Question about Cell Phones
My screen is all blank and only has its back lights flashing and i dont know what may of caused that as it was jus in my coat pocket
  • 156 Answers
Take the battery out and put it back in and turn it back on. See if that helps.
Posted on May 03, 2008
Red light flashes blank screen
I have the same problem on 2 of my IP's - did you manage to sort it out?
Mar 27, 2013 | Saitek Pro Flight Instrument Panel...
My LG phone screen will not react to touch
When a phone screen is blank or has a white screen, etc, there are three things that could be the cause;
1. Bad/defective screen and the solution is screen replacement. (In your case, your screen might be failing).
2. Software/Virus problem and solution is to flash the phone
3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
Conclusion
Disassemble your phone and check the screen part in order to verify from the above which is actually the cause of the problem.
Please let me know if you need anymore assistance.
Good luck.
Jan 12, 2012 | LG GT540 Cell Phone
Blank screen
ummmm jus take the battery out or reset the phone
Feb 14, 2009 | Pantech Matrix Cell Phone
PS3 Quit
Alot of the playstation 3 systems are having problems overheating. this would be the cause of the system shutting off. not to much u can do unless u know how to replace the fan or if you bought the warranty. other then that you would have to take it to get fixed or buy a new one. hope this helps sorry if it dont
Nov 24, 2008 | Sony Playstation 3 (PS3) Console
Screen is blank
Try the reset button on the back of the unit.
Also try cleaning the contacts on the games. Push back the sleeve on the game and clean good with alcohol. If this doesn't do it, unplug it, and clean the contacts inside the unit with a qtip.
Hope this helps!
Nov 07, 2008 | Vtech V.Smile Pocket
Sony ericsson w850i blank screen
I am having the same problem with my w850i, poweres up but nothing more than a blank screen? Any suggestions?
Jan 20, 2008 | Sony Ericsson W850i Cellular Phone
No lit up screen or music
Even I had same problem. When showed it to technical person, he told me that battery has fused off due to water.
Oct 26, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Blank scren
That because your PPC don' have a CMOS. Solution is a Jtag flashing.
Jun 30, 2007 | Mitac Mio 168 Pocket PC
Cell Phones Logo
51 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
