Question about GE WSXH208A Front Load Washer
New GE frontload washer does not fill with water, just hums
    Champion:
  • 245 Answers
Check your hoses for obstructions, but it sounds like your inlet valve is bad.
Posted on Aug 20, 2010
  • bournie58 Aug 21, 2010
    What and where is the inlet valve
  • lancaster5
    lancaster5 Aug 27, 2010
    IT IS THE PLASTIC PIECE THAT YOUR HOSES CONNECT TO.
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
My washer initial had a rinse cycle problem where no rinsing occur after washing, now it spreads to the wash cycle where it is pausing at the this cycle, need urgent advice
The problem is you are not getting cold water fill. (rinse is all cold water fill) Check to see if the inlet screen is plugged by turning valve off that supplies cold to the hose attached to the machine, then removing the hose at the machine and checking the filter inside the water valve where the hose was just removed from. If screen is not blocked, replace water valve.
Nov 20, 2011 | GE Washing Machines
Washer seems to not cycle or take in any water. Is there a reset switch or button
If you hear a hum check the cold water inlet screen . If no hum check the valve or try hot water . If works replace fill valve.
Nov 04, 2010 | GE WBSR3140DW Top Load Washer
Do I need 2" drain for frontload washer?
not nessarily if your draining system can handle a non-efficent washer the old top load style drain 42.3 gal of water evey time it fills and for a complete cyc on the h-3 washer only 14 for a complete cyc. When the unit is in the high spin all of the water is already drained and what little water is spun out of the clothing in nothitng to worry about
Aug 26, 2009 | Electrolux EIFLW55HIW Front Load Washer...
WHDSR315DDWW, Fills then just sits there and hums.
Push down on the agitator. You may have to hold the activating button in with the lid up so you can do this. Press down firmly on the agitator and it should start rotating. If it does, you need to have it replaced. If it doesn't, then let the store know and they should take care of it. You should not put any money into since it is new. Anything you do from this point will cost you some money to fix.
Feb 06, 2009 | GE WBSR3140DW Top Load Washer
Washer does nothing
ok we need to check a couple of things...take the fill hose off ,,,now put unit in a cycle and make it call for water...is the inlet vavle humming or vibrating....will your there look in vavle and see if your inlet vavle screens are clogged...does the unit have water in it,,if so it wont fill with water in it...keep me posted onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer won't fill with hot water
If you hear a humming, the coil on the water valve is probably OK. On warm, you are getting cold fill only. (hot + cold = warm) Take the hot water supply hose off the machine and look inside where the hose attached to the washer. There should be a screen inside. Remove it and clean it out. Also, check both ends of the supply hose, as sometimes you will find a screened washer in there too.
Oct 26, 2008 | GE WBSE2090A Top Load Washer
Frontload Washer won't spin or wash.
check the door lock/ latch mechanism
Sep 17, 2007 | GE WSXH208A Front Load Washer
GE washer repair
to start I will never again buy another GE product for as long as I live. I am having the same problem w/my GE washing machine. I have to manually turn the dial to make it go thru its cycles. the problem is the 'timer' must be replaced. good luck trying to get their customer service dept to help you with anything. they are useless.
May 06, 2007 | GE WDSR2080D Top Load Washer
GE WSXH208A Front Load Washer Logo
67 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
