Question about Ford 8n,9n,2n, Tractor Starter With Drive
Can not remove starter - Ford 8n,9n,2n, Tractor Starter With Drive
  • 3 Answers
You mean you cannont physically take it out. Is the starter drive bound up with the ring gear? If thats the case put the tractor in high gear and rock it by pushing on a rear tire to unstick the drive... Need more info.
Posted on Aug 20, 2010
Starter removal
remove battery terminals to prevent unexpected grounding of wires at starter. Remove wires at starter, taking note of how they are placed on the starter/selonoid... remove starter mounting bolts, remove starter. Get new starter and install same as reverse. Sometimes the starter has exhaust or other things in the way, so you may have to turn the starter just a certain way to remove it. Might have to come out the top, but out the bottom is the most common way to remove the starter. replace battery wires and vroooom.. off you go.
Dec 17, 2013 | 2002 Hyundai Santa Fe
How do remove and install a starter
Unbolt negative battery lead.
Remove outer primary cover.
Remove bolt on end of starter gear, remove gear and jack-shaft.
Unbolt positive cable from starter. Unhook other wire from starter.
Remove two bolts holding starter on.
Remove starter.
Reverse to reinstall.
Jun 21, 2013 | Harley Davidson FXDL Dyna Low Rider...
How to remove starter from 2004 pacifica
REMOVAL
Disconnect the negative battery cable.
Remove (UPPER RADIATOR CROSS MEMBER) and relocate (UPPER RADIATOR CROSS MEMBER REMOVED) the upper radiator crossmember, (Refer to 23 - BODY/EXTERIOR/RADIATOR CROSSMEMBER - REMOVAL).
Remove the radiator fan module (FAN MODULE IN VEHICLE) (Refer to 7 - COOLING/ENGINE/RADIATOR FAN - REMOVAL).
Remove the wiring harness clip from front mount.
Remove the coolant line clamp bolt (COOLANT LINE BRACKET).
Remove the upper nut from the front mount (FRONT RUBBER MOUNT UPPER NUT).
Remove the upper starter mounting bolt (UPPER STARTER BOLT).
Remove the middle starter bolt (MIDDLE STARTER BOLT).
Raise vehicle and support.
Remove the lower front mount nut (FRONT RUBBER MOUNT IN POSITION).
Raise and support engine (SUPPORT ENGINE).
Remove the lower bracket bolt to transmission (BRACKET TRANS BOLT).
Remove the lower bracket bolt to engine block (BRACKET ENGINE BLOCK BOLT).
Relocate the front mount and bracket.
Disconnect the positive battery cable from starter
Disconnect the solenoid connector from starter.
Remove the lower starter bolt (STARTER LOWER BOLT).
Remove starter from vehicle.
Aug 16, 2011 | 2004 Chrysler Pacifica
Starter diagram for a 1994 dodge intrepid
3.3L Engine
  1. Disconnect the negative (-) battery cable. Raise and safely support the front of the vehicle on jackstands. Fig. 1: Disconnect the negative battery cable 88172g31.gif
  2. Remove the three bolts attaching the starter to the engine/transaxle. Fig. 2: Remove the three starter mounting bolts 88172g32.gif
    CAUTION
    Be careful when removing the starter motor mounting bolts, the motor can be quite heavy. Personal injury could result if the starter motor falls from its mounting position.
  3. Remove the starter from the the transmission housing. Position the starter to gain access to the wiring connectors.
  4. Remove the battery positive cable nut from the starter and remove the cable. Fig. 3: Remove the battery positive cable nut from the starter and remove the cable 88172g33.gif
  5. Disconnect the push on solenoid connector.
  6. Remove the starter from the vehicle. To install:
  7. Clean all wire terminals of dirt, grease or corrosion.
  8. Attach the electrical wire connectors and secure with the mounting nuts. Tighten the starter solenoid B+ nut to 90 inch lbs. (10 Nm) and the solenoid wire-to-starter nut to 55 inch lbs. (6 Nm).
  9. Hold the starter motor in place, then secure in place with the 3 attaching bolts. Tighten the bolts to 40 ft. lbs. (54 Nm).
