Question about Brinkmann Grilling
I have a model 8445w. the crossover channel is broken. I need to order the part.
Http://buyitnow64.stores.yahoo.net/brgasgrbucac6.html
It's aftermarket, but much cheper and works great, I suggest to go ahead and buy all 3 to replace.
Posted on Feb 21, 2011
How to repair driverside manual window cutlass ciera
Yes. it sound like one of the guide channels is broken or loose. You will need to take the door panel off to look inside and see what the problem is.
Sep 08, 2014 | Dorman 1987 Oldsmobile Cutlass Ciera...
Behringer cx2300
follow this instructions and fix it. God bless you
Instructions
    • 1
      Plug one end of a shielded input cable into the mixer's main output, and the other end into the crossover's input. The cable connectors will be dictated by your particular mixer and crossover, and will be either standard 1/4" or 3-pin XLR connectors. Consult the owner's manual of all components for specific details and recommendations.
    • 2
      Plug another shielded input cable into the crossover "high" frequency output, and the other into the crossover's "low" frequency output.
    • 3
      Plug the cable coming from the crossover "high" output into the channel one input on the stereo power amp, and the cable from the crossover "low" output into the channel two input of the power amplifier.
    • 4
      Plug one end of the unshielded speaker cable into the power amp channel one speaker output, and the other end into the horn tweeter.
    • 5
      Plug one end of the second unshielded speaker cable into the power amp channel two speaker output, and the other end into the woofer. The connections are now complete.
Jul 13, 2013 | Behringer cx2310 super-x pro crossover...
Brinkmann grill
As long as the crossover channels do not leak at any point the gas should be getting to the other burners (assuming that the gas pressure is up to snuff). The next thing to check are the individual burner jet openings for clogs, and finally the flame spreaders should also be clean!
Jan 22, 2013 | Brinkmann Grilling
I would like to know I have 2 subwoofer with amp how can I connect it the best way thank you
first, you will need a passive crossover, i do not believe that the mono out of the mixer has a crossover., if the amp does not have a crossover. you could use the "mono" output, and split the signal, with an adapter, to both channels of the crossover, then run both of the low outs to the 2 channels of the amp. or, you could hook the crossover to the main laft and right outputs of the board. send the 2 low outs, left and right, to the subs' amp, and send the two high outs, left and right, to the main speakers' amp.
Nov 24, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Wiring Speaker to amp
remove all speaker connections to your amp. MAke sure the inputs are driving all 4 channels, and that the built in crossovers on the amp are all set to full range. Conect your full range speaker to each output channel one at a time and verify there is oputput on all 4 channels. If all is ok, then connect your rear speakers to the front(a) outputs of your 4 channel amp, and then use the second 2 channels (rear or B) bridged to drive the sub. Re-configure the crossovers for highpass for front (to drive your rear speakers) and lowpass for sub. This is the proper way to connect a 4 channel amp with a sup whle driving 2 full range speakers.
Jun 10, 2009 | Car Audio & Video
Eq on channel a doesn't work on 2 units
It could be an internal ground connection on the EQ that's broken ( maybe inside the connector) ..I repaired numerous peavey products and broken grounds are common.
Feb 11, 2009 | Peavey EQ215FX Home Equalizer
I wanna some information about electronic rolls in car
An electronic roll-a-long switch for use in a seismic exploration system and method of seismic exploration are disclosed. For a group of N sequentially numbered receiver points, N/2 input channels are provided. Each input channel receives input from one of two receiver points which are spaced N/2 receiver points apart. The input channels are multiplexed to a data bus in an order corresponding to the sequential numbers of the receiver points comprising the input channels. :D
Dec 16, 2008 | Rolls ELECTRONIC CROSSOVER, 2 WAY STEREO,...
Deck speakers
An active crossover is needed if you plan to do a 2.1 or 4.1 or 5.1 setup.
Check if you have a subwoofer output from your head unit (most later models have). If there is, you might not need an active crossover anymore, but it depends on how you like the sound quality of the separations (low, mid, high). Please note the speaker polarities too.
Oct 16, 2008 | JBL GTO 301.1 Car Audio Amplifier
Car audio
As long as the crossover keeps the frequency going to the tweeters within a safe range (I'd say about 500hz+, read the box or look it up by model number) they should be just fine. That is what the crossover is for.
Apr 01, 2008 | Car Audio & Video
Peavey Compressor/Limiter and Peavey 3/4/5w Crossover
The correct order is Mixer>EQ>Compressor>Crossover>Amps>Speaker. Here is the link that helped me out. Scott's PA System Tutorial
Feb 13, 2008 | Peavey CROSSOVER, STEREO 2-WAY/MONO 3-WAY,...
Grilling Logo
219 people viewed this question
Top Brinkmann Grilling Experts
paulcarew
Dan Webster
Dan Webster
Lyle Siemens
Lyle Siemens
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
