool Refrigerators
I have a whirlpool frig. with in the door water and ice, model # ED5JHEXTB00. Here is my problem the ice maker has stop making ice and this is what I have done so far I have bypassed terminal V and L on the modular / motor to activate the water valve, which it did activate and fill the ice tray ,ice formed in tray but does not eject out of mold, so I replaced the modular/motor and thermostat, still no ice. water from the door works fine, what next any help would be greatly appreciated.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
Have you checked the infrared transmitter if it is not transmitting the machine thinks it is full of ice and will remain on the off stage
Posted on Jun 02, 2017
  • 531 Answers
SOURCE: Whirlpool ice maker stopped making ice
change the modular
Posted on Mar 31, 2009
  • 531 Answers
SOURCE: Ice maker door dumps ice on floor.
you have to call service
Posted on Apr 02, 2009
  • 35 Answers
SOURCE: Water will not fill my ice tray. I have good water
THE WATER VALVE IS BAD
Posted on Jun 18, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool side by side Ice maker has quite making ice
Open the freezer door and on the right side , make dure the slide is in the on position . If the red light flashes twice , then pauses , flashes twice , pauses , consistently , then close the flap door on the left side of the freezer . The light should go off . If these tests work , then the cut-off optics are good , and the icemaker needs replaced , due to the cubes not dumping . Also check the coils under the front of the refrig , to make sure they are clean of dust , lint , etc.
Posted on Sep 16, 2009
aasc
  • 1606 Answers
SOURCE: WHIRLPOOL MODEL ED5NHA NOT MAKING ICE, IN DOOR
You may check the coils under the front of the refrig , to make sure they are clean of dust , lint , pet hair , etc . If the coils are not clean , it will raire the freezer temperature so many degrees , to where you will not be able to tell the difference , but warms enough (6 degrees or highter ) , to where the ice maker will not dump . Ice maker needs to be 5 degrees , to harvest ( dump ) . If clean , then "sea breeze" solution , would be the next step .
Posted on Oct 25, 2009
Whirlpool side by side frig, model #: ED2JHGXRBO2, serial #: ST2854810. We have had this frig for several years and almost from the get go when you open the right side door, the door gets so far and always...
I own a whirlpool fridge (side by side) model # ed2jhgxrt02. with a problem with the ice maker. the water is not being delivered to the ice makers. it seems that the switch to turn on the water to flow is not making contact. any suggestions?
Jan 04, 2011 | Whirlpool Refrigerators
I have a whirpool side by side frig WITH DOOR ICE MAKER and need to know how to get AUTOMATIC ice maker in so door will shut model ED226WXFW02
looking at your model the ice maker is mounted and is not removable . so maybe you mean the ice storage bucket. . make sure the rails are clear and it should slide in and when all the way in lift up and feel the click into pos . this lock the bin so the augar can work . and the door should shut .. hope this hepled mm and thanks for using fix-ya ..
Oct 16, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Frig has stopped making ice.
Open the left door open the ice maker door, up in the left hand corner you should see a green light, check to make sure that you have a selection chosen(either small of large cubes.
Jul 15, 2009 | LG LFX25960ST Stainless Steel French Door...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker freezing up
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Aug 23, 2008 | Whirlpool ED2FHSS Side by Side...
Whirlpool Gs5shaxnb02 Ice maker
is there water in the ice trays?if not try pushing the test button normally underneath the unit. possibly it will initiate a reset and start working. sometimes a limit is not activated when it should be.
Aug 07, 2008 | Whirlpool GS6NBEXR Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
61 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
