Question about Nokia N76 Smartphone
Prints of battery connectors has been losted from the plate
The battery connectors of my n76 has been detached fomr the plate and the connection track has been losted. How can it be repaired?
  • Anonymous May 15, 2008
    The battery connecting block has detached from the main phone and one pin has been lost, can you buy a new block and where from?
  • Anonymous Feb 02, 2009
    battery terminal print has been spoiled
Print of battery conector losy{n-76} plz help
Posted on Jan 20, 2009
BATTERY REPLACEMENT Always turn off power to smoke alarm before replacing battery.
Replace battery at least once a year, or immediately when the low
battery signal sounds (a beep once per minute indicates low bat-
tery). Batteries should be replaced regularly as necessary, even
when the smoke alarm is receiving AC power.
Use only the following batteries as replacements in this smoke alarm: Eveready 216, 522, 1222, Duracell MN 1604, or Ultralife U9VL-J [Alkaline batteries 9Volt] DO NOT USE RECHARGEABLE
1. Turn off power to smoke alarm at main service panel.
2. Turn smoke alarm counter-clockwise to detach from mounting plate.
3. Gently pull down smoke alarm. Be careful not to separate wire
4. Pull out power plug from back of smoke alarm.
5. From back of smoke alarm, lift tab to open battery pocket door.
6. Remove battery from pocket. Disconnect and discard bad battery from battery connector.
7. Connect a fresh, 9-volt battery to connector. The battery will fit
only one way. Be sure battery connector is securely attached to
battery terminals.
8. Place battery into battery pocket.
9. Close battery pocket door. Push down until it snaps into place.
10. Replace connector plug. Connector will "snap" into place.
Gently tug connector to be sure it is attached properly.
11. Reattach smoke alarm to mounting plate by turning smoke
alarm clockwise until it snaps into plate.
12. Turn on power and test smoke alarm using Push-to-Test button
Jan 03, 2018 | Home
My laptop shuts down in 5-10 mins.
Purchase a new fan for the Sony Vaio model you have by checking the owner's manual of your computer or consult the Sony website for the correct part number.
Remove the power cord from your computer and then remove the battery. Unlock the battery and slide it from the bottom of the laptop. Allow it to sit for 5-10 minutes after removing the battery.
Turn the computer with the left side facing toward you and locate the only screw found on the left side and remove it. Remove the panel by sliding it toward you and set it aside.
Slide the panel covering the power buttons to the left and detach the ribbon cable connecting it to the motherboard and then remove the panel gently.
Remove the keyboard by unscrewing the small screw directly above the keyboard. Once the screw is removed, gently lift the keyboard and detach the small cord connecting it to the motherboard. Set the keyboard aside.
Remove the plate under the keyboard by unscrewing the three screws and lift the plate out.
Disconnect the cooler fan from the motherboard by pressing the connectors in and removing them from the sockets. Once the connections have been removed, lift the cooling fan up out of the computer.
Replace the old fan with the new one you purchased and attach the two connectors. Reinstall the metal plate back on top of the fan and attach the screws.
Jan 10, 2013 | Dell Inspiron 1545 Notebook
I need to know how to take the old stereo out of my 1999 buick regal to put in my new cd player? i cant figure out how to get the dash out
Hi, here is the procedure from Please let me know if you have any questions, and thanks for using FixYa.
Removal & Installation
  1. Obtain the THEFTLOCK® codes and radio station presets before attempting to remove the radio, if applicable.
  2. Disconnect the negative battery cable.
  3. Remove the trim plate bezel from around the radio using the following procedure.
    1. Adjust the steering wheel for access.
    2. Remove the ignition switch cylinder bezel.
    3. Remove the left side instrument panel fuse block access opening cover.
    4. Remove the instrument panel cluster trim plate screws.
    5. Starting at the right side of the instrument panel cluster trim plate, grasp the trim plate and carefully pull rearward. Continue working around the trim plate until all of the retainers are released from the trim pad.
