Question about Tivoli PAL Radio
The radio will only turn on if the power supply is plugged in. Once it is on, it will run of battery for hours. It will no long turn on with just the battery. Tivoli suggested some type of amp issue. Have you heard anything?
    Sergeant:
    Champion:
  • 387 Answers
Yes its possible <br /> the battery and the power supply have different connection on the main board, battery connector have a Diode that works like a valve when you connect the power supply it disconnect the battery <br /> I can fix this problem <br /> I am in NY - <a rel='nofollow' href="mailto:doron_c21@yahoo.com">doron_c21@yahoo.com</a>
Posted on Aug 25, 2010
Battery drain
no power to the dmi plug
Feb 08, 2014 | Infiniti G35 Cars & Trucks
I have an Darlac Electronic water timer DW253 but haver mislaid the instructions, where can I download a set?
I cannot find a manual for the Darlac DW253.
It appears the timer is set by moving each selector knob.
http://www.watermate.co.uk/secure/uploads/DW253%20(Small)%20new%20darlac%20pop.jpg
Knob on right is Run Time:
This is how many minutes timer will run each time.
Set run time from 1 minute to 120 minutes.
Knob on right also has ON-OFF override.
Knob on left is Frequency:
This is how frequently the timer will turn ON. Once per hour, once per each 2 hours ... once per 24 hours ... once per 72 hour ... once per week.
So set frequency to 48 and set run time to 20, then every 48 hours the water will turn on for 20 minutes.
To turn timer off, move right knob to OFF.
For continuous watering, turn same knob to ON.
This timer is battery-powered, probably 9 Volt, but maybe AA.
Battery carriage appears to be located on front below the function knobs.
Typically, water timer batteries last one season.
Timer can be connected to household spigot, or connected to any passive water supply for example rain barrel or tank.
Appears to have standard female hose thread on top, or possibly 1/2 pipe thread, and quick connection on bottom.
Plastic water timer exposed to freezing temperatures can crack. Drain water out of timer during cold weather.
Generally if water timer stops working: replace battery, clean battery terminals, and if functionality is not restored, then buy another timer.
Add a comment to fill out the missing details.
Aug 02, 2011 | Woods Inwall 24 Hour Programmable Timer
My Acer Aspire 6530-5753 laptop stopped charging the battery even though the power supply light was on--it's an aftermarket charger from Radio Shjack. The battery ran dead and it wouldn't run on...
This is not the motherboard. The batteries in laptops have electronic sensors in them. When they reach the end of life, they stop the computer from turning on. Once that happens it wont power on with the battery in or out. Batteries are not that expensive. Only about 25 dollars.
Mar 27, 2017 | Acer (ACERMOTHERBOARD)
My dell inspiration 910 has just played up. it was working perfectly before and i was using dell speakers and my ipod, ipod was removed, and left it still pluged in and charging and noticed the orange...
This sound as though the power supply adapter needs replacement.
If you can find a compatible power supply adapter perhaps you can charge you laptop.
A company call Batteries Plus may be able to help or Ebay may have you adapter power supply if you do a search.
You may also contact Dell for support on this issue.
Some Dell power supply fail due to overheating.
you may also want to check the power supply connector.
Apr 24, 2011 | Dell Inspiron Mini 10 Notebook
No power to the smartset
Sorry it took so long to give you a answer to your problem. You will have to try to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set with out power for about 3 hours to completely drain the stored current and voltage stored in the Clock/Radio's microprocessor. After you have let the Clock/Radio set for about 3 hours,You can then reinsert the internal battery and plug in in to the A/c power source. The Clock/Radios functions should return to normal. If they do not you will have to change the internal battery and let the Clock/Radio set with out any power for about 3 hours. Put in the new battery (CR2430) and again plug it in to the A/C power source. The Clock/Radio functions should return to normal. If you find you are still having a problem with the function of the Clock/Radio you can call the Emerson customer support. The telephone number for the Emerson customer support is 1-800-909-1240. call them between the hour of 8am-4:30pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance with the problem. I hope this information helps you solve the problem. Thank you for using FixYa and have a nice day!
Dec 03, 2008 | Emerson Smartset Clock Radio
Always running on batteries
You can still use your laptop even if you take out the battery and run on ac alone. You can also leave your battery in with the ac plugged in for 4 hours to charge it even if the laptop is off. Hope this helps. Thank you.
Sep 20, 2008 | Toshiba Satellite P35-S611 Notebook
Midland 79-290 won't power on
All the battery does is hold your presets...radio should run fine with no battery at all...just annoying when you turn if off and all presets are gone.
Sounds like your off-on switch may be gummed up from sitting too long.
Have no idea what you mean by "shorting out the faceplate", that really doesn't sound too good!
Sep 08, 2008 | Midland 79-290 120-Channels Base CB Radio
Can't turn radio off or get anything else to work
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
Feb 19, 2008 | Emerson Smartset Clock Radio
Milwaukee Job site radio
Questions:
1. Does the AC cord look ok? Not damaged?
2. Have you tried another AC outlet?
3. Does the AC cord unplug from the radio?
When you operate the radio from the AC power cord, the radio uses an internal power supply consisting of a step-down transformer, rectifier, and filter that converts the AC to DC to operate the radio.
When you run the radio off of batteries, it powers the radio directly. In some radios, when you plug the AC cord into the radio, it activates a switch that disconnects the battery voltage to the radio so that the batteries wont be damaged from the voltage created by the internal supply.
The radio can be powered by either the batteries or the internal supply. You don't want either supply affecting the other, so that is why a switch is sometimes used.
Since the radio works fine off of batteries, that would indicate that there is a problem with the internal power supply. This could be a blown fuse, bad transformer or bad rectifier diode.
Good Luck,
- Jim
Jan 24, 2008 | GE Superadio III AM/FM
Tivoli PAL Radio Logo
490 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Electro Med Services...
KC135Nav
Level 1 Expert
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
