Question about Westinghouse Refrigerators
My freezer icemaker constantly has a frosting problem in the front of the ice box and into the ice shoot. This is a rental unit that isn't used frequently, is it because it is not used or opened frequently. Should I turn off the icemaker until the unit is occupied?
    Champion:
  • 245 Answers
The inlet valve is going bad.
Posted on Aug 20, 2010
Ice maker freezing up, odor in freezer
is water supply ok? leak around freezer door, fix/replace freezer door gasket
Oct 09, 2015 | Frost Refrigerators
Why is ice forming in freezer
Ice layer inside freezer box floor - Defrost drain line clogged.
Frost or ice on freezer box top - Room air leaking into the fridge from door seals.
Frost on the Freezer box back wall means unit is not defrosting properly.
Sep 04, 2014 | Whirlpool Refrigerators
Ice maker doesn't work.model kbfa25erss01
Hi and welcome to FixYa, I am Kelly.
Often when ice-makers stop working the real problem is that the freezer is not cold enough (It must be 14-16F for the icemaker thermostat to cycle) Check for signs of ice or substantial frost in the back of the unit / evaporator coil area. If you have ice / frost in this area you should do a manual defrost by unplugging the unit and directing an external fan into the freezer compartment for about 2 hours while it makes a water mess that will need to be tended too. Once the 2 hour thawing is complete wipe up the excess water and return the unit to normal service. If the problem was caused by excess ice it will operate normall for 2 - 3 days before ice production slows or stops totally. Should the manual defrosting correct the icemaker problem you most likely have and automatic defrost problem in the form of a problem with one of these 3 components:
1. Defrost control
2. Defrost heating element
3. Defrost thermostat
Having said all of that... You can use this manual to check out your icemaker:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Make sure to test the coils on the inlet water valve for continuity. If one of the coils is open *** must be replaced. The inlet water valve is NOT repairable.
Your water valve can be found here:
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-water-inlet-valve-item-number-ap4080917.aspx
Here is another link on how to test out the icemaker:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The ice-maker thermostat must be at or belw 16 F for the above tests to work.
NOTE the freezer door LIGHT switch must be taped down also.
Before you get too deep into troubleshooting checkout the freezer door light switch first. If the switch is bad the freezer compartment light will not work and the ice-maker also will not work.
Thanks for choosing FixYa,
Kelly
Jun 24, 2011 | KitchenAid Refrigerators
My ice maker not making enough ice . I have already check the water. thank you
When an icemaker slows production, the problem is not the icemaker at all but the temps in the freezer warming up because of an airflow problem either in the freezer compartment evaporator coils or underneath the unit that being the condenser coils. (Fan not working or lint blockage)
Airflow problems in the freezer compartment are caused by the fan or the automatic defrost system not functioning properly so yu end up with an ice block / lots of frost in the freezer compartment on the back wall of the compartment.
Check for ice or large amounts of frost in the freezer compartment. If you note ice / excessive frost, unplug the unit, empty the freezer compartment and do a manual defrost by directing an external fan into the compartment for just over 2 hours. This will ensure the evaporator coils and the freezer compartment drain have thawed. While the manual defrost is in progress remove the rear fiberboard cover from the compressor access and check / clean the condensor coils and fan area.
After 2 hours clean up the excess water.. reassemble the rear cover and return the unit to NORMAL service. It should start making lots of ice in 4 to 6 hours. Here is the kicker... if there is an auomatic defrosting problem your icemaker will after 2 - 3 days again slow ice producion and ice will build up in the evaporator area. You will have to keep repeating the manual defrosting process every 3 to 4 days until the automatic defrost system is repaired.
There are 3 main components of the Automatic defrost system:
1. Defrost control
2. Defrost heater
3. Defrost thermostat or depending on type thermistor
Most of the time the problem is either the defrost control or the heater that fails and the unit stops defrosting.
Your parts can be found here:
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Refrigerator-Parts/Model-LSC26905TT/3204/0165000
Kelly
Jun 23, 2011 | LG LSC26905TT Side by Side Refrigerator
Buzzing in a full freezer with icemaker model no. 253.44133802
try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
Feb 03, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Have a HOTPOINT CTX18GI fridge. Automatic icemaker doesn't work, but don't know if it's the actual ice maker or any of the switches. Water is going to the line from the sink plumbing via a standard small...
Have you tried raising the arm of the ice maker and leaving it for awhile then push it back down and see if it will work? Should be a cover that is over the plug take the cover off and unplug the ice maker, shouldn't be that hard to take off. I believe you have to squeeze the top and bottom together to remove it but Im not positive.
Nov 09, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
Ice maker is not making ice. I can see no other problem and as far as I know the freezer was not left open as there is no frost buildup inside the unit. Everything is frozen, only problem is NO ICE!!
Pour about 1/2 cup of water into icemaker and see if it dumps the cubes after a few hours . If it does , and icemaker does not refill , then water valve is the problem . If the icemaker never dumps the water poured in , then icemaker is bad . ALSO , check to make sure the coils under refrig are clean of dust , lint , etc . Icemaker has to be 5 degrees to operate .
Jul 22, 2009 | Freezers
GE TFX22CR Ice Piling up in Back of Freezer
You either have icing that you didn't clear or the unit is low on gas.  You might also try cleaning the condenser coils.  This is a big problem in cooling.
To check low gas:  After cleaning the condenser (!), clean around the piping to the compressor in the back of the unit.  Wait at least an hour with the unit shut off.  Restart.  The larger pipe should begin to frost up.  If after about 15 minutes the frosting gives way to: ice, wetness or drying out...the gas level is likely okay.  If it stays frosted, you'll need a gas recharge.
Nov 04, 2008 | GE GSS20IEP Side by Side Refrigerator
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
