Digital Cameras
Problem for Digital Cameras
Generic problem for all Digital Cameras
I have an error code
By stevec047 on May 03, 2008
I have an error code 99 on my 350d DSLR using a kit lense and a Sigma lense, but not when usings my telephoto, it only happens when there is hih light conditions
Solution #1
posted on May 03, 2008
Not Rated)
IrishDruid
Rank: Guru
Rating: 88%, 1803 votes
The lens contacts are dirty. Get a pencil with an eraser on the end, just a regular old pencil with a rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s do-able: just hold camera so lens opening points down so no gunk falls in. Erase lightly. Use a lens cloth and dab at the contacts rather than blow them so as not to blow the erasings inside the camera.
Do this to each of the three lenses just to be sure.
To summarize:
1. Turn off the camera.
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
5. Depress the shutter button as you would to take a picture.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Comments:
May 31, 2008
- Hi,
Just wanted to inquire if your issue is resolved, or if there is anything further I can do to assist you…
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved.
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
If your issue is not still not resolved, do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can.
IrishDruid
Was this helpful?
Yes
No
Popular Solutions for Digital Cameras
Questions and Unsolved Problems for Digital Cameras
Answer
best for close up pictures for ebay
Answer
sony digital camera charger
Answer
actually im sorry its a casio exilim camera...it lets me view pix but when i try to take them the... (More)
Answer
The battery door on my Kodak EasyShare C913 is cracked and falling apart. I have only owned this for... (More)
Answer
My Vivitar V15 will NOT work in battery mode. I took one back and got another one and both of them... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Digital Cameras:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 904
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
