Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Daniel
Hi
F2 error in your Asko dishwasher indicates that the water is not draining or is unable to drain and dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
