Question about RCA HD52W59 HDTV Projection Television
Convergence power supply fuse
Hey i'm the girl determined to fix her hd52w59 hdtv. you had suggested to check the convergence power supply fuse. i was able to locate the fuse but am not sure how to go about checking it. can you explain how to check this fuse link? i'm familiar with checking a glass fuse but not so sure on this fuse link. i appreciate the help, thanks.
    Genius:
  • 1,030 Answers
The fusable link... can be check with continutiy.. or a ohm meter......u need a meter that can do this when you put a meter across it it will read o ohms if good and infinate if bad some meter beep when it has near zero ohms meaning good... if you have any question. i can be reached at willie AT fordtv.com.... from your desciption it does sound like the fuse... However when you replace the fuse you have to make other repairs or it will fail again...falty solder connections is what cause this
Posted on May 05, 2008
On what board is the convergence fuse on a ITC222. Have the Convergence Power Supply board out and cannot spot it.
The fuse for the convergance power supply most likly is not your problem, go to the board below it, the deflection board and neer the flyback you will find three small fuses the one in the center is the most common problem with convergance and this also can be cused by the pins for the flyback comming unsoldered
Nov 10, 2009 | RCA HD52W59 HDTV Projection Television
Where are the convergence chips and resistors (pico fuses) located in the rca hd52w59 hdtv projection tv?
There are none in that chassis. You can get the convergence option missing repair kit at the following link and the kit contains the parts and CD with instructions. www.tvrepairworld.com
Sep 12, 2009 | RCA HD52W59 HDTV Projection Television
Hd52w59 convergence fuse
what is wrong with you television ... does not have convergence. did you replace the fuse
Nov 25, 2008 | RCA HD52W59 HDTV Projection Television
Fl231 replacement
ok first lets determine if the fuse is the poblem. do you have convergence option in the setup in customer menu. if you do then it will not be the fuse. if you have that option go into blue and red convergence. when you arrow over left or right up and down do the cross hairs move if they dont then it will be the power board(convergence)
Sep 24, 2008 | RCA HD52W59 HDTV Projection Television
Fl231 fuse compatibility
yes, thats the replacement fuse for your set. However unless you have replaced the convergence power supply also chances are the fuse will blow again, as the power supply shorting is what causes the convergence to get out of alignment and it will then blow FL231 thereby removing the convergence option from the menu.
Sep 02, 2008 | RCA HD52W59 HDTV Projection Television
FL231 RCA HD52W59
You dont want to leave that fuse jumped, as it blows when there is a problem with the convergence power supply, and if the power supplt surges again with that fuse jumped you will destroy the convergence power supply and the deflection board and the cost would be in excess of 500 for those two boards.
Aug 31, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 Convergence issues after some repairs.
Hello rmolen,
This is an indication that the convergence amps are drawing too much current which has an effect on the power supply and thus killing your sound by removing or lowering the voltage supplied to that stage, finally this results in the blowing of the fuse. I would suggest that you change the convergence amplifiers and the biasing resistors (All of them) and then see if this corrects your problem (I believe it will). Also get a schematic of the TV and try to find out how the power supply relates the sound module and the convergence module, they might share a common power bus, or the voltage regulator for the sound also feeds the convergence board.
I hope this helps,
Thank you,
Shuttle83
Jul 08, 2008 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 convergence?
Before you go and buy parts it might be worth your time to check the convergence power supply fuse. It's located in the back of the TV just to the right of a large black component with 2 red wires coming off of the top. This is the flyback transformer. Just to the right of the flyback you should see three fuseable links that look like chicklet's gum. The one that may have fried is the one in the middle, it's a 400mA 125V fuseable link. Hopefully thats all your problem is.
Apr 28, 2008 | RCA HD52W59 HDTV Projection Television
Convergence??
e-mail me at networks@q.com and get me the chassis number see in the back of your tv under model number maybe chassis number
Apr 17, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
241 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
