Question about LG Heat cool Window Air Conditioner
What is the cn signal, does it pull the relay, where does it get it voltage from?
    President:
  • 1,796 Answers
Hi!
That is correct, the remote/keypad sends the ON signal to the processor, which in turn sends it to the relay, when the relay is energized, lets current from L1 go thru to the board starting fan and compressor if Cool is selected. The fan uses 3 smaller relays, one for each speed that are activated separately (Fan Only) or together with the compressor (Cool).
So if the relay do not activate, the most common reason is not that is not getting the ON signal, it is because it is defective. If you remove the circuit card, the larger rectangular component with two flat prongs on top, one on which one end of the power cord connects to, its the Start Relay, (take a picture of it and label the wires to avoid confusion ) turn card upside down and de-solder relay, Buy one at any electronics store (about $5) and replace.
Good Luck!! Don't forget to rate this post!!
Posted on Aug 20, 2010
2007 Cadillac CTS No Brake Lights In Iluding The Third Brake Light
Is the EBCM energizing the BAS relay to turn on the brake lights ?
The brake pedal position sensor receives both a 5-volt reference voltage and a low reference signal from the electronic brake control module (EBCM). When the brake pedal is pressed, a variable signal is applied from the brake pedal position sensor to the EBCM through the brake sensor signal circuit. The fuse block left rear supplies battery positive voltage to the bass relay switch through the BASS fuse. One side of the bass relay coil is permanently grounded at G402. The EBCM supplies voltage to the bass relay coil upon receiving the signal from the brake pedal position sensor. The switch contacts of the bass relay close and battery positive voltage is applied through the bass relay switch to the center high mounted stop lamp (CHMSL), and to the turn signal/hazard flasher module through the stop lamp switch signal circuit. The ground for the CHMSL is applied from G402. The turn signal/hazard flasher module then supplies voltage to the left and right stop lamps in the tail lamp assemblies that have ground at G401 and G402. For export vehicles the stop lamps receive battery positive voltage directly from the bass relay.
Did you have a qualified repair shop check for DTC'S - diagnostic trouble codes ?
DTC B3903 Stop Lamp Relay Circuit
The electronic brake control module (EBCM) supplies voltage to the BASS relay coil side voltage supply circuit when the stop lamps are active. The coil side control circuit of the BASS relay is permanently grounded at G402.
DTC C0278 Brake Pedal Position Sensor Not Calibrated
The brake pedal position sensor (BPP) is a potentiometer. The electronic brake control module (EBCM) supplies a 5-volt reference circuit and low reference circuit to the BPP sensor. The BPP sensor signal circuit is a direct input to the EBCM. The EBCM determines the BPP based on the voltage from the BPP sensor. The EBCM converts the BPP sensor feed back voltage to a digital signal and puts it on the class 2 communication bus.
DTC C0282 Brake Pedal Position Sensor Circuit Range/Performance
DTC C0283 Brake Pedal Position Sensor Circuit Low
DTC C0284 Brake Pedal Position Sensor Circuit High
DTC C0880 Device Voltage Reference Output 2 Circuit
Without knowing if any of these DTC'S are stored do not know what diagnostic direction to point you in .
Mar 21, 2018 | Cadillac Cars & Trucks
How do I find out if the wipers on my 2006 H3 Hummeris on a relay?
The Wiper/Washer System consists of the following components:
• Windshield wiper/washer switch
• Body control module (BCM)
• Wiper micro relay
• Wiper 2 relay
• Wiper diode
• Windshield wiper motor
• Windshield washer pump
• Windshield washer nozzles
• Windshield washer solvent container
• Windshield wiper arm and blade assemblies
• Windshield wiper transmission
• WIP/WASH 10A fuse
• WIPER 25A fuse
Wiper/Washer System Description
The body control module (BCM) controls wiper motor low speed operation. The washer pump and high speed operation are controlled directly by the wiper/washer switch. The windshield wiper/washer switch supplies voltage on the signal circuits to the BCM for windshield wiper/washer operation. When WASH, MIST, DELAY, LOW, or HIGH is detected, the BCM energizes the wiper micro relay by suppling voltage to the relay coil. This allows battery voltage from the WIPER fuse to flow through the relay switched input then through the contacts and out the relay switched output to the wiper 2 relay switch contacts. Since the wiper 2 relay switch contacts are normally closed to the low speed circuit of the windshield wiper motor, the motor will operate at low speed.
