Question about RCA Audio Players & Recorders
I have an RCA RS2000 clock radio/CD/Tape system that was working great until we had a power outage for about 36 hours at the office building where I work. When I turned the radio on again with the remote once power was restored, the display goes to "TAPE", and if I switch bands with the remorte, the FM readout shows a range of 05.22 to 16.20 mhz instead of 88.1 to 107.3 or so on the typical range. If I try to switch to AM, I get one of two readings - 2598 khz or 9605 khz with "MW" showing on the bottom of the readout in small letters, with nothing inbetween, instead of the typical range of 630-1450 or so. What is going on here? When I try pushing the bottom part of the round Volume Control button on the right, it goes to "TAPE" but nowhere else. It's gone haywire. Please help. Best regards, Ed Nicks (720) 331-2362
  • 3,083 Answers
It sounds like the microprocessor has been damaged from a power spike, probably from when the power was turned back on, or when it was lost. In these type of situations, there just isn't an easy solution- it usually requires a great deal of troubleshooting and replacement of parts or even boards, which is labor intensive and costly. You could call RCA support to see how much it might cost to get repaired, and here is the contact info:
http://www.contacthelp.com/directory/Shopping/Electronics/RCA?ListingID=288
Wish there was a simple solution to this problem, but power outages and spikes are too often damaging beyond affordable repair.
Good luck, and hope this helps.
Posted on Aug 20, 2010
After a power outage, my rca alarm clock (model RP5435A) is frozen at one time, and no buttons work. Advice?
Hello
Take out the memory battery that have been installed in it. Just wait for 3 minutes. Reinstall batteries, and set the time according to its user manual says. OK.
Aug 29, 2011 | RCA Radio Alarm Clock
RCA RS2000 CD Shelf System - CD Cover Latch
I was recently work on researching your item in the internet, and I was not able to found any supplier of this item or accessories. This only an advice, you can check the supplier where you bougth the said player possible they can give you any appropriate feedback regarding your problem. I am hoping that this will be a helpful information to solved your problem even though I was not able to solved your problem.
Please don't rate me until such other fixya will able to post their own opinion regarding your problem. Thank you.
Nov 29, 2007 | RCA RS2000 CD Shelf System
We had a momentary power failure (breaker tripped). Once power was restored, the radio works but the clock does not. No display at all. Any idea?
It sounds like the outage caused a surge in power and damaged your clock. I recommend connecting all your equipment to surge protector power strips.
Mar 14, 2011 | RCA RP3722 Clock Radio
RCA Clock Radio with CD player RP5620 How do i turn the alarm off so it will not sound at the same time every 24 hours?
1. Rotate the SELECTION KNOB to the WAKE MODE 1 or WAKE MODE 2 position.
2. Press the right or left arrow button to cycle through the wake modes until the alarm indicator on the display completely disappears.
Jan 14, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Cannot set the time, need manual for our RCA RS2620 system
hold in the "clock" button until the hour flashes
use the forward & back buttons for the cd player to set the hour. (located just to the right of the equalizer" button)
once the hour is set, press the "clock" button until minutes are flashing.
use the forward & back buttons for the cd player to set the minute.
once done, press the "prog.set" button below the forward & back buttons
Dec 31, 2008 | RCA RS2620 CD Shelf System
RCA RP3740A CLOCK RADIO CD PLAYER ALARM
Just did it to check the process. Push button: Set (time/wake) Push it until the clock image appears on the upper left screen (it took me three times to push the button for this to happen). Let go of the Set button and press FWD button until it comes to the your time.
It worked for me. gotojo
Oct 07, 2008 | Audio Players & Recorders
I need help
On the front of the system, press and hold Clock button until the hour flashes. Then press the Digital tuning arrows for up or down. Watch the display for AM or PM. Stop on your hour. Press and hold the Clock button again til the minutes flash. Press the Digital Tuning arrows again for up or down. Immediately press Program Set button under the Digital Tuning arrows to set the program in. If you do not press Prog Set soon enough, you will have to do the whole thing all over.
Apr 22, 2008 | RCA 100-Watt Stereo System With 5-CD...
Clock
Turn the system on and press the "Clock/Timer" button (located above the eject button for Deck 1). The clock will appear. To change the time, simply hold down either the < or > buttons (the ones you use to change radio stations and begin CD/tape playback). Press "Clock/Timer" again to lock in the time.
Dec 28, 2007 | RCA RS2622 CD Shelf System
36" RCA TV
My RCA G36788LV 36" television won't turn on
Oct 30, 2007 | RCA G36788LV 36" TV
RCA RP3721 Alarm won't shut off
To turn alarm off completely, press WAKE1 and WAKE2 until the bell-shaped indicators go off.
As for resetting the alarm (buzzer), press SET WAKE/CLOCK untill SET and WAKE! light.  Press left- or right+ arrow to set time.  Press WAKE1 until bell-shaped indicator comes on.
Jun 14, 2007 | RCA RP3721 Clock Radio
57 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