  10. Lower the vehicle.
  11. Connect the negative (-) battery cable.
3.5L Engine
  1. Disconnect the negative battery cable.
  2. Raise and support the vehicle.
  3. For easier servicing, do not remove the wiring from the starter motor at this time.
  4. Remove the three bolts attaching the starter to the engine. Fig. 4: Remove the three bolts attaching the starter to the engine 88172g34.gif
  5. Remove the starter solenoid assembly from the transfer housing. Position the starter to gain access to the wiring connectors.
  6. Remove the battery positive cable nut from starter and remove the cable.
  7. Disconnect the push on solenoid connector.
  8. Remove the starter from the vehicle. To install:
  9. Clean all wire terminals of dirt, grease or corrosion.
  10. Attach the electrical wire connectors and secure with the mounting nuts. Tighten the starter solenoid B+ nut to 90 inch lbs. (10 Nm) and the solenoid wire-to-starter nut to 55 inch lbs. (6 Nm).
  11. Hold the starter motor in place, then secure in place with the 3 attaching bolts. Tighten the bolts to 40 ft. lbs. (54 Nm).
  12. Lower the vehicle.
  13. Connect the negative battery cable.
Oct 15, 2010 | Dodge Intrepid Cars & Trucks
How do i connect my starter to the battery
REMOVAL & INSTALLATION 2.2L (VIN 4) Engine Fig. 1: Removal and installation of the starter — 2.2L engine shown 87952039.gif
Fig. 2: Remove the starter electrical connections from the back of the starter 91142p05.jpg
Fig. 3: Remove the three bell-housing cover retaining bolts and . . . 91142p06.jpg
Fig. 4: . . . remove the bell-housing cover 91142p07.jpg
Fig. 5: Remove the starter support brace-to-engine bolt 91142p08.jpg
Fig. 6: The starter is retained by two bolts 91142p09.jpg
Fig. 7: Remove the bolts and . . . 91142p10.jpg
Fig. 8: . . . remove the starter from the engine 91142p11.jpg
Fig. 9: Note that the starter bolts are two different lengths, the longer one goes on the inside 91142p12.jpg
  1. Disconnect the negative battery cable at the battery.
  2. Raise and safely support the vehicle.
  3. Remove the electrical connections from the back of the starter.
  4. Remove the bell-housing cover.
  5. Remove the starter support bracket bolt from the engine block.
  6. Unfasten the starter motor-to-engine bolts, then carefully lower the starter.
  7. Remove the nuts/bolts that hold the starter support bracket to the starter. To install:
  8. Transfer the starter support bracket to the new starter if the starter is being replaced.
  9. Raise the starter into position and secure the starter using the starter motor-to-engine bolts. Tighten the bolts to 32 ft. lbs. (43 Nm).
  10. Install the starter support bracket-to-engine bolt to 24 ft. lbs. (32 Nm).
  11. Install the bell-housing cover.
  12. Install the starter electrical connections on the back of the starter. Tighten the "S'' terminal to 22 inch lbs. (2.5 Nm) and the battery terminal to 106 inch lbs. (12 Nm).
  13. Carefully lower the vehicle, then connect the negative battery cable.
2.3L (VIN D) and 2.4L (VIN T) Engines Fig. 10: When installing the starter, tighten the mounting bolts to 66 ft. lbs. (90 Nm) on the 2.3L and 2.4L engines 87952040.gif
  2. Detach the air inlet duct from the throttle body.
  3. Remove the top starter bolt.
  4. Raise and safely support the vehicle.
  5. Remove the lower starter retaining bolt.
  6. If necessary, position the engine wiring harness aside.
  7. Position the starter to enable access to the solenoid wiring, then detach the wiring.
  9. Raise the starter to the vehicle, then attach the wiring.
  10. Position the starter, then secure using the lower starter bolt. Tighten to 66 ft. lbs. (90 Nm)
  11. If moved, reposition the engine wiring harness.
  12. Carefully lower the vehicle.
  13. Install the top starter bolt, then tighten to 66 ft. lbs. (90 Nm).
  14. Fasten the air inlet duct to the throttle body.
  15. Connect the negative battery cable.
Aug 19, 2010 | 1996 Chevrolet Cavalier
How to replace starter
Check this procedure for Starter - REMOVAL & INSTALLATION...
