Question about Brother Sewing Machines
My needle will NOT pick up the bobbin thread and the needle is hitting driver and makes the nob on the right hard to move.
    Genius:
  • 1,788 Answers
Your needle is probably inserted wrong-make sure the flat side is facing the rear-read your manual
Posted on Aug 21, 2010
How to fix time hook on special adition XL5700 the needle not picking up the bobbin thread
CHECK THESE FIRST::
NEW NEEDLE.
MAKE SURE NEEDLE IS INSERTED THE RIGHT DIRECTION. LOOK AT YOUR INSTRUCTION BOOK.
MAKE SURE INSERTED IS TOTALLY INSERTED.
CHECK TO SEE IF THE BOBBIN THREAD IS STUCK. ALSO, ENOUGH LENGTH OF BOBBIN LENGTH EXTENDED TO ALLOW THE NEEDLE TO PULL IT UPWARDS.
MAKE SURE THE BOBBIN THREAD IS INSERTED THE RIGHT DIRECTION AND SET WITH CORRECT TENSION.
CHECK TOP NEEDLE TENSION TO INSURE THERE IS TENSION ENOUGH TO PULL THE BOBBIN THREAD ABOVE THE THROAT.
IF THESE DON'T WORK YOU MAY NEED TO GO TO YOUR LOCAL REPLAIRMAN.
Jun 18, 2016 | Sewing Machines
Needle does not pick up bobbin thread
1. Replace needle. Make sure the needle is pointing the right direction and all the way in.
2. Make sure the thread from the bobbin is extended three inches. It must be with the appropriate tension. (Follow guide attached).
3. While threading the machine do it with the pressure foot up and give little tugs to insure there are no hangups.
4. Once successfully threading the machine hold the top thread under the foot towards the back while turning the hand wheel towards you.
5. It should pick up the bobbin thread.
6. Once again; make sure the needle is inserted the right direction.
7 If this doesn't work monitor the bobbin case if it is on top. If it moves fairly back and forth easily the holders on each side of the case might need to be tightened.
Jun 04, 2015 | Sewing Machines
Simplicity sewing machine SL 9240 was giving to me and when I try to sew the needle keeping hitting the bobbin holderr.
On the right side you have two knobs to make adjustments. The lower knob will move the needle left or right so it won't hit the bobbin holder.
May 31, 2014 | Singer 7442 Mechanical Sewing Machine
Will not pick up bobbin thread
you might check your needle to see if it's damaged
make sure you have a least a 3-4 inch thread tail for top & bobbin
try holding the top thread tail & manually move the handwheel on the right side of the sewing machine to lower the needle to the bobbin area & see if that works.
make sure there is no lint or loose threads in bobbin area
Sep 24, 2010 | Riccar Sewing Machines
My bobbin thread will not thread. When I bring the needle down, it comes up without the bobbin thread. The mechanism moves, but no thread. How do I fix this problem?
check the bobbin to make sure it's not warped
check the needle to make sure it's not bent-roll on flat surface to see if it roll correctly
make sure the bobbin is in the bobbin case correctly
make sure you have a 3 to 4 inch tail on the bobbin-so the upper thread can pick it up easily
make sure you have a 3 to 4 inch tail on upper thread also as it picks up the lower thread
or you can hold the upper thread with your hand to the side of the machine & use the handwheel to lower the needle as it picks up the lower thread
pull both threads to the back behind the needle
make sure there is no lint or loose threads in the bobbin area
Sep 01, 2010 | White Sewing 2200 Multi-Tasker
Singer Model 6233 While sewing the bobbin cas...
If you broke a needle and cannot get it to pick up the thread from the bobbin you need to check your timing. Remove the needle plate and turn the machine over watching the needle, when it is at the bottom of its travel the hook on the shuttle should be right next to or a fraction from the needle. So that as the needle begins to move upward the hook should pass it if it passes to soon it will miss the loop of thread. Check to make sure your needle is installed all the way up in the bar. If your machine is out of time and you are fairly handy, you can retime it. There should be 2 set screws some where behind the shuttle. Loosen them, one loose and one only as loose as need be to turn the shuttle. The needle must have moved upward about 1/16 before the hook is in place to catch the loop. This can be time comsuming, and you will have trial and error. Good luck. P.S. always check for simple stuff before you go for the hard stuff.
May 20, 2010 | Sewing Machines
Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
May 24, 2009 | Husqvarna Viking 1
Not catching stitches / bobbin correctly
When you broke the needle I think you have moved the shaft that brings the needle down ,you can adjust it !
Oct 05, 2008 | Bernina Bernette Deco 600
Bobbin thread not being picked up
This unfortunately sounds dismally like a timing problem. When a sewing machine makes a sudden mechanical stop as when a needle is bent slightly and hits the needle plate, sometimes the other machine bits revolve along further causing the needle to be introduced into the hook either to early or to late to catch the thread.
To test this, remove the thread, the needle plate and and the bobbin case. Replace the needle with a brand new one. Yes, again. Revolve the machine by hand via the balance wheel and watch closely as the needle goes into the hook region allow it to it move down and then just start to move up. If the tip of the hook is not pretty close to right behind the needle than it is more than likely a timing problem.
If the tip of the hook is behind the needle in the scarf (the slight hollow on the back of the needle) than it is not timing. Thread the machine normally like it is and watch what happens as you manually turn the machine via the balance wheel. The thread should catch and be pulled around the hook and let go.
Try this and then either you figured it out the problem or contact me again. Either way please vote. Thanks
Mar 02, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
29 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
