Question about Frigidaire Affinity AEQ6000WH Dryer
What is error code e68 on dryer model #aeq6000es2
SOURCE: frigidaire affinity dryer problem
help[ my affinity dryer is somehow tearing /slashing rips in my clothes.
Posted on Sep 05, 2008
SOURCE: My Frigidaire Electric Dryer keeps giving an error code
If your dryer is the same or similar to mine (Model AEQ6000ES2) then error E68 is a stuck key on the keypad. This may be mechanically stuck or the membrane contacts. The simple solution is to replace the keypad.
I found this information by searching for "Frigidaire Model AEQ6000ES2"
Posted on Mar 30, 2009
SOURCE: dryer keeps stopping error code e68
E68 error refers to "Current leakage to ground on heater or fuse opened".Problem with the fuse.Try getting it replaced.This can be done by any local repairman.Need not be a technician from Frigidaire,as they charge a lot for servicing. Good luck with the machine.Please do post results and comments.
Posted on Apr 12, 2009
SOURCE: ERROR MESSAGE E 68
Jahn27
  • 1554 Answers
SOURCE: stops working with code e68
The error code means a key is stuck; enter the service diagnostic mode and perform the key test to determine which key is stuck. Once the key is determined, try to unstuck it; replace the electronic control board (part number 134557201) if the error code continues to appear after the button is unstuck.
Press and hold simultaneously the Select and Cancel buttons for six seconds to reset the control then immediately after the buzzer sounds, turn the cycle selector knob 5 clicks counterclockwise to position the cycle indicator light second (Touch Up) from the bottom.
Press and hold the Options and Cancel button simultaneously for two seconds to enter the service diagnostic mode. The buzzer will sound three times and all of the LEDs will flash indicating the service diagnostic mode has been entered successfully.
Rotate the cycle selector knob 4 clicks to the Heavy Duty cycle; the motor runs with the heater off. The buttons can now be tested. Press each button and all corresponding LEDs should flash; otherwise the button is stuck or a faulty. Unstuck the key and perform the key test again; replace the control board if the problem is not resolved.
Access to the control board requires the removal of the top panel and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the two screws attaching the top panel to the rear of the dryer then slide the panel rearward and lift it off the dryer.
Remove the four screws, two on each side, securing the console to the front panel then flip the console forward. Disconnect the wires from the control board and lift the console off.
Remove the five screws mounting the control board to the console and lift the control off. Remove the control board's rear cover by releasing the two locking tabs the flip the cover off the control board. Try to unstuck the faulty key and reassemble the dryer in reverse of the disassembly steps
Posted on Apr 27, 2010
What does area Error code E-05 mean on a Frigidaire front load dryer model # AEQ6000ES2
model aeq6000es2: the "e05" error code normally indicates that control board may need to be replaced or a stuck relay on the control panel. you can reset the unit by unplugging the dryer power cord for 5 minutes and then reapplying the power. if the problem persists then the control board or the control panel may need to be at fault.
Good Luck & All The Best, Justin McCartney
Dec 26, 2015 | Frigidaire Dryers
E68 ERROR CODE FRIGIDAIRE DRYER MODEL NO GLEQ2152EE0. CAN YOU DIRECT ME TO A SPECIFIC PART NUMBER?
E68 for this model number says in manual that this is for a "button stuck" or held down for more than 30 seconds
ck all your buttons for one that just doesn't "feel right" when its pressed , this one will be your problem
Oct 29, 2015 | Frigidaire Dryers
What does code E68 mean?
Hello Erik;
My name is Peter. I am a retired field service appliance technician.
The code E68 appears when one of the buttons on the keypad is stuck in the down position. This is a common error with several different Frigidaire dryer models and tends to occur when the dryer is five or more years old. You may be able to un-stick the offending key manually. If not, you will need to replace the entire keypad.
Dec 08, 2014 | Frigidaire Dryers
Why can't I get my new control board for my Frigidaire affinity dryer to work?
Hey tim bryant, thanks for your post!
I understand that you have installed a new board inside of your Frigidaire dryer, AEQ6000ES2, and on the new board the lights blink. I would recommend a reset on your appliance which can be done by disconnecting the power to it for roughly ten minutes. If that step does not correct the issue I would seek professional assistance for the repair of your dryer. I hope that is helpful. -Matt
Aug 13, 2014 | Frigidaire AEQ6000ES Electric Dryer
Aeq6000es2 fridgidaire dryer
May be a bad safety thermostat. Or, the thermostat may be working as it is supposed to, but you have excess heat in the dryer drum. Check for lint buildup.
Dec 13, 2013 | Dryers
MI SECADORA ES FRIGIDAIRE AFFINITY MODELO AEQ6000ES2 Y ME DA ERROR E68
confirma que sea realmente el error del boton atorado y si todo esta bien agrega un resistor de pull down al micro eso me funciono en una secadora que arregle
Apr 24, 2012 | Frigidaire Affinity ATF7000ES Front Load...
Was receiving E68 code on Frigidaire GLEQ2152ES1, replaced circuit board and am still receiving the e68 error code. What else will cause this error?
Hi yoyosam66...
Your e68 error code means:
Please take time to rate me
E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel. Solution:
Press buttons lightly and release.
Disengage button.
Aug 17, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire affinity dryer problem
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
Mar 29, 2009 | Frigidaire AEQ6000ES Electric Dryer
Mar 23, 2009 | Frigidaire Electric Dryer
Frigidaire Affinity AEQ6000WH Dryer Logo
213 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
