Question about IBM 6400 Matrix Printer
Printer is advancing 4 extra pages between printing files.
    Problem Solver:
  • 8 Answers
Most likey you have an incorrect emulation setting on the host side. What is the current config on the printer?
jack
Posted on Oct 01, 2010
2 Suggested Answers
SOURCE: extra page gets printed showing file details everytime i print a file
in word, go to:
tools
options
print
include with document
uncheck document properties
Posted on Jul 08, 2009
Why does my printer put through an extra blank page after printing?
Yout have to disable SEPARATOR PAGE under printer properties
1. Select Start.
2. Select Settings.
3. Select Printers and Faxes.
4. Highlight the appropriate HP LaserJet printer icon.
5. Right-click on the highlighted printer icon and select Properties from the Advanced tab.
6. In the Advanced tab, select the Separator Page button.
7. Delete the location for the separator page.
8. Select OK.
Feb 13, 2011 | Epson Office Equipment & Supplies
Whenever i try to print a pdf file longer than one page from adobe reader, my e-studio4511 will only print the first page, followed by a second blank page, and then a final page with the following error...
Send the font information for each page in the PDF file when you print.
For Adobe Acrobat Professional 9:
1. Choose File > Print.
2. Click on Advanced.
3. Choose Postcript Options.
4. Under Font and Resource Policy, select Send for Each Page.
In Adobe Reader 9: try this 1
3. Under Font and Resource Policy, select Send for Each Page.
may or may not work try it
Hopefully this will be helpful to you all
Nov 20, 2010 | Toshiba e-STUDIO 4511 Printer
Won't print from Web page
make sure your firewall settings in the exceptions or advanced settings window lists your printer and it is selected. If it is not listed browse your programs using the add program at the bottom of the page and select your printer device program. Also, in your device settings for the device you are using to connect to the Internet is configured to allow your printer and files shared option enabled.
Apr 03, 2010 | Brother Multi-Function Center MFC-240C...
Does the Lexmark X9575 print automaticly 2 sided with no manual feed. I have a 15 page document doulbe sided. How do I print this without babysitting the printer. Thank you
Your model supports automatic duplex printing using letter and A4 sizes ONLY. If you want to print two-sided documents on another type or size of paper, use the manual duplexing method.
1) With a document open, click "File" > "Print..."
2) Click "Properties" or "Preferences" or "Options" or "Setup" depending on your system
3) Click the "Advanced" tab
4) From the "2-Sided Printing" area, select the 2-Sided Printing option and then select either the "Sideflip" or "Topflip" option (sideflip is the setting most often used)
5) From the drop-down box, select Automatic.
6) You will see an "Extend dry time" option, which allows extra drying time between sides when you are printing on both sides of the paper. The Automatic 2-Sided Printing option affords enough time for the ink to dry on supported paper types in average air humidity. Under conditions of high humidity, or if the normal drying time does not allow the ink to dry completely, you should select Extend dry time.
7) Click <OK> to close any printer software dialogs that are open. This will take you back to the General Print screen.
8) Click "Print"
Note: To return to single-sided printing, return to the Advanced tab. From the 2-Sided Printing area, clear the 2-Sided Printing check box.
Jan 14, 2010 | Lexmark X9575 InkJet Printer
Extra page with every print
1. From the menu, goto Printers and Faxes. 2. Right-click your printer model and select properties. 3. In the dialog, click Advanced tab. 4. Click separator page button below. 5. You may have give a blank page as a separator page. Remove it.
Jul 31, 2009 | Office Equipment & Supplies
OKI Microline 591 prints extra page of paper everytime
There is a setting on most printers to print a separator page at the end of print jobs. You can check the settings of your printer by going to the control panel and clicking on printers. Select your printer, right click and go into properties. The setting for this is usually located in the advanced settings. See if the printer is set up to print a separator page, if it is, uncheck it, press apply/ok button and close out printer window.
Jul 10, 2009 | OKI MICROLINE 591 Matrix Printer
Extra page gets printed showing file details everytime i print a file
in word, go to:
tools
options
print
May 30, 2009 | HP Officejet 5610 All-In-One InkJet...
Every time I print, the printer feeds an extra blank page after every printed page. How do I get it to stop this?
I have an HP D7360 Photosmart that has been doing the exact same thing. This has been driving me crazy, especially when I have to print a lot of pictures at once or a long report.
After uninstalling and reinstalling the printer a dozen times, installing every possible driver I could find for it, and even swapping out the USB cable (who knows...stranger things have been the cause of problems!!), I just found the fix for this.
Go to the Properties page of the printer (for mine, I open the printer, click "Printer", then select "Properties"), then go to the Advanced tab. At the bottom are a few checkboxes, one of them being "Enable advanced printing features". I unchecked this and do not have the problem with the extra page.
I am not really sure, at this point, what else may be turned off, but just printed a test page and WOOOHOO...no more blank page came out right after it.
Hope this helps you and that the "advanced printing features" aren't something that negatively impacts your and my ability to print quality pictures and documents.
I love this printer otherwise. Amazing picture quality!!!
Apr 09, 2009 | HP Photosmart D7460 Printer
When converting Publisher file to PDF it shows 4 on one page
Convert file to PDF free online websites has many disadvantage only one file converted at a time, not confidential, relied on network.The best way is Shareware desktop PDFconverter,Advanced pdf converter 6.0 may be your preference as it is very good in preserving the formatting. It also allow us to convert a lot files at the same time.
Feb 02, 2009 | HP LaserJet 3100se Printer
My hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Sep 23, 2008 | HP LaserJet 4 plus Printer
IBM 6400 Matrix Printer Logo
69 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
