Question about Sony CDX-5090 CD Changer
Hi can you tell me how many watts per channel is the cdx-5090 , as i am thinking of up grading but 50 watts per channel is about max for most units ? is the cdx-5090 50 watts
  • 111 Answers
20 x 4 is what it shows on the front of the manual
Posted on Jan 29, 2014
2 Suggested Answers
SOURCE: SONY CDX 5090 - E 04 error message.
I have a Sony cdx 5090 car stereo, I don't have the manual for it. I need to know the wiring color codes for it to hook it up.
Posted on Mar 08, 2010
Son puissance max
800 watts per channel @ 4 ohm
400 watts per channel @ 8 ohm
400 watts per channel RMS @ 4 ohm
200 watts per channel RMS @ 8 ohm
Dec 13, 2010 | Gem Sound GemSound PA-2505 Car Audio...
Wattage
I have the following specs for you
Basically 150watts per channel using two channels , or 75watts using all four
Here goes:
  • 4 Channel Mosfet Amplifier
  • Advanced Overload and Thermal Protection
  • Metal Film Capacitors/Resistors In Signal Path
  • Frequency Response +/-1dB, 20Hz to 20 kHZ
  • Signal to Noise Ratio (A-weighted) >100dB
  • Max Continuous Bridged Power @ 1% THD 150 watts x 2 into 4 ohms @ 14.4 Vdc
  • Max Continuous Power per Channel @ 1% THD 75 watts x 4 into 2 ohms @ 14.4 Vdc
  • Nominal Continuous Power per Channel @ 1 % THD 35 Watts x 4 into 4 ohms @ 14.4 Vdc
  • IASCA/USAC Power Rating 12 Watts x 4 into 4 ohms @ 12.5 Vdc
  • Minimum Load when Bridged 2 Ohms
  • Minimum Load per Channel 1 Ohm
  • Input Signal Voltage Range 0.1 volts to 2 volts
  • Crossover Type Resisitor Network, Linkwitz Riley,
  • Highpass/Lowpass
  • Crossover Slope 24 dB per octave
  • Crossover Frequency Range 20-550Hz
  • Factory Crossover Setting 85 Hz
  • Auxilary Output Channels 2
  • Auxilary Output Frequency Range Highpass or Lowpass, Opposite of Speaker Output
  • Bass Boost 0- to +18dB @ 45 hZ
  • Power Supply Voltage 10Vdc to 15.5Vdc
  • Recommended Fuse 40 amp
Dimensions 12.25L x 9.25W x 2.10H
May 23, 2010 | Car Audio & Video
How many watts is the audiobahn a2401t
i think it's 100watts on 2 channels,
so further explaining: 50 per channel, but if you bridge them, meaning connecting one wire of the speaker to the plus of one and the pother wire the minus of the other will result in 2 channels converting so to say in one channel and giving a 100 watt x 1 channel.
hope this is useful, and greetings,
Olivier.
Oct 20, 2009 | AudioBahn A2401T Car Audio Amplifier
Aug 22, 2009 | Sony CDX-5090 CD Changer
I have all the wires running right but for some reason my amp is not picking up or pushing my subs. could the rca jacks be messed up on the stereo?
According to the specs for the xo 1945- the output is; 50W x 4 Max Power Output , and I do not see a pre amp output listed. So I think to connect subs, you will need a separate AMP.
The way this works; the rear speaker wires from the xo 1945 hook into the Add-on amp, for example a 4 channel amp. In a 4 channel amp, the rear speakers come off two of the channels of the add-on, and the subs come off the other two channels. There is also the option of bridging two channels for more output power to ONE sub.
You did not mention what size sub(s) you were thinking of adding, but keep in mind that the ox 1945 puts 50 watts MAX per channel. So, if you add two 12" subs and a 1500 watt amp to drive them, your total sound is going to be very uneven.
If you go on line and look up auto audio or amps, you'll get a good idea of all the Sub and amp options that are available.... Hope this helps.
May 02, 2009 | Car Audio & Video
Need specs and wiring options
  • 105W x 4 Channel Max. Power Output at 2o.gif Stereo
  • 60W x 4 Channel 0.1% THD at 2o.gif Stereo @13.8V (RMS Continuous Power)
  • 40W x 4 Channel 0.1% THD at 4o.gif Stereo @13.8V (RMS Continuous Power)
  • ChannelFlex Crossover
  • Adjustable High-Pass Frequency (50-200Hz, L/R Independent)
  • Low-Pass Frequency (120Hz)
  • Adjustable Bass-Boost Level (45Hz, 0-9dB, F/R Separate)
  • High-Current, High-Speed Output Devices
  • High-Efficiency, High-Energy MOS-FET Power Supply
  • Audiophile Grade Component Selection
  • Intelligent 7-Way Discrete Protection Circuitry
  • Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
  • High-Level Input - Add on Capability
  • Epoxy Composite PCB
  • 2o.gif Stable Design
Each 6 1/2" speaker will see 40 Watts
Each 6"x9" will see 521/2 Watts
Yes your solution is correct. Front wired in stereo, bridge rear.
Dec 29, 2008 | Eclipse Car Audio & Video
Gem Sound clipping problem
First of all the EXA-3940 is rated at 350watts per channel in to 8 ohms. The 1400 watts is bridged into a 4 ohm load. Second, the speakers can handle 1000Wats peak with an average of 600 continuous (i'm guessing). That tells me that the amp is underpowered for the speakers. The sensitivity of the amp is such that the mixer is overdriving the input stage. That is what is causing the clipping. If you are looking for more volume, you are probably better off purchasing another amp and running them in bridge mode, 1 per speaker cab. Be careful though, not to overdrive the speaker cabinets either.
Dan
Sep 21, 2008 | Gem Sound GemSound PA-585 2-Channel...
Inquiries
Straight from the product's manual...
Amplifier section
Power Output-
[Stereo Mode]
125 watts per channel
[Dolby Pro Logic Mode]
Front
120 watts per channel
Rear (Surround)
60 watts per channel
Center
120 watts
Click HERE for the manual.
There you have it.
Cyryl
Nov 10, 2007 | Aiwa AV-X220
Will this amp push my speakers
Whoa, I do belive your rating for your speakers are inflated. I have never heard of a 6X9 accepting 800 watts thats just rediculas, its more than my 12" sub needs. Anyways, if this amp is anywhere from 300 to 500 RMS watts you will be fine. Because the speakers are small they need very little wattage to reach there potential, usually less than 100 Watts each, and probably around 50. If you think about it most decks put out 50Watts max for each channel, because that is the max you can assume that the RMS wattage of the unit is only around 20-25 Watts of power per speaker.
Mar 25, 2007 | AudioBahn A4401Q Car Audio Amplifier
Car Audio & Video Logo
60 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
