Question about Cameras
User manual I cannot get the flash to work since inserting a memory card. Where can I get a manual for this camera
    President:
  • 2,712 Answers
First, kindly give me the make and model of camera please?
In the meantime, try a different card and see if that resolves the issue and let me know..
Posted on May 03, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    Thank you for using FIXYA!
    IrishDruid
When i insert the memory card, it is not showing on my phone. but if i insert the memory card in some other phone then it shows. Kindly help??
Your phone may simply not be compatible with cards of that capacity. Try a smaller capacity memory card, or check your user manual for memory card restrictions / maximum capacity.
Jun 20, 2011 | SanDisk 2GB microSD Memory Card
8g sd card doesnt work on jvc camcorder...it says card error
Each camera have maximum memory card to be readable. If the memory capacity is to high from the limit, the camera will hard to write the data inside the card and said that "card error".
Try to insert memory card with lower capacity (4 or 2 GB) and read the user manual to know optimum memory card for your device.
Hope this help and RATE please !
Jan 16, 2011 | Cameras
How do I delete the pictures from my Nikon coolpix880 camera
Use this option to format the internal memory or memory card. Formatting the Internal Memory To format the internal memory, remove the memory card from the camera. The [Format memory] option appears in the setup menu.
Formatting the Memory Card
When the memory card is inserted in the camera, the [Format card] option appears in the setup menu.
or for more detail get the user manual from here
http://www.nikonusa.com/pdf/manuals/coolpix/L12_en.pdf
do rate the solution if helped
Nov 28, 2010 | Nikon COOLPIX L12 Digital Camera
I have a Conon Powershot S1 IS camera and bought a Transcend Compact Flash 4GB memory card and when I insert in into the camera a red light flashes at the menu and set buttons?
Have your new memory card inserted into your PC to test for any virus. Format the memory car.
Please check if your cannon is adaptive to the 4GB (check the instruction manual) if the card shows the same fault now after inserting.
Use another card into the camera to confirm if the card slot is faulty.
Sep 13, 2010 | Canon PowerShot S1 IS Digital Camera
I have a HP PSC 1610 All in one printer and I tried putting my media card in the SD slot and it tries to read the card but the red light flashes and says memory card error. HELP Please!
If using the Card Reader -
The HP all-in-one has detected an error with the memory card.
1. More than one memory card is inserted in the HP all-in-one.
2. An incompatible camera is connected through the camera port.
3. A memory card is inserted and a digital camera is connected at the same time.
Solution:
Remove and reinsert the memory card. It may be inserted incorrectly. If the problem continues, the memory card may be defective.
Remove one of the memory cards. Only one memory card can be used at a time.
Check the user guide that came with the camera to see if it supports PictBridge. If it does not, try using the cable that came with the camera to connect the camera to the USB port on the back of the HP all-in-one instead of to the HP all-in-one camera port. If the camera does support PictBridge, make sure the camera is set to PictBridge mode. See the user guide that came with the camera for instructions on how to do this.
Remove the memory card or disconnect the camera. Only one can be used at a time.
You might try the following - Reformat the memory card in the camera or format the memory card in a Windows XP computer by selecting the FAT format.
Hope this helps!
May 01, 2010 | HP PSC 1610 All-In-One InkJet Printer
Is San Disk memory card compatible with Digimax 401 ? I inserted one and got the message card errior.
SD Memory Card is compatible with your Digimax 401 camera. You just need to format the card.
Formatting a memory card
** This is used for formatting the memory card. If you run [FORMAT] on the memory card, all
images, including the protected images, will be deleted. Be sure to download important
images to your PC before formatting the memory card.
** If the memory card is not inserted, the internal memory will be formatted.
** Be sure to format the memory card if you are using a newly purchased or non-initialized
memory card, if it contains data that the camera cannot recognize, or if it contains images
captured with a different camera.
Formatting a Memory Card
1. In any mode other than Voice Recording mode, press the MENU button.
2. Press the LEFT/ RIGHT button and select the [SETUP] menu tab.
3. Select the [FORMAT] menu by pressing the UP/ DOWN button and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button.
- If [No] is selected : The memory card will not be formatted.
- If [Yes] is selected : A [PLEASE WAIT!] message appears and the memory card will be formatted. If you ran FORMAT in Play mode, a [NO IMAGE!] message will appear.
Apr 12, 2010 | Samsung Digimax 401 Digital Camera
Genius G-Shot HD55 (camera) - How to get SD card working??
For Genius G-Shot HD55 you need to insert the SDHC card deeper into the slot until it clicks closed, like opening a pen, then when you want to remove it press it again until it clicks to release, like closing a pen. Your card is recognised after the deep click insertion and restarting the camera.
Dec 13, 2008 | Genius Cameras
Memory card Samsung Nv3
This is a common problem and I had the same issue. Samsung only guarantees that a 1GB external memory card will work. If you look at the user manual on page 77. I just used a 1GB memory card instead and it worked fine.
I am not saying that no memory cards greater than 1GB will work but I would try to find someone that has used the brand and size and knows that it will work.
Sep 08, 2008 | Samsung NV3 Digital Camera
Sony 512mb Memory card
You can insert the memory card to the card reader and then insert the card reader to the PC. Access the drive where the memory card created and then right click it and then format.
You can format also using the menu of the camera. refer to user manual in formatting camera storage disk.(memory card)
may this help:
melnavz
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
May 27, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