2.0L Engine
Fig. 3: Remove the three starter mounting bolts
Fig. 4: Carefully lower the starter out of the vehicle
  2. Remove air intake resonators.
  3. Remove starter motor upper mounting bolts.
  4. Raise and support the vehicle.
  5. Remove the nuts on the starter terminals and remove the cables from the terminals.
  6. Remove the two starter lower retaining bolts and remove the starter.
To install:
  1. Place the starter into position and tighten the 2 lower retaining bolts to 15-20 ft. lbs (20-27 Nm).
  2. Place the starter cables onto the terminals and tighten the retaining nuts to 80-124 inch lbs. (5-7 Nm).
  3. Lower the vehicle.
  4. Install and tighten the upper retaining bolt to 15-20 ft. lbs (20-27 Nm).
  5. Install the air intake resonators.
  6. Connect the negative battery cable.
2.5L Engine
Fig. 5: Starter mounting-2.5L engine
  2. Remove the engine air cleaner assembly.
  3. Remove the fuel feed and return lines from the support bracket located on the accelerator cable bracket, and remove the fuel line bracket.
  4. On vehicles equipped with a automatic transaxle, remove the gear selector and the gear shift cable bracket from the transaxle.
  5. Remove the air cleaner support bracket from the engine and transaxle mount.
  6. Remove the nuts on the starter terminals and remove the cables from the terminals.
  7. Remove the starter motor-to-transaxle case retaining bolt at the rear of the starter.
  8. Remove the two starter retaining bolts and carefully lift the starter from the transaxle case while disengaging the alignment pins.
To install:
  1. Position the starter onto the alignment pins and onto the transaxle case.
  2. Install the two starter retaining bolts and the rear retaining bolt and tighten them to 15-21 ft. lbs. (21-29 Nm).
  3. Place the starter cables onto the terminals and tighten the retaining nuts to 80-124 inch lbs. (5-7 Nm).
  4. Install the air cleaner support bracket.
  5. If removed, install the gear shift selector and bracket.
  6. Install the fuel line bracket and install the fuel lines in the bracket.
  7. Install the air cleaner assembly.
  8. Connect the negative battery cable.
Hope helps (remember comment and rated this).
Jul 16, 2010 | 1998 Mercury Mystique
How do i remove the starter?
Removal
1. Disconnect negative battery cable. Raise and support vehicle. As required, remove nuts from A/C
compressor, exhaust system and/or engine braces, adjacent to starter. On M/T models, remove bending
brace from around starter (if equipped). On all models, remove other items that may interfere with
removal of starter.
2. If necessary, remove nut from engine cross brace. Using pry bar between upper engine mount and engine,
pry rearward and support engine.
3. If necessary, remove oil filter, air induction tube and cooling fan. Remove flywheel inspection cover (if
equipped). Remove starter solenoid terminal "S" nut and battery cable nut. Separate wiring from starter.
Remove starter mounting bolts. Remove shims and note arrangement for reassembly. Remove starter.
Installation
Before installing starter onto engine, tighten inner solenoid terminal nuts to ensure they are secure in cap.
Starter failure may occur due to terminal or cap damage. Install starter and wiring. Ensure shims are installed in
original location.
Jun 25, 2010 | 1996 Buick Regal Olympic Gold
Where is the starter on a audi a4 1997
0900c152800c2aae.jpg Fig. After the negative battery cable is disconnected, remove the wire terminals from the starter solenoid
0900c152800c2aaf.jpg Fig. Remove the lower starter mounting bolts...
