Question about Dell Inspiron 8000 Notebook
I have a dell Inspiron 8000 that is dead. Was working fine last time used. After pressing the power button The Hd light will flash a few times. There is a few sounds, And you can see a quick bleep in the screen and then nothing. I have tried a different power supply, a different battery, removing the cd drive & 3.5 floppy. This is just out of the blue it was working fine last time used. and this time it wont do anything. Anyone help!!
  • wamper29 Aug 20, 2010
    the problem is that it won't turn on at all and that the battery won't charge either. the battery indicator light will blink orange a few times then blink once green over and over again.
    Brigadier General:
  • 5,158 Answers
There should be a video output on that laptop. hook it up to an external monitor and use the keyboard combination of keys to toggle on the external monitor and watch to see if you get the same issue
Posted on Aug 20, 2010
  • Roberta Smith
    Roberta Smith Aug 20, 2010
    try booting it with only the power supply and no battery.
Charging light is flashing
There are two possible causes for this issue:
1) Your dell 9400 charger is malfunction
2) Your laptop dc power jack is loose or dead
Possible troubleshooting step:
1) Borrow a compatible dell charger to plug in your laptop, if it works without any issue, it means your dell inspiron 9400 adapter need to be replaced.
2) If the compatible dell 9400 charger won't work normally, the problem may lie in your dc power jack.
Hope this will help.
Jan 07, 2013 | Dell Inspiron 9400 Notebook
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
I am using compaq , power is there but the computer won't on for more then two second ? Anyone can help me ?
Sounds like battery is dead and power supply is not working. Seen it dozens of times w/PCs usually bad power supply.
Jan 04, 2011 | Dell Inspiron 8000 Notebook
Dell Inspiron E1705 battery light flashes 4 amber lights, then 1 green. The battery seems to charge.
The ambar lights are warning you the battery is becoming to dead, it means in a short time, if it has not happens now, the battery won't retain the charge anymore, it is time thinking in a replacement if you use your laptop without plug in the power outlet.
Dec 29, 2009 | Dell Inspiron E1705 Notebook
Will not power on once chager is plugged in lights flash three times but there is nothing
what lights flashed? is it the LED locks or the battery light? try to run PSa. press andhold the fn key and pree the power button and release button at the same time when you see the dell logo screen
Oct 01, 2009 | Dell Inspiron 1000 Notebook
Power light comes on and goes off and machine is dead
The Motherboard is bad but before you buy one.Try this Remove the memory, cd rom,hard drive battery, power adapter. Press and hold the power button down for about twenty .Replace the memory only,power up if you get the same result the motherboard has to be replace
Sep 15, 2009 | Dell Inspiron 9300 Notebook
Won't turn on
Have you tried a hard reset hold the Ctrl+R key at the same time as switching on the computer will sometimes clear the problem did on mine
Jan 19, 2009 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dead inspiron 8600
take out the battery and use the AC.
if that power up the laptop. then the battery is draining the power source. if not, the laptop power citcuit need to be check out, which I think should be done a repair shop.
Dec 01, 2008 | Computers & Internet
Dell Inspiron 8000 Notebook Logo
63 people viewed this question
Alun Cox
