Question about Mercury Health & Beauty
Hello, I have a Mercury Prism mobility scooter and after a mile it keeps beeping nine times and no matter what I've tried it won't start up again. After I've charged the battery for twelve hours it does the same thing again, goes for a mile, beeps nine times and will not work. I've tried everything. I've had it rewired twice and have even tried a new battery but the problem still persists. I have no clue to what the nine beeps means or what to do to make the scooter work again. Please help!!!
  • 118 Answers
SOURCE: New batteries, fully charged, still wont work
I have the book if you can figure a way to post you email without getting too much SPAM. Be sure the charger is un-plugged, and that the free wheel lever is engaged.
Posted on Nov 27, 2008
dromtonpa
  • 40 Answers
SOURCE: Pride "Celebrity XL Deluxe" 4-wheeled Mobiltiy Scooter
Sounds like your motor brake is out. Usually the discolor on the brake indicates it has overheated.
Posted on Apr 12, 2009
gewiz
  • 1263 Answers
SOURCE: pride mobility scooter. turn key on it keeps
Are you sure that it not in FREEWHELL mode, lever at the back, Regards
Posted on Jun 13, 2009
  • 175 Answers
SOURCE: The battery takes a charge, but will not power scooter
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
Posted on Jul 12, 2009
  • 17 Answers
SOURCE: the battery is fully charged but the scooter will not move.
Is it the small portable scooter? The one with the base that comes apart for transporting? Could it be a bad connection where it goes back together?
If it is the portable, try disconnecting the rear drive portion from the base and re-installing it so it clicks into place.
Posted on Sep 22, 2009
Will not run fault indicator flashes continually without pause
you can check to see if it is in free wheel at the rear of the scooter there shoulb be a lever make sure it is in the lock mode
Jul 20, 2014 | Mercury Prism Coloured Travel Mobility...
Pride elite traveler keeps cutting out 9 beeps
it could be the connection between the rear section and the front half. take back section off and see if connection has melted as I have repaired lots with this fault.
Dec 13, 2013 | Pride Mobility Products GoGo Elite...
Mercury prism mobility scooter
The distance a scooter will go depends on the size and weight of the load also. If two people are different height ( wind drag ) and different weight or there is a difference in load you are carrying then there will be a difference in how long the charge will last. Since you switched the batteries with no change then this could be the case. There are other factors that can cause this as well , such as brake dragging, wheel bearings going out, low tire pressure if your tires are air, if 4 wheel scoters then wheel alignment. hope that helps.
Jun 06, 2013 | Health & Beauty
Mobility scooter
Check the freewheel lever is not engaged.
Jun 03, 2017 | Health & Beauty
Mobility scooter keeps beeping
Go to the scooters website and download the service manual. It will tell you why it beeps and how to fix it. Bypassing the brake is unsafe and dangerous as the brake will not stop the scooter or hold it on an incline. That may have been your original problem (the brake)
May 10, 2017 | Cars & Trucks
While driving scooter rear will sometimes shutter for short period of time and remain moving. Sometimes it will stop on its own. Beep code of nine (9). I find if I lift battery pack and put back in place...
Yep There are 3 possible problems 1. Make sure that the key is out of the lock before reinstalling the battery pack. 2. The controller is overheating. Let it rest 10-15 minutes to cool down if it happens again and 3. I think you are having a brake problem where the brake is not fully disengaging from the motor and causing excess drag on the motor.
You can remove the brake from the rear of the motor being careful not to break or pull the wires going to the brake. Tie the brake up away from the motor keeping the wires intact. Try driving the scooter and see if it still shutters. If it doesn't then you can use it like that but you will have no brake and if you use ramps it is dangerous. You can carefully remove the brake pad and give it a good cleaning along with the face of the motor where the brake pad rubs. Then reinstall all the parts and try your scooter again. The shuttering should stop and to excess overload of the motor should stop too. You could replace the brake by contacting Pride Mobility @1-800-800-8586 and talk with tech support to find out if you can just replace the brake assembly. Hope this helps you
Oct 01, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Health & Beauty Logo
66 people viewed this question
Top Mercury Health & Beauty Experts
D. E. Hev
Lawrence Oravetz
Are you a Mercury Health and Beauty Expert? Answer questions, earn points and help others
