Question about Philips Televison & Video
I have a Philips 42pf9631d/10. The TV works great, the problem is that when I switch on with the remote it often shows a green light then red which continually blinks. If I swith off the power the red light blinks up to 5 times slowly followed by three quick blinks then a quick amber light. Sometime this can happen 2 or 3 times before the set powers up properly. I also find that it skips several channels when doing this. I have bought the unit second hand I find that the power button at lower right side has been pushed in and will not come back out. I think it will need a new button panel, but any other advice will be greatfully received. Thanks Ian Wason
SOURCE: TV will not turn on, the light goes from green to red.
I own the same model. You have 1-2 Blown Capacitors. Take off the back cover, And look towards the center of the main power board. Look towards the center of this, and there are 2 capacitors side by side. You should see them swollen at the tops, even maybe a little black residue that has come out. I soldered on 2 new ones, and bingo! I would suggest replacing them both.
Posted on Jan 11, 2009
ginko
  • 19396 Answers
SOURCE: Red LED blinking after turn on the TV (Philips Plasma 42PF9631D
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
SOURCE: Cannot get set (picture or sound) to come on.
cant find signal with or without cable box
Posted on Oct 05, 2009
SOURCE: LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Posted on Nov 22, 2009
budmrtn
  • 11361 Answers
SOURCE: I have an emerson LC320EM9 HDTV it recently quit
Look at the power supply first, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Dec 01, 2009
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips 42PF9631D 42 in. Plasma Television TV wont turn on..I get the initial green power light, but it quickly goes to a flashing red light (flashes a series of 4 times). Philips tech support is a joke....
Philip have alot power problems with their tv.Check power board for puff up parts like Capacitors,or rust in cracks or soldering.Changes parts or the whole power board.
Jan 08, 2010 | Philips 42PF9631D 42 in. Plasma Television
One minute its good, the next i get nothing.
There is a eletronics parts thats has a cold solder on it. Maybe there is a cable or wire is barely touching on the connector inside the main pcb board. See technician to check your tv. Don't let this problem will continue, bacause some of the electronics will be damage.
Jul 24, 2009 | Philips 42PF9631D 42 in. Plasma Television
7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Jun 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
Mar 28, 2009 | Philips 42PF9631D 42 in. Plasma Television
Dec 13, 2008 | Philips 42PF9631D 42 in. Plasma Television
Televison & Video Logo
131 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
