Question about Dell 5110cn Laser Printer
WE HAVE CRINKLED PAPER. WE THINK ITS THE FUSING UNIT. WHAT CAN WE DO?
  • 185 Answers
You can do a "stop test" which means you will open up a cover before it reaches the fuser. If the paper is damaged then you would suspect something in the registation area.
If it's the fuser TD218, you can install it yourself.
It may also be something wrong with your Exit Chute, but the fuser is the best suspect.
Whit
Item, Inc.
Posted on Aug 20, 2010
Error cs548 in ricoh mp c4500
SC548
Fusing unit rotation error
The fusing belt sensor does not detect change in the actuator for 0.5
seconds after the fusing/paper exit motor has turned on.
* Defective fusing/paper exit motor
* Deformed actuator for the fusing belt sensor
* Defective fusing belt sensor
* Broken connection between IH inverter and IOB
* Incorrectly set fusing unit
1. Check if the fusing unit is correctly set.
2. Check or replace the actuator for fusing belt sensor.
3. Replace the fusing belt sensor.
4. Replace the IH inverter.
5. Check the connection between IH inverter and IOB.
Jul 14, 2014 | Gestetner DSm645 Digital Imaging System
I have a sharp al-1631 copier. it was working fine and then i had a bad misfeed. the paper was crinkled like an accordion, but i managed to get it out of the fusing and area and below the fusing area. ...
You can not make any copies? Is this because it continues to jam every copy in the same location? At the fuser? If so then this means you have a quite common issue with this series of machine. You have a broken fuser drive gear. Part number NGERH0540FCZZ. I have included a picture of the part. All you will need is someone to remove the fusing unit (the part that gets hot) and replace the gear. You can get the part from PrecisionRoller.com
Good Luck and Thank You for using Fixya. Our solutions are being rated this month based on positive testimonials. If my solution is helpful please leave a short testimonial for me.
Thanks!
Oct 05, 2010 | Sharp AL 1631 Copier
H5-01 error on sharp AR-M450N
Sharp AR-450 H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 01, 2010 | Sharp AR-M450N Copier
Problem with Richo aficio 1224C fusing oil supply unit
I think that you pull out the felt for fusing oil distribution.I think that you need to call another service for second opinion
Jan 12, 2010 | Ricoh Aficio CL7000 Laser Printer
Call for service
Cause The fusing JAM is not completely
removed. (Jam paper remains.)
Fusing unit installation failure
Check and remedy:
Check for jam paper in the fusing section.
(paper winding, etc.)
Check fusing unit installation.
Check the jam sensors in the fuser.
Aug 24, 2009 | Sharp AR-M237 Copier
Remove a paper jam under the fuser unit on a canon image runner 5070
Hello sir; I believe You have to detacth finisher unit then open the side door to reach the fusing unit see is there have jamming paper over there ,the paper under the fusing unit just open front door turn the knob clockwise on the fusing unit paper will coming out.
Aug 17, 2009 | Canon imageRUNNER 5000 Copier
Paper crinkles
This is what I've seen with wrinkled pages in these machines.
Usually only happens with letter size paper.
At some point a leaking toner was used in the machine the excess toner works its way toward the fuser and builds up on the guide where the paper enters the fusing assm.
You can try to clean the toner thats built up or replace the fuser.
Hope this helps
Jan 13, 2009 | HP LaserJet 8000n Printer
Crinkled paper and jamming
Where is the paper jam ???? If you have a paper jam in the back of your printer it maybe the fuser unit.....Make sure thaht you don't have a little peace of paper somewhere in the paper path...
For your drum, did you reset the drum counter ????Normally the instruction for resseting the counter is in the drum box...
Mar 26, 2008 | Brother MFC 7420 All-In-One Laser Printer
Re: Paper Jam
I'am sorry to say that you have to replace the fusing unit on that machine, when it jams inthe fuser like that the fusing unit is going bad. the fusing units range from: $200.00 to $295.00 plus service call. You may think about replacing it, sorry for the bad news. I've worked on about 5 of those machines with the same problem and it always comes down to replacing the fusing unit, even if you get the paper out it will jam again.
Nov 16, 2007 | Canon imageCLASS D761 Copier
Dell 5110cn Laser Printer Logo
62 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