    6. Detach the electrical connectors from the hazard switch and remove the trim plate from the vehicle.
  4. Remove the screws from the radio and pull the radio gently from the instrument panel.
  5. Detach the instrument panel wiring harness connector and the antenna cable connector from the radio.
Fig. You must remove the instrument panel cluster trim panel in order to remove the radio assembly
To install:
  1. Installation is the reverse of the removal process, noting the following:
    1. After the electrical connection is secure and the antenna cable is connected, find the radio locator tab.
    2. If the locator tab is difficult to align to the instrument panel locator opening, pull the radio towards you and reposition the antenna cable.
    3. Gently install the radio to the instrument panel, aligning the radio locator tab to the instrument panel locator opening while carefully pressing the radio into the instrument panel until fully seated.
  2. Install the trim plate bezel.
  3. Connect the negative battery cable.
  4. Unlock the THEFTLOCK® radio (if applicable).
  5. Program the radio stations back into the radio as recorded at the beginning of this procedure (if applicable).
Jan 28, 2011 | Car Audio & Video
I have iose my nokia n76 battery track how can i
Dec 31, 2010 | Nokia N76 Cellular Phone
My Dash Isnt working, the gauges dont move or work how do i fix it
Instrument Cluster -it could be a loose connection at the harness. REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Disable the SIR system. Refer to procedure outlined in this section.
  3. Remove the cluster trim plate, as follows. Fig. 1: View of the cluster trim plate (1), instrument panel (2), dimmer switch lead (3), fog lamp switch (4), and mounting screws (5) - Chevrolet Malibu shown 93206g21.gif
    Fig. 2: View of the cluster trim plate screws (1), cluster trim plate (2), and instrument panel assembly (3) - Oldsmobile Cutlass shown 93206g22.gif
    1. Remove the bezel from the ignition switch. Fig. 3: Remove the bezel from the ignition switch 93206p24.jpg
    2. Remove the screws fastening the cluster trim plate.
    3. Gently pry out the trim plate.
    4. Detach the hazard and instrument panel electrical connectors and remove the trim plate.
  4. Remove the four screws attaching the instrument cluster to the dash panel.
  5. Pull the cluster rearward and detach the electrical connections, then remove the cluster from the vehicle. Fig. 4: Exploded view of the instrument cluster assembly 93206g23.gif
    To install:
  6. Attach the cluster electrical connectors and position the cluster into the instrument panel recess.
  7. Install the screws into the instrument cluster and dash. Tighten the screws until fully driven, seated, not stripped.
  8. Install the cluster trim plate, using the reverse of the removal procedure.
  9. Enable the SIR system as outlined in this section.
  10. Connect the negative battery cable.
Nov 09, 2010 | 2001 Chevrolet Malibu
How do i replace the fuse for the lighter in my '99 chevy lumina?
Circuit Protection Underhood Electrical Center #1 Underhood electrical center #1 gm-06-00-703.gif
Underhood Electrical Center #2 Underhood electrical center #2 gm-06-00-704.gif
I didn't see the cig lighter mentioned in my online resource, but with my experience on GM vehicles, the under dash driver's side fuse box usually has a cig lighter fuse listed. If not, then you'll have to get a fuse tester and test each and every fuse until you find the burnt out one.
If the fuse is not burnt out, there may be a broken wire behind the console.
Console Removal & Installation Chevrolet Lumina & Monte Carlo To Remove:
  1. Disconnect the negative battery cable after first disabling the Theftlock® feature of the radio, if equipped.
  2. Remove the front floor console trim plate using the following procedure:
    • Remove the cigarette lighter.
    • Remove the transaxle shift handle.
    • Remove the front floor console trim plate by unsnapping from the console.
    • Detach the automatic transaxle control indicator socket and bulb from the trim plate and detach the electrical connector from the trim plate.
  3. Remove the CD storage bin at the front of the console by unsnapping it.
  4. Raise the console armrest and remove the compartment mat. Remove the screws from console.
  5. Detach the electrical connectors and remove the front floor console from the vehicle.
To Install:
  1. Connect the electrical connectors and position the console on the floor.
  2. Install the screws and the compartment mat. Start with the front right console retaining screws and continue in a clockwise order.
    • Tighten the screws to 106 inch lbs. (12 Nm).
