Question about Cycling
Spark seen outside thespark plug - Cycling
  • 560 Answers
Simple one.... Replace spark plug.
Posted on Aug 20, 2010
JEEP IS OUT OF TIME
Before removing thedistributoris always good tocheck thepositionof the sameagainstthe engine blockandalsomark theposition of theinnerrotor, uncoveringplasticcrown.
You must putthe wires inthe sameorder they were in,and theplace thedealerI suggest youspark plugDestapes1willput apapercap, turnthe enginemanuallypulling the strapsor with agivenkey andcentercrankshaft, turnuntil thecappops out,thisshouldbe fineseal.when thisskips thedistributor rotortipshould indicate thespark plug wire1.remember tomatchthe groove of theoil pump withthe shaft of thedistributor.you can play withto placeand remove thedistributorturning theslot until thespark plugwillstay inoneconvenient place.is equalif6cilor8cil.
Nov 20, 2013 | 1997 Jeep Grand Cherokee
Where is the spark plug?
Look on the top of the motor where the piston comes up, if it is a flat head or l head motor the plug will stick straight out forward if an ohv the plug will be at an angle next to the cover it should have thespark plug boot on it
Apr 18, 2013 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
Ca find three of thespark plugs in a 2001 mitsubishi galant
there between the engine and the firewall. Just follow the plug wires
Jan 22, 2011 | Mitsubishi Galant Cars & Trucks
Need to kb\now how to change spark plugs on my 2001 sonata
Follow these steps on how to replace thespark plugs. 1. First, you turn off the Sonataengine and allow it to cool. This normally takes about 30 minutes. 2. Raise the hood and locate thespark plug cables along the side of the engine. Spark plug cables are normally1/4 to 1/2 inch thick and plug directly into the engine. 3. Grasp the cable by its boot.This is the thicker piece that covers the spark plug or spark plug well. Turnthe cable back and forth until the lock releases. Pull back on the cable toremove it. Complete the replacement process for each plug before moving on tothe next. Slide the socket, extension and wrench over the spark plug. Turn thewrench to the left to unscrew and remove the plug from the engine. Spark plugsockets have a cushion inside that grab the end of the plug to hold it inplace. 4. Clean the well and boot withthe wire brush. Do not rub hard on the well or boot or it will cause damage.Spray silicon in the boot and on the spark plug threads, so you can easilyremove the spark plug the next time. 5. Insert the socket into the welland gently thread it into the engine. Test the tension with the tester. Thetension a spark plug needs varies by plug manufacturer. Check the package tofind the correct tension. If you need more tension, tighten the spark plug. Forless, loosen or unscrew the plug. 6. Place the cable back onto thespark plug. Repeat Steps 2 through 7 for the other plugs. Work your way downone side of the engine and then down the other as you replace or clean thespark plugs. This are the things you need for the job, 16mm spark plug socket,Socket wrench with extension, Wire brush, Silicon spray, New spark plug,Tension tester
Jan 10, 2011 | 2001 Hyundai Sonata
Were's the spark plug on my old Poulan 2400
look for thespark plug wire /cable on one end there is a boot that snaps on the spark plug
May 12, 2010 | Garden
Cycling Logo
21 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
