Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Can I connect a laptop to the printer using the USB port on the front of the printer
    Sergeant:
  • 167 Answers
Yes you can Connect your Printer to your laptop using a USB cable and you need to Install the printer drivers software in your laptop so that your printer works If you have lost the Printer Drivers You can Download using this link http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp
Posted on Aug 20, 2010
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: to connect Epson lx 300 printer on a laptop which
You need to buy an USB to LPT adapter like the example below:
Adapter USB to LPT - acer Store
or check Adapter LPT USB
Posted on Feb 23, 2009
Inky
  • 691 Answers
SOURCE: usb printer problem "port in use please wait"
Can you advise which operating system you are using? Assuming 32bit windows: Unplug the printer from the USB and try deleting the printer from the printers folder. Then download the latest driver from the Canon web site. Once you have you have it, in the control panel go to SYSTEM and into HARDWARE tab and then DEVICE MANAGER. Look under UNIVESAL SERIAL BUS CONTROLLERS and check that there are NO yellow symbols. If there are yellow symbols you need to remove the offending item from the list (making a note of it's description) and then reboot your machine. When it comes back up it should advise that new hardware has been found and go through the process of installing the drivers. You can now go the manufacturers web site and download the USB controller driver for your device. If the file is a zip extract it to a folder on your PC. When it asks if it can go online to find a suitable driver, let it do so and you can also specify a location for it look (where you extracted the download above) Once it finds the driver required and has finished installing it, reboot your system and then install the printer driver you just downloaded. Hopefully this will get you back on the go. If you have a windows 64 bit system I'm afraid you are on your own. 64 bit drivers that work are very hard to come by. Let us know if this is any use to you, if not we may more to offer.
Posted on Sep 16, 2007
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
How do i change the language bak to English? And how do i print from my macbook laptop onto the printer
TO CHANGE THE LANGUAGE:
From the printer control panel, press the 'Spanner' icon.
Press the right arrow button, and then press OK
Press OK again.
Press the arrow buttons until the language that you want appears on the display, and then press OK.
If you are sure, press the right arrow button, and then press OK to change the language.
To print from your macbook laptop you may have to install additional software onto your laptop from the installation CD. Insert the CD and wait for the 'Welcome' screen to appear. (Note if the 'Welcome' screen does not appear after a minute, then click the CD icon on the desktop). Double click 'Install' and follow the screen instructions.
Some additional notes that may apply to your machine(s):
If the printer is connected to a desktop computer through the rear USB port and you decide to connect a laptop computer to the printer through the Quick Connect laptop port, then the Quick Connect laptop port connection overrides the rear USB port connection. The active print jobs on the desktop computer may be cancelled. Pause or cancel active jobs on the desktop computer before switching between ports.
To summerise:
Pause or cancel active jobs on the desktop computer.
Connect a USB cable to the laptop computer and then to the Quick Connect laptop port on the front of the printer.
Warning-Potential Damage: Do not plug in or remove the USB cable from the Quick Connect laptop port while a memory device is being accessed by the printer.
If you have not yet installed the printer software on your laptop then install it now.
Hope this helps
Jul 14, 2011 | Lexmark X6675 All-In-One InkJet Printer
I have epson c43sx pinter, i will use to my nootbook (laptop) with usb port but i can't connected it. there is warning on my screen "comunication error". how to use my printer and my laptop with usb?
This will be because of your problem in your USB port. So try connecting using some other Port. Still the same problem persists means, try connecting the laptop and printer with another USB cable. This error means that there is no problem with your laptop or with your printer. This is just the cable or port problem.
Aug 02, 2010 | Epson Office Equipment & Supplies
I have a HP Deskjet 6540printer and a HP laptop.What I have to buy to print wireless from my HP laptop' Thank you for your help
Attached is a link to the HP Deskjet 6540 Support page on HP.com. The manual has a section on networking. That section displays as below:
5 Connecting to the printer
• USB
• Front USB port (HP Deskjet 6540-50 series)
• Front USB port - printer software not installed
• Front USB port - printer software already installed
• Using the front USB port
• Networking
• Sharing the printer
• HP Jetdirect 175x
• HP Jetdirect 310x
• HP Jetdirect 380x
The link to the HP page is:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&product=357211&lc=en&jumpid=reg_R1002_USEN
I hpe you find this information helpful. If so, please leave positive feedback for me.
Thank You,
Brian
Jan 25, 2010 | HP Pavilion dv9000z Notebook
HP Printer Usb port in my Acer Laptop , shortcircuits my house
hello
Try using external USB HUB (POWERED) Adapter. It might fix this issue.
Use an other USB cable and see.
If the problem still exist do not plug in the printer again, you may damage your USB port or even burn your laptop motherboard.
hope this helped
TekSpotDotCoDotUK
Aug 26, 2009 | Acer Aspire 6930-6941 Notebook
Printer is connected but does not print
Hi
Thanks for using FixYa. Please check the following things first---
· The printer cover is closed and the rear access door or optional duplexer is attached.
· The printer is connected to the power source and turned on.
· The cable connections are secure and the cartridges are correctly installed.
· The paper or other media is correctly loaded in the in tray.
Now check the printer cable connection: If the printer cable is attached to a USB hub, a printing conflict might exist. Use one of the following methods to resolve the conflict:
· Attach the printer USB cable directly to your computer.
· When printing, do not use other USB devices that are attached to the hub.
Now verify if the printer is connected to the correct USB port: If the computer is configured to use both the back and front USB ports on the printer, then you might be printing to the wrong port. The computer has two versions of the printer driver: one for the front USB port and one for the back USB port. If you are connected to the back USB port, but select the printer driver that is associated with the front USB port, the printer will not print. In the application that you are printing from, click File and then click Print. The Print dialog box opens. The Print dialog box displays two versions of the printer driver. Select the version that is associated with the port to which you are printing. The issue will be resolved.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 12, 2009 | HP DeskJet 6540 InkJet Printer
Trying to connect from USB laptop to parallel printer
You can't have a double hook up to it,When the parallel port is used the usb port is disabled and when you use the usb port the parallel port is disable.This is done to prevent damage to the printer.You can network the laptop with the pc and print that way though
Jun 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Where to connect on computer
The printer will have one of two cables , either it is a USB cable , or an LPT cable
USB Cable Looks Like This:
The LPT Cable Looks Like This:
If it is the USB cable , it will connect to the back of your computer in a USB port, which looks like this:
It it is the LPT cable , it will connect to the back of your computer also:
Sep 29, 2008 | Lexmark Office Equipment & Supplies
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
66 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
