Question about JVC Televison & Video
I have a JVC I'Art Pro 42" HDTV ready projection TV. Recently, it started intermittently flickering (Picture would go from correct to negative looking). Now this video circuit problem is negative picture looking all the time. The tuner works, all inputs work, sound is fine, and all menus are fine, but he end result is the same no matter what the input. You can barely make out what the picture is. If I go to the convergence utility, I can see that all guns are working. Question is, what's the problem, and can I get a troubleshooting manual with circuit diagrams?
  • sgwyer7354 Aug 21, 2010
    Hello Ginko,
    If what you say is the case, why do I see all three guns (very solid) on the convergence screen?
    Skip
    Sorry for the duplicate input, but why would I see all three gun colors on the convergence screen if one of the CRTs was intermittent or out, due to a high voltage disconnection or a faulty component?
    Skip
  • JVC Master
  • 19,396 Answers
Hi.
It is not video circuits on main controller or convergence.
This TV uses a CRS system with three CRT tube lamps, red, green and blue.
The problem is likely one or more of the CRT individual high voltage PSUs failing intermittently, if problem is associated to vibration, then it is a cold solder joint , otherwise it is a faulty component.
Posted on Aug 20, 2010
I have older projection JVC i Art pro Tv, it is projecting a double image and i need to know how to fix it easily
if model number is correct the two stk-392-110 chips need to be replaced.
Can you solder?
see photos of board in your set and I can tell you how to get it out and what is needed.
Before you rate this information let me know if you can solder etc.
Jul 25, 2011 | JVC AV-56WP74 56" Rear Projection...
I HAVE A 48 JVC I ART PRO AND IT SEEING DOBLE.
Thats caused by failed convergence ICs and resistors. You can get the JVC AV48wp74 -AV65WP74 cnvergence repair kit from <A href="http://www.tvrepairworld.com">www.tvrepairworld.com</A> the kit contains the ICs , Resistoirs and the cd with repair instructions.
Aug 25, 2010 | JVC AV-56WP74 56" Rear Projection...
Jvc i art pro doe not turn on
The clicking sound is the TV trying to restart itself. It generally attempts this several times before giving up. The blinking code indicates the type of error (error codes are documented in the manual for the TV). The most likely cause is a burned out bulb, but could be something else.
If it is a bulb, it is usually replaceable without a service technician, and at a cost far less than $450.
Good luck.
Jun 18, 2009 | JVC AV-56WP74 56" Rear Projection...
Tv turns off by it self
Ours 60" (60P8342) turns off after a short period of time also. My husband researched it online. The cheap solution he was told to try is to unplug the TV (or plug into power strip and switch off) when you are done watching it. A computer board inside over heats and it's a protection mechanism for it to turn off. Otherwise, it's over $100 to fix the computer board.
May 29, 2008 | Philips 60P8342 60" Rear Projection...
JVC HDTV Pictrure Distortion
Your TV needs to be calibrated. Rear projection TVs are very sensitive to movement. They have 3 color canons that need to be precisely aligned so that the colors overlay each other. They are like three projectors all aimed at the same screen.
If you were to enter the User Menu on the TV, you should find an alignment/calibration choice that will re-align the colors using some on-screen help.
If you are not able to resolve the situation on your own, a certified ISF Calibrationist should be called.
And, since you've bought this TV used, it should be cleaned by a professional (the canons, lenses, etc.)
Apr 07, 2008 | JVC PD-42WX84 42 in. HD-Ready Plasma...
This usually is heat related. Is the filter clean? The fan working? Otherwise there is most likly a "so called" cold solder joint...where the connection on a board is not positively made...often when it warms up the joint will 'open'..disconnect. This needs re-soldering.
Mar 29, 2008 | JVC AV-56WP74 56" Rear Projection...
Projection LCD flickers to black and white
If the S-video cable is not completely in it will do this. You need to remove and clean tips on S-video cable/ replace, this is your problem.
Mar 10, 2008 | JVC HD-52Z575 52" Rear Projection...
JVC I ART
You need to replace the convergence IC's. That is the most common issue with any CRT type projection TV.
Apr 06, 2007 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
148 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