  3. Install the CD storage bin.
  4. Install the console trim plate.
  5. Connect the negative battery cable.
Oct 17, 2010 | 1999 Chevrolet Lumina
How do i replace my 2003 Buick Regal LS head light switch?
GM Lumina/Grand Prix/Cutlass Supreme/Regal 1988-1996 Headlight Switch - REMOVAL & INSTALLATION
Except With Head Up Display (HUD)
(see Figures 1, 2, 3 and 4)
Fig. 1: Headlight switch location and mounting-1988 Regal shown
Fig. 2: The headlight switch is secured with clips and screws-1990 Lumina shown
Fig. 3: Light switch location and attachment-1993 Cutlass Supreme
Fig. 4: Headlight switch assembly-1996 vehicle shown
  2. Remove the instrument cluster trim plate by unfastening the retaining screws or simply unsnapping it.
  3. If necessary, remove the air outlet trim plate. If may be secured with screws/bolts or clips.
  4. If accessible at this time, detach the switch electrical connector.
  5. Remove the switch, using one of the following procedures:
    1. Unfasten the retaining bolts/screws from the switch, then remove the switch from the instrument panel.
    2. Unsnap the headlight switch from the instrument panel.
  6. If not already done, detach the electrical connector from the switch at this time.
To install:
  1. Attach the switch electrical connector and fasten the switch to the instrument panel. If the switch is secured with screws, tighten to 18 inch lbs. (2 Nm).
  2. Install the air outlet and cluster trim plates.
(see Figure 5)
Fig. 5: The HUD incorporates the headlight, fog lamp and HUD switches
  2. Remove the steering column opening filler panel.
  3. Remove the instrument cluster, as outlined earlier in this section.
  4. Depress the locking tabs, then pull the switch out.
  5. Detach the HUD electrical connectors.
To install:
  1. Attach the switch electrical connectors.
  2. Snap the switch securely into the instrument panel.
  3. Install the instrument cluster.
  4. Install the steering column opening filler panel.
Hope this help (remember comment and rates this).
Apr 16, 2010 | 2003 Buick Regal
Where can I read, for free, how to remove the drivers door panel and remove and replace the window regulator. I see these questions on this site but there are NO ANSWERS. What's with that? 1998 Cadillac...
GM Cadillac Deville_Fleetwood_ELD_Seville 1990-1998
Fig. Front door panel-1990-91 Deville and Fleetwood
Fig. Front door panel-1992-98 Deville and Fleetwood
Fig. Carefully pry up the power window switchplate and . . .
Fig. . . . gently remove it from the door panel
Fig. Remove the door pull strap retaining screw covers by gently prying them off
Fig. Remove the door pull strap retaining screws
Fig. Gently pull the inside door handle panel down and . . .
Fig. . . . release the rod from the handle
Fig. Carefully lift up the door panel to release the . . .
Fig. . . . retaining pegs on the door panel
Fig. Do not pull the panel too far away from the door, as some components still have wiring harness connected
Fig. Detach any necessary wiring connectors and remove the door panel from the vehicle
  2. Insert a flat-bladed tool between the door panel and the rear edge of the power window switch plate to disengage the retainer from the panel.
  3. Slide the power window switch plate forward, then label and detach the wiring connectors.
  4. Remove the power door lock switch plate retaining screw. Remove the switch plate and detach the wiring connector.
  5. Remove the pull handle retaining screws.
  6. Using a thin-bladed tool, carefully pry the courtesy lamp lenses off. Remove the courtesy lamp bulb.
  7. Pinch the courtesy lamp retainers and pull out the lamp socket holder. Detach the courtesy lamp wiring connector.
  8. Remove the door panel retaining screws.
  9. Using tool J-2459B or equivalent, disengage the door panel fasteners from the holes in the door. Detach any remaining wiring connectors and remove the door panel.
To install:
  1. Position the door panel close to the door and attach the wiring connectors.
  2. Align the door panel fasteners with the holes in the door. Push in on the door panel to install it to the door.
  3. Install the door panel and pull handle retaining screws.
  4. Install the courtesy lamps and switch plates.
I really hope help you with this (remember rated it) Good luck.
Oct 12, 2009 | 2001 Cadillac DeVille
Nokia N76 Smartphone Logo
157 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
