Question about HP LaserJet 3055 All-In-One Printer
All in one Hp3055
Hi
we have all in one 3055 printer
when ever i reecive fax my internet network get disconected
    President:
  • 2,712 Answers
It is probably because you cant use the internet and phone on the same line. Ask your internet provider to provide you a broadband line where you can both make/recieve calls and use the internet at same time.
If you are from India, I believe there is a company called Airtel that provides this service.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 03, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    IrishDruid
HP 3055 All In One laserjet prints all black pages
Odds are that you have a bad toner cartridge; especially common when using remanufactured cartridges. (Staples, Corporate Express, etc.) Replace your cartridge with an OEM HP cartridge and you should be OK.
Feb 22, 2010 | HP LaserJet 3055 All-In-One Printer
How do i change the number of rings before fax
Menu/Fax Setup/Enter/Fax Receive Set up/Enter/Rings to Answer
Feb 03, 2010 | HP LaserJet 3055 All-In-One Printer
Need help re-installing my hp3055 printer on my vista computer
Click Here for the correct driver for the 3055 running on Vista, I recommend the plug and play driver with pcl 5, the pcl 6 has a tendancy to be more buggy...
Dec 15, 2009 | HP LaserJet 3055 All-In-One Printer
Fax issue with HP Laserjet 3055
Hi. The fax-module in lj 3055 needs a 100% analog dial tone. You might get it working on a internet-phone-line, but HP garantees nothing because there are so many internet-phone-providers, and all of them operates with different specs and line-quality. You might try to lower the baud rate, turn off JBIG compession and error-correction. If the problem still remains, you need to replace your phone-line to a 100% analog line. Not any internet or ISDN/adapter-stuff. You should test your fax on any analog line at a friends house, just to make sure the fax i working anway.
Jul 27, 2009 | HP LaserJet 3050 Printer
Unable to print to HP3055 connected through network. Has orange light on the back. All of the lights on netgear switch going crazy, but go normal if I unplug HP3055. Worked perfectly until yesterday when...
check the cable with cable tester ensure good or try with another cable
there is an ip address setting pls check it
if the printer in warranty period try with hp
Jul 15, 2009 | HP LaserJet 3055 All-In-One Printer
Can't read fax that is being sent
tell those people to wear their eye glasses...hahaha..
May 09, 2009 | HP LaserJet 3055 All-In-One Printer
Someone is faxing me iam getting commerror283 how to fix it
This error typically indicates a problem with the line. Sometimes it's caused by noise (like from DSL on the same line, or alarm systems/home automation systems that use the same line).
Try other devices on the line, like a standard phone or modem and see if you can detect the noise issues. You may need to order a separate POTS line for faxing, especially if you are using the aforementioned services or VoIP systems.
Hope this helps!
Mar 29, 2009 | HP LaserJet 3055 All-In-One Printer
How can send fax thru internet
You can not send faxes thru the internet unless you use a service such as E-Fax.
Faxes usually are sent via phone lines only.
If you are asking anything else then you have to be more precise in your question as it is not exactly clear as to what you are asking!
Good Luck!
Rich Lilja
Dec 04, 2008 | HP LaserJet 3055 All-In-One Printer
Printer can't send or receive faxes
Same problem here - I got it work:
- Error Correction: off
- V34: off
(both Menu -> Fax-Setup - All Faxes)
- detect-dial-tone: off
(Menu -> Fax Setup - Fax Send setup - detect dial tone)
:-) Stefan
Aug 30, 2008 | HP LaserJet 3055 All-In-One Printer
HP 3055 LASER JET ALLIN ONE
Cheers!
IrishDruid
May 03, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
166 people viewed this question
Seeker5211
Seeker5211
