Question about AudioBahn A4075HCQ Car Audio Amplifier
Wiring subs hi i have the audiobahn A4075HCQ amp also have 2 12" dual voice coil there 750 watts how do i wire my 4 channel amp to these subs also what kind of box should i use i have a 2002 infiniti g20 4 door pleasr help thanks
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
There are more on the audiobahn site.
Posted on Oct 21, 2015
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Audiobahn.com can help you with the free diagrams under tect support
Posted on May 11, 2010
Wiring a crossfire vr602 at 4ohm
OK what you are saying now is that your speakers are dual voice coil; models? 4 Ohms per Coil? I have always used single 4 Ohm Voice ciol speakers since amps are mostly based on 4 Ohm outputs. but you can get 8 Ohm dual voice coil subs also. With 8 Ohms per coil you can get 4 Ohms if you parallel the wires. What is best for you and will get you the most stable power and still will be in the specs of that amp is to run the amp in BRIDGED MODE running each subs voice coils in series with each other then run those 2 subs in parallel to the amplifier giving it a 4 Ohm load. So, your will have two sets of wires from your amp 1 for each speaker. Then you will take a short piece of wire that will connect the + to the - of each voice coil then hook up the wires from your amp to each sub What it will be is 4 Ohms + 4 Ohms = 8 Ohms per speaker the 8 Ohms in parallel each speaker to the Bridged amp output using just the + from one channel and the - from the other will give you a total of 4 ohms and power out put of 600 Watts so that ends up being 150 watts per voice coil or 300 watts each speaker
Apr 04, 2013 | Crossfire VR602 Car Audio Amplifier
I have 1 audio bahn eternal series awes15p 15inch subwoofer.I'm having problems hooking it in my vehicle,I don't have the wiring manual.I would appreciate if you can tell me or give me a...
There are some things to think about when you install this.
1. Is the sub a dual or single voice coil?
2. What ohms are the voice coils?
3. Is your amp 2 channel or mono?
4. What are the ohms loads allowed by your amp?
I am going to assume your sub is dual 4 ohm and you want to get as much power out of your amp as you can. I am also assuming the amp is a mono channel amp. (if it's a two channel amp, you can bridge the channels)
Go from the positive of your amp and wire to both positives of the voice coils. Then go from the negative of the amp to the negative of both voice coils. You will have 2 sets of wires to your sub. This is called a parallel set up. This drops the load of one dual 4ohm sub to a 2 ohm load. The lower the resisitance, the more power is able to flow from your amp, giving your more sound. Make sure your amp is 2 ohm stable.
Hope this helps
Aug 25, 2011 | AudioBahn AW1500 Car Subwoofer
Hello..im trying to find a diagram on how to wire my subs down to 1 ohm..i have 2 12 in. Audiobahn alum12n..they are currently runnimg at 3 ohms on a hifonics 2500 watt 1 channel amp that only supports 1 2...
Hi, if you wire all voice coils in parallel, you will get down to 1.5 ohms. That is the lowest you can go with these 2 subs. Just hook the amps' positive to all 4 positive speaker terminals and the amp negative to all 4 speaker negative terminals. Please let me know if you have more questions, and thanks for using FixYa.
Mar 22, 2011 | AudioBahn Car Audio & Video
How do you wire a AW1000V to 1 amplifier?
The easiest way to wire this would be to make sure you have a 2 ohm amp, wire both voice coils in parallel to the amp. This means to connect both + terminals on the speaker to the + speaker output on the amp, then wire both - terminals on the speaker to the - speaker terminal on the amp. With the voice coils in parallel like this it makes it into a 2 ohm load at the amplifier. If you are running for example a 1000 watt amp at 2 ohms into this speaker it would give each voice coil the equivalent of 500 watts of power at 4 ohms. The other way would be to run the voice coils in series (voice coil 1 - terminal to - speaker terminal on the amp, voice coil 1 + terminal to the voice coil 2- terminal, voice coil 2 + terminal to the +speaker terminal on the amp.) The series wiring would give you a 8ohm speaker load to your amp so you would need a 8 ohm amp.
Mar 07, 2011 | AudioBahn AW1000V 10" Dual 4-ohm Voice...
