Printer all in one sharp ar-m155
Hi i tried to clean the wire.now when i turn on the printer,it shows me an red triangle and message,,replace toner cartrige''. is anny error codes for this printer? ar-m155 sharp. thanks
    Brigadier General:
  • 6,966 Answers
Hi again,
Sorry but not the wire, I was referring to where the wire is attached, both ends. This would either be a clip-on or sandwiched between 2 small plates held together by a screw. It is not uncommon for this clips or plates to be tarnished or have burns. They have to be cleaned, if not current will not flow freely to the corona wire. The purpose of the wire is to draw the toner from the drum onto the paper, it uses static electricity to coat both the photoreceptive drum and the paper with a layer of positively charged ions. If the corona wire is not getting full charge or no charge at all, this is the primary reason the warming up is taking too long.
Additionally, try to enter service mode; try #, *, CA, #.
To reset the developer counter press 24, Start, 5, Start.
To exit press reset 3 to 4 times or turn main power off/on.
Would appreciate further updates.
Posted on May 03, 2008
I want to know the solution to a sharp ar-5316 i refilled the toner after the toner was empty and the red triangle is still blinking, what should i do?
Does the toner cartridge have a electronic chip on it? if so you could refill it all day long it would not change once the chip say the i am done the cartridge is done. Sorry.
Try this site as a start and get a new OEM cartridge
http://olsonbros.com/sharp/parts/list.htm
Jan 28, 2016 | Sharp Ar 5316
How to fix replace toner cartridge problem when there is enough toner in the cartridge.
Remove from the printer, give it a good shake over the sink, (you may find toner leaking and it is hard to cleanup...then replace it. That may do the trick but if it does not you may be best off replacing the cartridge. Sometimes old electronics misreport the condition of components ....it could be that the machine is getting old and going wrong. But you will only discover whether this is the case after investigating further)
Oct 26, 2015 | Sharp Cartridge Copier Toner/Developer...
AR-M155 keep complaining of change the ink cartridge.while the cartridge is working perfectly with another printer. pls what step should i take please what is the next step to take
well some times you do get bad cartridge is this third party if so replace the cartridge with a OEM. Is there a chip on the cartridge if so clean with alchol also clean the contact inside the machine where the chip connects, buy a new one OEM do not use one from other machines there chips already have data about that machine not the new one
My Sharp Ar-M155 is displaying d message replace the toner cartridge. I ve tested d cartridge with another machine and it is working perfectly
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Jul 07, 2011 | Sharp Office Equipment & Supplies
The little red triangle is lit up
OK, but what is the message?
Like change toner, maintenance required,...?
Jun 25, 2010 | Sharp AR-M205 Copier
Sharp AR-5316
The toner cartridge comes with on-chip sensor that counts the toner life. If you allow it to go empty completely that is it gives red triangle which is steady to warn that toner is near empty. You should replenish toner at this time but if you allow it to blink red triangle, that means its completely over and can't be refilled. REPLACE A NEW TONER CARTRIDGE.
May 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
REPLACING THE TONER
HI! I HAVE BOUGHT THE SHARP PRINTER/COPIER/FAX/SCAN MODEL AR-M155, WHEN I INSERTED THE NEW TONNER AND MAKE THE PHOTOCOPY TESTING I GOT THE OUTPUT COPY WHICH SHOWS THE HALFED COPY IN VERTICAL ON RIGHT HAND SIDE WHEN YOU READ THAT PAPER SO WHAT COULD BE THE PROBLEM ON IT WHILE IT IS NEW MACHINE???? AM SCARED!!!. PLEASE IWOULD BE VERY HAPPY IF YOU HELP ME TO SOLVE THIS MY REQUEST PROBLEM.
THANKS,
Aggrey34
Sep 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
734 people viewed this question
jasbo
jasbo
