Question about Sharp Zaurus ZR-5700
HI,MY SHARP ZR 5700 READS REPLACE MAIN MEMORY BACKUP BATTERY, IS THAT THE CR2032 ROUND BATTERY AT THE BACK OF THE UNIT? Thanks
3 Suggested Answers
SOURCE: zr 5700 usb connector cable to pc
usb to serial and use old cable
Posted on Aug 28, 2008
SOURCE: How to do with Sharp ZR-3500
On the back of the unit, there is a battery selector switch. Move the selector to the 'replace batteries' position. Now you can open the main battery compartment. Adjacent to the main compartment is a smaller hatch secured by a small hex-head screw. Loosen and remove the screw to remove the hatch cover. Then you can remove and replace the old 2032 battery with a new one. Reverse the procedure to secure the hatch, ensure you have fresh batteries in the main battery compartment, replace the main hatch, select 'normal operation' and you should be good to go.
Posted on May 10, 2009
ZR-5800 won't restart
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Aug 10, 2012 | Sharp Zaurus ZR-5800
While trying to transfer data from my Zaurus ZR-5000 to my computer a message comes on my computer screen saying " the Win 16 Subsystem has insufficient resources to continue running. Click OK, close...
You may be short of memory due to too many programs running in background. Google "windows task manager" to learn how to control startup programs. It is not too complicated.
Dec 03, 2017 | Sharp Zaurus ZR-5700
Sharp zaurus zr-5000 stopped working. Any way to get my backup flashcard (FL02M-20-11138-XX 15095) to read to anything?
I have lost all comm ports for exchanging info to and from my Zaurus 5000. It says my ports are being used by my mouse which is not true.
Anyone have any ideas on how to retrieve ports?
Ted
Oct 20, 2010 | Sharp Zaurus ZR-5700
I installed replacement batteries with the polarity reversed. Since then unit does not display the Contact file, but all other functions (activities, data files, etc.) seem unimpaired. Any ideas? I...
Hi, well the reason this has happened is that these contacts are stored in battery backed up NVRAM, now this RAM is very sensitive to polarity reversal, and also due to the way it works, doesn't have polarity reversal protection, on that circuit. So when you reversed those batteries even though the reverse polarity protection saved the Unit as a whole, the NVRAM would have been destroyed or wiped at best. These is no real way of replacing this NVRAM, I guess you could send it back to the factory though and ask for a "Quote" with view to the repair.
Sep 14, 2010 | Sharp Zaurus ZR-5700
How to transfer Sharp Zaurus 5800 data to mac osx leopard?
Hi you can use Bluetooth, or if you have the cable to connect from the Zaurus to the computer you have make the connection and make sure the computer recognize the Zaurus before you can do any transfer.
Jul 28, 2010 | Sharp Zaurus ZR-5700
Sharp wizard. Batteries dead. can you retrieve information???
Depends. The Wizards had backup battery. As long as it is still good, then your data is safe. if you saved / copied / made backups to the compact flash card (Type 1 option) as well, then you have a copy there that you might be able to use in a computer. Sharp used a different, not quite proprietary, format for storing data though. You may be able to see the data on the computer, but won't be able to open the individual files.
If your backup battery is dead, and the main batteries are dead, and you don't have backups on CF, then your data is likely gone.
Jun 23, 2010 | Sharp Zaurus ZR-5800
NEED A SHARP ZR-5700 MANUAL FOR ORGANIZER
You can down load the manual on the link below.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good Luck and please rate 4 thumbs for the free answer
Mar 16, 2010 | Sharp Personal Organizer & Spanish/English...
Replace battery in Sharp OZ-8000 pda.
unscrew 3 little screws at the bottom cover using jewelry phillip driver-remove the cover- you will see further instructions inside the cover. This model requires 5 batteries CR2032 (4 for main memory-1 for backup memory)-Hope it helps.
Apr 11, 2009 | Sharp Wizard OZ-800
Jan 08, 2009 | Sharp Zaurus ZR-3500X
Zr 5700 usb connector cable to pc
Aug 20, 2008 | Sharp Zaurus ZR-5700
Sharp Zaurus ZR-5700 Logo
56 people viewed this question
Top Sharp Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
pontelemon
pontelemon
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
