Question about Targus Wireless Mini Optical Mouse
I have an Dell Inspiron laptop and i just bought this new mouse that is driving me crazy... Targus... \r\n I did everything it said on the manual, when i put the USB in the blue light blinks only once and the mouse shows no signs of life at all,,, my computer cannot install the device. Are they not compatable? My computer/windows and the mouse? i can't belive this small mouse would cause me so much trouble...
5 Suggested Answers
Jastababe
  • 117 Answers
SOURCE: Targus Wireless Laser Rechargeable Notebook Mouse problem
The mouse worked initially....have you tried doing a system restore back to a few weeks ago to see if that solves the problem..
With Vista and so many of it's incompatibility issue's...you maybe have downloaded something and it corrupted your software for that mouse...
Here is the url with vista drivers. Redownload the drivers and install...see if this helps
http://www.targus.com/us/support_downloads.asp
Posted on Feb 25, 2008
  • 9 Answers
SOURCE: Targus PAWM001 Mouse - How to connect it to my laptop
Yeah, I was kind of confused about this too. Apparently, on the base of the mouse, there is a red reset button. Press that, while simultaneously pressing the black reset button on the base of the charger. The laser light should becomes steady after a moment, indicating that the mouse is in sync with the laptop. If the laser is blinking, however, then the mouse is attempting to become synced. You may have to press the reset button multiple times. Hope this helps.
Posted on Aug 07, 2008
  • 4 Answers
SOURCE: How do I install the battery on a Targus PAWM004 wireless mouse
yo dude just slide the silver cover back its tight but does come off, instructions available on their website, by the way you dont need a driver for xp will pnp
Posted on Jun 10, 2009
pumpkinman
  • 1147 Answers
SOURCE: Targus Bluetooth Laser Mouse Rechargeable Battery Trouble
check batterys to make sure there placed in mouse properly.try other usb ports.Batterys may be bad from factory.try some other rechargeables in it.if you have a charger for rechargeable batterys place the batterys in that and see if they charge.if they do then your pc is not charging them correctly/
Posted on Jun 11, 2009
Dell inspiron 1300 laptop mouse eratic
just uninstall old driver and then you should install a new and updated touchpad driver in your system.
then restart your system. its a software issue.
for new driver go to dell.com at drivers and download.
okay
Apr 26, 2010 | Dell Inspiron 1300 Notebook
I just bought a new mouse for my laptop. It is a Targus Kaleidoscope Optical Mouse. For my HP Pavilion dv2700, I plugged it in and it will not work,it did install itself several times.Everytime I plugged...
First thing you need to do is to know that the USB ports of your laptop is really working. Insert another usb devices or storage such a flash disk. If the flash disk being inserted is not recognized by the system then the usb port you had inserted is malfunctioning or it is defective. But if the other usb devices like the flash disk is working then your new bought mouse is defective. Try to plug the usb mouse to the other ports available in your laptop.
Oct 29, 2009 | Targus Kaleidoscope Optical Retractable...
I owned a Dell(inspiron 1420) touchpad is not functioning at all!
Try going into Control Panel, Mouse, Tapping and turn it all off.
Set the sensitivity to as low as you can.
The key combination should be Fn & F9, look for a button on the function row that has a finger pointing at a box :)
Jul 30, 2009 | Dell Inspiron 1420 Notebook
Problem in os
Try starting explorer by going to file\new task (run..) and typing explorer.
If it doesnt work, just type msconfig on the same box and go to startup tab, leaving everything unmarked, just reboot your pc and problem should be solved
Jun 21, 2009 | Dell Inspiron 1420 Laptop
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Deactivation of mouse pad
Check your user manual. Usually, "Fn" key in combination with one of the functional keys will disable touchpad.
Mar 13, 2009 | Dell Inspiron 1525 Notebook
I have the Targus wireless mouse amw10us. It just
Mine did the same thing, so I took it apart. The flip hinge in the receiver wore through the wire running between the plug & the little board inside. I'm shopping for a new mouse.
Mar 11, 2009 | Targus PAWM001U Mouse
Model PAKP003 Won't work
You will need to reset the id code on the the receiver as well as the device. Here is the direct link to the manual with the detailed instructions (please, cut and paste to your browser):
http://www.targus.com/us/Downloads/PAKP003_UG.pdf
The Targus link to the product itself:
http://www.targus.com/us/drivers_manuals.asp?SKU=PAKP003U
Good luck
Feb 03, 2009 | Targus PAWM001U Mouse
Bluetooth Mouse
Try new batteries. If this does not work then try reinstalling the blue tooth drivers. If this does not work then replace the mouse. if you purchased it from Dell, it might be still under warranty.
Aug 10, 2007 | Targus AMB03US
Targus Wireless Mini Optical Mouse Logo
Top Targus Computers & Internet Experts
dhnguyen
Josh Whitehead
Josh Whitehead
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