Low Speed Operation
When the wiper switch is in the Low position, voltage is supplied through an internal resistor to the signal circuit. The body control module (BCM) monitors the windshield wiper switch signal 1 circuit, and energizes the wiper micro relay which will operate the windshield wiper motor. The wiper motor will operate at low speed, since the wiper 2 relay is de-energized. Low speed can also be commanded with a scan tool, by commanding Wiper Relay Cmd. ON and OFF. Refer to Scan Tool Output Controls .
High Speed Operation
In the High position, the windshield wiper/washer switch supplies voltage to both the wiper micro relay and wiper 2 relay coils. This energizes both relays and allows battery voltage from the wiper micro relay switched output to the switched input of the wiper 2 relay through its contacts and out the switched output of the wiper 2 relay to the high speed circuit of the windshield wiper motor. The windshield wiper motor will operate at high speed. During high speed wiper motor operation the wiper switch signal circuit is at the low speed signal voltage, and the body control module (BCM) supplies redundant voltage to the wiper relay via the wiper diode.
This info is out of hummer factory service manual !
Dec 10, 2016 | 2006 Hummer H3
2010 impala high beams do not come on, light on dash comes on, replaced bulbs still don't work, checked all fuses, look good
High Beam Headlamp Operation
Battery voltage is applied at all times to the coil and switch sides of the HIGH BEAM PCB Relay located in the underhood fuse block. When the headlamp dimmer switch is placed in the high beam position, the headlamp dimmer switch signal circuit to the BCM is pulled low signaling the headlamp high beam request. In response to this signal, the BCM applies ground through the high beam relay control circuit energizing the high beam relay. With the high beam relay energized, battery voltage is applied through the switch side of the relay, the left and right high beam fuses, and the high beam supply voltage circuits illuminating the high beam headlamps. At the same time the BCM sends a GMLAN serial data message to the instrument panel cluster (IPC) requesting the IPC to illuminate the high beam indicator. Ground for the left headlamp is provided at G101 and the right headlamp at G100.
Nov 23, 2016 | 2010 Chevrolet Impala
Fusefor indicators 2008 captiva
Your problem is not a fuse if just the right front isn't working , same for all indicators .
Turn Signal Lamps
The TURN fuse in the fuse block - I/P provides ignition positive voltage to the turn signal relay. The turn signal lamps may only be activated with the ignition switch in the ON position. When the turn signal switch is placed in either the left or right position, current flow is from the turn signal relay output to the turn signal switch assembly. The turn signal relay sends an ON-OFF voltage signal to either the left or right turn signals and their instrument panel cluster (IPC) indicator through the turn signal switch.
an it's not a bad relay , if there is no B+ voltage at the lamp you have an open circuit . You would need a wiring diagram to test circuit from turn lamp back to source voltage to find open . free wiring diagrams at www.bbbind.com . video on youtube testing voltage drop Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Oct 02, 2016 | Chevrolet Captiva Cars & Trucks
My 99 olds intrigue just won't turn over like my battery or something dead
How is the battery ? Do the headlamps shine bright ? Did you check the crank relay an the crank fuse 40amp ? one of the big one's ,maxi fuse . Under hood fuse / relay box . Check to see if voltage is coming through the transaxle range switch.
When the ignition switch is on, battery voltage is applied to one side of the crank relay in the underhood accessory wiring junction block through circuit 3, the PCM-BCM Fuse in the fuse block, and circuit 439. When the ignition switch is turned to START, voltage is fed to the powertrain control module connector C2 terminal 23 through circuit 5, the CRANK SIGNAL Fuse in the fuse block, and circuit 806 through the underhood accessory wiring junction block. Power is always provided from the CRANK MaxiFuse in the underhood accessory wiring junction block to the common side of the crank relay contacts. When the powertrain control module sees the crank signal and determines that conditions are OK for a crank, it supplies ground through circuit 625 to the crank relay. The crank relay now has both power and ground to the relay coil, causing the relay to pull in. When this happens, and the gear selector is in either PARK or NEUTRAL, the power at the relay common contact is passed through circuit 1737, the transaxle range switch and circuit 6 to the S terminal on the starter solenoid.
Passlock Theft Deterrent System
This vehicle is equipped with the Passlock theft deterrent system. This system contains a Passlock sensor. The Passlock sensor is part of the ignition lock cylinder assembly. The Body Control Module (BCM) interfaces with the Passlock sensor.
When turning the ignition switch to the START position with the proper key, the Passlock sensor generates an analog voltage signal, which is sent to the BCM. This analog voltage signal is of a specific value to the vehicle, and varies from vehicle to vehicle. When attempting to start the engine, the BCM compares a preset stored analog voltage value with the signal coming from the sensor. Because both values match, the BCM sends a fuel enable password via the Class II Serial Data Line to the Powertrain Control Module (PCM). As a result, the PCM enables the crank relay, and allows fuel delivery to the engine.
