Question about Yamaha YSP-1 System
This unit is about 4 years old,wont turn on makes the sound of starting up but will not turn on
  • stevensauto Aug 20, 2010
    unit is 4 years old, won;t turn on,power supply is ok, what fails internally in this units
    thank you, i new some one there had a logical solution,some one suggest the power cord was faulty, not the case,as i stated the unit was trying to start up loud clicking noise, thanks for good info, tell other tech to try differant occupation
  • 10,515 Answers
This is a common problem with these sets. This is either a faulty relay on the power board or some failed capacitor on the main board. You need to open the unit to repair it. I doubt if it would be economical to send the unit to Yamaha. You need to catch a local repair guy who could check either/both items on this unit.The relay for this unit is ' not ' easily available in the market.
Good Luck!!
Thanks!!
Posted on Aug 20, 2010
    President:
  • 4,070 Answers
Hi! It's a possible power supply failure. If the power supply is faulty the YAMAHA YSP 1 wont turn on. Have it replaced and you'll be good. Hope this helps and thank you for using FixYa!
  • dj_relly999
    dj_relly999 Aug 20, 2010
    Have a nice day and thank you for using FixYa!
Will not spin
You have a bad motor. At 15 years old, best to put money towards new one. Most motors are over $150 plus home call and labor charge if you call in a service company and you would still end up with a 15 year old dryer.
Jul 08, 2015 | Dryers
AC Wont stop running.
a defective thermostat thats all
Jun 02, 2013 | Dometic Rooftop RV Air Conditioner
Car wont start but it tries to turn over all lighs work and door dings
first check make sure battery has 12.6 volts and battery cables and post clean free from corrosion and battery cables has tight connection.have vechicle jump start or use booster battery if engine trying to turn over battery COLD CRANKING AMPS TOO WEAK battery could be too old if over 4 or 5 years olds.
Jan 23, 2012 | 2001 Pontiac Grand Am SE
1997 chevy blazer s10 cranks but wont start
You have a new battery and it cranks. Turning over is cranking. You are saying it won't start after sitting for six months? What is an old mechanic? Was the cable installed at home during the one year layoff? It sounds as though you failed to hold the old mechanic responsible for installing the correct cable or adjusting the one you have ,so it will start. You have a safety switch issue by the sound of it. Make sure you have the right cable and then find out how to install and if applicable,adjust properly
Feb 07, 2010 | 1997 Chevrolet Blazer
Jeep wont start checked connection and fuses
Check the battery, it sounds like it's flat. Try charging the battery to see if it recovers, but if the battery is about 3 years old or more it is likely to have failed and replacement is the only viable solution.
Jul 16, 2009 | 1996 Jeep Grand Cherokee
Whirlpool refridg side by side
This sounds like the compressor is bad. The clicking sound is the start relay trying to start the compressor and cannot. You stated that it was only four years old. Check the warranty for your frig. Most carry a five year warranty on the compressor.
Nov 10, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Starting system cold, no sound for 2-3 minutes
Its not worth having it looked at. $100.00 for a new 400.00 unit? My unit is doing the same thing. Turn it on and 2 to 5 minutes later it may come on. Change to video 3 4 5 etc it stop again. Only works with a cold start. Something in the unit has failed and is heat related. My original Kenwood 20/20 recevier still works. Must be 40 years old. New products just last 5 to ten years max if your lucky.
Dec 17, 2006 | Kenwood VR-6070 Receiver
Yamaha YSP-1 System Logo
388 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
