Question about HP LaserJet 3055 All-In-One Printer
HP 3055 LASER JET ALLIN ONE
HI
WE HAVE HP3055 ALL IN ONE WHEN EVER I REECIVE FAX MY INTERNET NETWORK GOES CUT OFF CAN U SUGEEST ME Y
OTHER THINGS R OK
    President:
  • 2,712 Answers
It is probably because you cant use the internet and phone on the same line. Ask your internet provider to provide you a broadband line where you can both make/recieve calls and use the internet at same time.
If you are from India, I believe there is a company called Airtel that provides this service.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 03, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    IrishDruid
Can I do network scanning with hp laser jet 3055 printer
Yes you can print, fax & scan with HP Laser jet All-in-one through LAN port (wired or wireless). Un-install and re-Install driver and Check "Extended Capabilities" when prompted.
Feb 16, 2011 | HP LaserJet 3055 All-In-One Printer
How can I clear my fax memory hp laser jet 3055
Hello !
You can clear the memory by doing an NvRam or hard reset
a. Turn off the product.
b. Press and hold the Right arrow and Cancel buttons simultaneously.
c. Turn on the printer.
d. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
e. After a few minutes the printer should go back to the "ready mode"
May 14, 2010 | Canon L120 Fax Laser Printer
HP 3055 All In One laserjet prints all black pages
Odds are that you have a bad toner cartridge; especially common when using remanufactured cartridges. (Staples, Corporate Express, etc.) Replace your cartridge with an OEM HP cartridge and you should be OK.
Feb 22, 2010 | HP LaserJet 3055 All-In-One Printer
Unable to print to HP3055 connected through network. Has orange light on the back. All of the lights on netgear switch going crazy, but go normal if I unplug HP3055. Worked perfectly until yesterday when...
check the cable with cable tester ensure good or try with another cable
there is an ip address setting pls check it
if the printer in warranty period try with hp
Jul 15, 2009 | HP LaserJet 3055 All-In-One Printer
Cannot get HP 3055 scanner to work on vista home premium 64 bit
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=1140780&lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&taskId=135
Go there and try download the Drivers and Utility for the 64-bit Version of Vista. Pretty bad that HP's own website has the info you need, yet they say it won't work.
Jun 20, 2009 | HP LaserJet 3055 All-In-One Printer
How to connect the printer wireless
I don't think the HP 3055 has built in wireless capabilities. It does however have a built in 10/100 Base-T TCP/IP networking with 1 RJ-45 port, Hi-Speed USB 2.0 port, RJ-11 fax port, RJ-11 line-out telephone port. You should be able to connect directly into your hub or router and access the printer through a wireless router. You can get more information on set up at the link below.
http://h10010.www1.hp.com/wwpc/us/en/sm/WF06a/18972-18972-3328064-12004-3328082-1161389.html
May 31, 2009 | HP LaserJet 3055 All-In-One Printer
How can send fax thru internet
You can not send faxes thru the internet unless you use a service such as E-Fax.
Faxes usually are sent via phone lines only.
If you are asking anything else then you have to be more precise in your question as it is not exactly clear as to what you are asking!
Good Luck!
Rich Lilja
Dec 04, 2008 | HP LaserJet 3055 All-In-One Printer
HP laser jet 3055 not doing net work printing
Has a printer cartidge loaded but says that does not
Oct 17, 2008 | HP LaserJet 3055 All-In-One Printer
All in one Hp3055
Cheers!
IrishDruid
May 03, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
125 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
