Question about Cobra Car Audio & Video
Car alarm fob will not work after battery change
If the alarm is an after factory installation, turn the ignition to start and then to accessory and the alarm will deactivate and you should then be able to start the vehicle
Posted on Mar 16, 2009
Key fob won't work even after changing battery, can only open and lock car using key, alarm won't shut off and keeps ringing
retry replacing battery new doesnt mean cant be defective if it is good than fob needs a relearn different cars have different relearn that you can perform but if the fob has other features such as start that will have to be done at dealer ----
Free Keyless Remote Fob Entry programming instructions procedures for all... look up your vehicle and will have instructions one how to program fob --will also tell if need to be done at dealer
Aug 02, 2015 | Cars & Trucks
How do I turn off the alarm?
Try pressing the unlock button twice quickly.
Aug 21, 2017 | Viper Vehicle Parts & Accessories
Deactivate alarm
change the battery in your fob. check the power in your battery may need a recharge.
Dec 20, 2013 | 2001 Mercedes-Benz C-Class
Turn off alarm without key fob
Tracy:
Have you replaced the battery in the fob? After replacing the battery in the fob, the car owner's manual will tell you how to re-program the fob to the car.
Sep 18, 2013 | Pontiac Cars & Trucks
Key fob wont re set on my ssan yan rexton
I recently changed the battery on my key fob for my ssanyong rexton. I then did the following for the key fob to make it work. 1. Enter vehicle and close all doors.
2. Put seatbelt on (or clip it into the buckle) to shut the warning buzzer off.
3. Put key in ignition, turn to run position but don't start it.
4. Press and hold both buttons on key fob until red light on fob stays on. Then let go of both buttons. Then pressed the alarm button then the panic button, somthing like that. To be fair the button sequence after the red light came on is a bit vague. The alarm was blaring so i was happy when it just stopped.
May 23, 2012 | SsangYong Rexton Cars & Trucks
Gemini 7200 car alarm replaced battery fob not working no tx to alarm. please help and many thanks. natec
The problem seems to be the key fob on these alarms goes out of sink with the alarm unit (thats if you have changed the battery and its not responding), but 7200/7300 have the ability to "self learn" the new frequency your key fob has changed to .I dont know why they change frequency but they do.I have had to do this a few times myself. if you have a manual for this alarm it tells you how to do it in there but you will need the round key that comes with the alarm that fits in the top of the alarm unit (siren). Anyway to do it : 1.using the key switch alarm off. 2. switch on again. 3. turn ignition for 1 second then off. 4. push the key fob.within 30 secs. 5. switch dim dip (6) back to off. if it dosent work repeat.(dim dips are in the siren where the wire goes in) and if the alarm goes of while your doing it dont worry but just try and be quick. Hope this helps. Chris 13.
Apr 14, 2011 | GPS
Central locking not working
Assuming that the battery mentioned above is the Key Fob battery?
The usual solution to the key fob not working the Central Locking after battery replacent  is to remove the car battery feed fuse   to the Central Locking (or disconnect the car battery )  for 10 minutes...replace it..... then it should work OK
note: If you disconnect the Car Battery then make sure you have the radio security code.
If not then POST A NEW QUESTION quoting your radio Serial Number (usually begins with M * * * *  * * )
Sep 25, 2009 | Code-Alarm Code Alarm Transponder
Car key fob not working and locking car
i have a rover 25 and the key fob is not opening the car i could use the key to open it but the alarm will go off and cant stop it without the fob...
May 28, 2009 | 2002 Jaguar X-Type
Car Audio & Video Logo
641 people viewed this question
Top Cobra Car Audio & Video Experts
xxxxxx xxx
Are you a Cobra Car Audio and Video Expert? Answer questions, earn points and help others