Volfenhag ZX4725 i am buying this subwoofer and
No the LOWER the resistance the MORE Output or Draw, If say it is 100 Watts into 4 Ohms, if you used a 2 ohm speaker it would draw 200 watts.(only if capable of delivering that amount of power) The LOWER the Resistance, the HIGHER the Current Draw. WATTS = AMPS x VOLTS. (This is not strictly true with amplifiers output though, as it is an AC Current, and a "Reactive" load, it has, Inductance, Capacitance and Resistance, all in one.and is worked out via a Formula) see below. http://en.wikipedia.org/wiki/Audio_power
http://www.hometheaterhifi.com/volume_1_1/v1n1spk.html
Now with Dual Voice Coils, Essentially, you can think of these speakers as TWO speakers in ONE enclosure. As such, They are basically TWO Speakers. Please see the website below it explains everything for you. http://www.diyaudioandvideo.com/FAQ/Wiring/
Everything is a function of Resistance and Ohms law.
Current (I) = Voltage (E) divided by Resistance(R).
Voltage = Current Multiplied by Resistance.
Resistance = Voltage divides by Current.
Apr 17, 2010 | Car Audio & Video
Why does the kenwood kac-9103d has two sets of terminals if its a one channel amp so how do i hook up a dual 12 phoniex gold 1200 watt sub to it
Hello damasogrizzl,
The 2 sets of terminals are connected internally. Having 2 sets just makes it more convenient when wiring multiple subs. The amp is rated for 900 watts RMS into a 2 ohm load. The specs claim that it is stable at 1 ohm but does not give a power rating.
The Radial SD competition series from Phoenix Gold are rated to handle up to 600 watts RMS. If you have the model RSdC124 with dual 4 ohm voice coils, it would be best to wire the voice coils in parallel for a 2 ohm load and connect the sub to one set of terminals on the amp. If your sub is the model RSdC122 with dual 2 ohm voice coils, you should wire the voice coils is series for a 4 ohm load and connect the sug to one set of terminals on the amp. Wiring the voice coils in parallel will result in a 1 ohm load. And, while the amp may be stable at 1 ohm, the sub will be seriously overpowered.
Hope this helps.
Sep 23, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Bridging 800a4
That all depends upon whether or not the sub you are running has dual voice coils or just a single voice coil. The 800a4 is a four channel amp; thus the only way you can bridge it will be 3 channel or 2 channel. If you are running a dual voice coil sub then you can wire the amp two channel and get 400 watts x 2 @ 4 ohms. Make sure that you sub can handle this kind of power though.
Here are the specs:
4 x 100 @ 4 ohms (13.8V - <0.05% THD)
4 x 200 @ 2 ohms (13.8V - <0.10% THD)
2 x 400 @ 4 ohms bridged (13.8V - <0.10% THD)
Fuse: External 60A
Manufactured in 1999 - 2001
Jun 18, 2008 | Rockford Fosgate Punch 800a4 Car Audio...
Unsureness of wiring configurations.
Mamola,
Get an amp with at least 200 Watts RMS. The RMS value is what is important about driving Subs. This could be proclaimed to be a 1000 Watt amp. REad the RMS value.
Wiring. It is better to series your Speakers to give them and your amp more reliability,
Get a Mono or Bridgeable amp. If it si bridgeable, BRidge the output as described in the manual you get. Some Amps have a diagram right on the output..
AMP+ to Sub1 +
Sub1 - to Sub2 +
Sub2 - to Amp -
Get a 4 Guage wring kit. Run your power wiring down the Drivers side, and Audio signal wiring down the Passenger side, keep the two separate.
Nov 26, 2007 | Kenwood 12" 4-Ohm Single-Voice-Coil...
How should I wire up this amp and sub
The amp's not actually a very good match for the sub, since the sub can be wired for 2 ohms or 8 ohms, and the amplifier is most efficient at 4 ohms in bridged mode. My advice would be to wire the amp in bridged mode, and wire the sub for an 8 ohm load. To do this, the amp's (+) wire should go to the (+) terminal on one of the sub's voice coils. Then run a wire from the (-) terminal on the OTHER voice coil to the (-) terminal on the amp. The remaining (+) and (-) terminals (on opposite voice coils) should be connected to each other with a wire. Your original wiring setup had the amplifier connected to only one voice coil, while the other voice coil was shorted.
Jun 10, 2007 | Kole audio Q2-480 Car Audio Amplifier
AudioBahn A4075HCQ Car Audio Amplifier Logo
328 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Josh Whitehead
Josh Whitehead
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