0900c152800c2ab0.jpg Fig. ...followed by the upper bolt, then remove the starter from the transaxle housing
0900c152800c2ab1.jpg Fig. Lower starter bolt locations-1994 2.0L, 2.0L ABA
0900c152800c2ab2.jpg Fig. Remove the upper starter bolts
0900c152800c2ab3.jpg Fig. Mark the location and length of each starter bolt
0900c152800c2ab4.jpg Fig. Remove the starter
0900c152800c2ab5.jpg Fig. Close up view of the starter drive gear
0900c152800c2ab6.jpg Fig. When the solenoid is energized the starter drive is pushed out and meshes with the flywheel to crank the engine
  1. Note the radio security code, and then disconnect the battery ground cable.
  2. Raise and safely support the front of the vehicle with jackstands.
  3. If installed, remove the lower engine shield.
NOTE The engine must be supported on 1990-97 Passat models as the starter mounting bolts also support the engine-to-transmission mounting surface.
  1. If necessary, label the small wires before disconnecting them.
  2. On 1990-97 Passat models:
  3. On Audi A4 and 1998-00 Passat models:
    1. Release the number 50 electrical connector from the starter.
    2. Then remove the nut for the large battery cable and remove the cable.
    3. Loosen then remove the clamp that secures the heat shield to the starter.
    4. Remove the fasteners securing the bracket at the front of the starter and remove the bracket.
  4. Remove the starter mounting bolts, while supporting the weight of the starter.
  5. Pull the starter straight out from the transaxle.
To install:
NOTE On vehicles with a manual transaxle, there is a bushing where the starter shaft fits into the bell housing. If the shaft or bushing is worn or if the starter has been jamming, the bushing should be replaced. There is a special bushing removal tool available but a small inside bearing removal tool is usually sufficient.
  1. Install the starter into the transaxle.
  2. Tighten the related starter motor fasteners as follows:
  3. Starter support bracket, M5 nut: 35 inch lbs. (4 Nm)
  4. Starter support bracket, M8: 16 ft. lbs. (22Nm)
  5. Battery cable to solenoid, M8 nut:10 ft. lbs. (13Nm)
  6. hydraulic hose support bracket, M8: 84 inch lbs. (10Nm)
  7. Starter mounting fasteners, M10: 44 ft. lbs. (60 Nm)
  8. Starter mounting fasteners, M12: 48 ft. lbs. (65 Nm)
  9. The balance of the installation is in reverse order of removal.
NOTE Be careful not to over tighten the battery cable connection. The metal is soft and the threads will strip easily.
  1. Lower the vehicle from the jackstands.
  2. Connect the negative battery cable and enter the radio security code.
Apr 05, 2010 | 1999 Audi A6
Where is the starter on a 1998 cavalier z24
1998 Chevrolet Cavalier 2.4L SFI DOHC 4cyl - Repair Guide
Look at the the lower end of the engine behind the radiator.
2.2L (VIN 4) Engine
Fig. 1: Removal and installation of the starter-2.2L engine shown
Fig. 3: Remove the three bell-housing cover retaining bolts and ...
Fig. 4: ... remove the bell-housing cover
Fig. 7: Remove the bolts and ...
Fig. 8: ... remove the starter from the engine
To install:
  1. Transfer the starter support bracket to the new starter if the starter is being replaced.
  2. Raise the starter into position and secure the starter using the starter motor-to-engine bolts. Tighten the bolts to 32 ft. lbs. (43 Nm).
  3. Install the starter support bracket-to-engine bolt to 24 ft. lbs. (32 Nm).
  4. Install the bell-housing cover.
  5. Install the starter electrical connections on the back of the starter. Tighten the S terminal to 22 inch lbs. (2.5 Nm) and the battery terminal to 106 inch lbs. (12 Nm).
  6. Carefully lower the vehicle, then connect the negative battery cable.
  7. Position the starter to enable accese to the solenoid wiring, then detach the wiring.
To install:
  1. Raise the starter to the vehicle, then attach the wiring.
  2. Position the starter, then secure using the lower starter bolt. Tighten to 66 ft. lbs. (90 Nm)
  3. If moved, reposition the engine wiring harness.
  4. Carefully lower the vehicle.
  5. Install the top starter bolt, then tighten to 66 ft. lbs. (90 Nm).
  6. Fasten the air inlet duct to the throttle body.
  7. Connect the negative battery cable.
I hope help you with this (remember rated this help) Good luck.
Oct 12, 2009 | 1998 Chevrolet Cavalier
Ford 8n,9n,2n,  Tractor Starter With Drive Logo
878 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
