Question about Acer Computers & Internet
My monitor gets off after 5 second when if swich off and switch on it then it comes back for 5 second and again same please solve this.
  • 105 Answers
Worn out capacitors in the power supply is most often the cause.
Monitor Mike
Posted on Aug 21, 2010
Monitor backlight problem (Dell S2409W)
pa_ma_fi, Have you figured out how to do the flashlight test on you monitor when it's lcd panel turns black or blank n black. No, CCFL back-lit lcd monitors require lots of things to be working all together at once to light up the CCFL tubes. The new style curlie-Q screw-in, energy efficient CFL light bulbs are of the same similar technology and use an "electronic-ballast" circuit to "light-up" the lamp! You will need to check to see if pc is working perfectly with old monitor that you know is good. You should do some free reading here at fixya in my and other fixya ccfl back-lit lcd technicians profiles. ou will also need to visit YOUTUBE for "LCD monitor disassembly" and "LCD monitor repair" videos. May need printed circuit board "switch-mode-power-supply/ ccfl inverter supply " to be repaired If pc software/firmware has been determined not to be causing this on/off/on/off symptom.
12fixlouie
Apr 29, 2010 | Computers & Internet
Dell E152FP monitor after startup or coming back from standby the screen will show up and 5 seconds later it disappears. I turn off the monitor and turn it back on. The image comes back again but it...
Hello
Probably the monitor. LCD monitors use electrolytic capactors which change value with heat. The power board in yours probably has 6 to 8 caps whic need replacement. Take it to a reputable repair person or check out my websit.
Thanks
Jan 07, 2010 | Dell E153FP 15" LCD Monitor
Unwantred announcments in the center of the screen
This problem comes from the control switches on the front panel. I had the same problem and fixed it by opening the monitor (unscrew 3 screws on the back side, remove plastic shape of the stand, unscrew 5 screws of the stand and open the back; unscrew the 2 screws of the button switch panel). Now inject contact spray on every switch button. If the problem remains you may have to replace the button swithces. Thats all!
Oct 12, 2009 | Philips 190V6FB 19" LCD Monitor
VX 910. Goes to black every 10 to 15 seconds then comes back on after 3 to 5 seconds With ''analog'' displayed in the lower right corner. Happens when connected to 2 different computers.
hi my lcd AL1916 acer monitor keeps going black or loosing signal after 2 or 3 sec. i press the moon on my keyboard 2 times it comes on then off again please help
Aug 11, 2009 | ViewSonic VG930m LCD Monitor
The screen goes blank after 5 seconds
Make sure you have the correct drivers install for you video card. Also, check to make sure your resolution is not set to high for you video card. To get to resolution; right click on Desktop > click Properties > press Settings Tab, from there you can move the slider to change your screen resolution (try different resolutions until it doesn't shut off anymore).
Let me know.
Jul 09, 2009 | ViewSonic VG900b 19" LCD Monitor
I want the setup software that runs the phone for k 750i
Try doing a master reset or back to factory settings. It would delete all the data so take a back up. If it does not work, it has to be a hardware failure, get the phone serviced.
Jan 27, 2009 | Sony Ericsson K750i Cellular Phone
Xerox XA7
ccfl tube is destroyed or fuse on inverter board
Sep 01, 2008 | Xerox XA7-192i 19" LCD Monitor
LCD Benq FP937s+
This is an Inverter related issue on the Inverter board.
Feb 23, 2008 | Relisys RLT1720 17" LCD Monitor
Relisys tl 766 monitor
ok i think i know how to get rid of it now, i did an ATX reset on it and it does go away HOWEVER as soon as you push the menu button again it comes back.
ATX Reset: unplug the main power lead then hold down the power button on the front of the monitor for about 10 seconds, plug the mains lead back in and then switch the monitor on.
Jan 15, 2008 | Relisys TL 766 Monitor
Samtron 56V monitor
Even i was also having the same problem. We can unlock the control lock by holding the menu button for 10-20 seconds.... But now my problem is the message "Controls locked/" appears continuously. Screen width also reduced. If anyone know the solution for this please help. thanks in advance.
Surya
Oct 16, 2007 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