When attempting to start the engine by means other than using the proper key in the ignition switch, the Passlock sensor sends a analog voltage signal of a different value. The BCM compares the preset stored analog voltage value with the signal coming from the sensor. Because both values do not match, the BCM sends a fuel disable password via the Class II Serial Data Line to the Powertrain Control Module (PCM). As a result, the PCM disables the crank relay, and does not allow fuel delivery to the engine.
For more information regarding the Passlock theft deterrent system, refer to Theft Deterrent in Body and Accessories
This starting system is computer controlled , if you are not familiar with this I suggest you take a GM dealership or an ASE certified repair shop .
Nov 28, 2015 | Cars & Trucks
I put a rod bearing in it was running good but knocking but now I get no electric to fuel pump
Maybe you forgot a ground, like the engine to ground strap?
No voltage at the tank when the engine is cranking? Find the fuel pump relay under the hood. Hold a finger on it while someone cycles the key to on. You should feel it click. If so, pull the relay and verify battery voltage is available to the relay's power side terminal. This would be a hot at all times terminal, right from a maxi fuse or fusible link. If no click from the relay, pull it and investigate the coil side of the relay. the pcm signals this relay on for two seconds with the key to ON-to pressurized the system. Then the pcm also signals to the coil side of pump relay when the engine is cranking. The pcm can act on the positive or the negative of the relay's coil, but it is what controls the FPR.
Mar 08, 2015 | Cars & Trucks
Headlights will not come on 02 s10
Have you checked fuses ? The Instrument panel fuse block , Fuse Block - I/P
LH of the I/P, near the door jamb switch - LF , fuse # 7 HDLPSW 10amp.
In the underhood fuse / relay box - Headlamp power relay , RT HDLP fuse 15amp LTHDLP fuse 15amp.
Battery positive voltage to the headlamp switch is supplied by the HDLP SW fuse in the IP fuse block. When the headlamp switch is in the HDLP position, the headlamp power relay coil is energized. A voltage signal is also sent to the body control module (BCM) signaling that the headlamp switch is activated. The headlamp power relay coil is grounded at G102. When the headlamp power relay is energized, the relay supplies battery voltage to the LT HDLP and RT HDLP fuses. Both low beam headlamps are grounded by the multifunction headlamp dimmer switch in the low beam position through the normally closed headlamp grounding relay in the body relay block to G200.
High Beams-Except ZR2 Battery positive voltage to the headlamp switch is supplied by the HDLP SW fuse in the IP fuse block. When the headlamp switch is in the HDLP position, the headlamp power relay coil is energized. A voltage signal is also sent to the body control module (BCM) signaling that the headlamp switch is activated. When the headlamp switch is in the AUTO or PARK position and the ambient light sensor detects darkness, the BCM produces a voltage signal that will also energize the headlamp power relay. The headlamp power relay coil is grounded at G102. When the headlamp power relay is energized, the relay supplies battery voltage to the LT HDLP and RT HDLP fuses. The RH high beam headlamp receives current directly from the RT HDLP fuse. When the headlamp switch is in the HDLP position, the BCM removes the ground path to the headlamp grounding and DRL relay coils. This allows current to flow to the LH high beam headlamp through the normally closed contacts of the DRL relay. Both high beam headlamps are grounded by the multifunction headlamp dimmer switch in the high beam position through the normally closed contacts in the headlamp grounding relay to G200. A ground signal is also sent to the BCM in order to confirm high beam operation.
In the i
Mar 01, 2015 | Cars & Trucks
What are the possible defects in a goldstar tv model cn 14b306...having a relay trouble.and low voltage at the capitor near the reg ic
Check the bridge rectifier diodes for leakage. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 21, 2015 | Televison & Video
I hve audi a4 1998 quattro my turn signal light n flasher is nt working,tell me where i cn find flasher relay
reley eithor under dash witch is most likely
but on rare ocation it is under the hood in fuse panel
turn on emerg flashers and folow sounds likely the other reley not far
Jan 08, 2010 | 1999 Audi A4
Electric radiator fan does not come on.
signal from temperature sender goes to the computer which then tells the relay to close. relay should have power at one leg which when contacts close, comes out the other leg and goes to the fan.
Jun 12, 2009 | 1999 Jeep Cherokee
LG Heat cool Window Air Conditioner Logo
103 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
