Question about Maytag Washing Machines
Our maytag washer makes a schrill sound when agitating and spining. I have the front off. It is belt driven nothing appears frozen, could the belt be slipping? model # MAV7700AWW
    Champion:
  • 245 Answers
Your transmission is going bad, look to see if there is oil on the inside of the cabinet walls.
Posted on Aug 20, 2010
Maytag centennial washer will not agitate
If it is belt driven the belt might be broken. It is underneath the washer
Apr 03, 2014 | Maytag Centennial Top Load Washer
Won't spin, agitator won't turn. Repair it or just get a new one? 8 yrs old.
Hello,if your washer won't spin first check to see if the motor is running, then proceed as follow.
1. If the motor is running, your washer probably has a frozen pump pulley or broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely or if it is frozen or stiff replace it.
If the pump belt is broken or looks quite warm, replace it but be sure to check the pump pulley before you change the belt.
AGITATOR: If the agitator won't turn, the likely cause is "Lid Switch" because if the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thanks
Jun 09, 2010 | Maytag SAV2655A Top Load Washer
Maytag washer will not fill with water. It does agitate and spin
My May Tag model LA 882 washing machine is not draining water. the water remains even after spining and the cycles are longer durations. any advise ?
Mar 31, 2009 | Maytag Washing Machines
Washer won't agitate
open the back check the belt also see if u can turn it by hand. if that doesn't help call repair man .
Jan 11, 2009 | Maytag Neptune MAH6500A Front Load Washer
Washing machine won't agitate
it sounds like the transmission is shot. Not knowing the cost of parts if you can replace the transmission yourself then yes it could be worth fixing however if you can't do the job yourself adding cost of parts and labor it may not be worth it
Jan 01, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Doesnot spin or agitate.
if you have the front panel off and you can see the motor is spinning the belt is turning then your transmission has failed.waring keep hands clear of all moving parts! transmission pn wh38x10002 for around $185 if mtr is not moving pn wh49x10040 for about $240 depending on what you need and how old your washer is it might be time for a new one
Dec 13, 2008 | Washing Machines
Maytag washer sqealing
hi Garrett,
sounds like a frozen gearbox. check the pulley that is being driven by the motor or by the secondary belt that you are saying. it could be the gear box broke and would not spin. another thing to look at once the gearbox is down is the brake mechanism. it could have broke down and would not run because the brake is not yet released.
tnx 4 using fixya,
drcool
Nov 14, 2008 | Maytag MAV6300 Top Load Washer
Kenmore washer won't spin
This should help you get to the coupler between the motor and the trans.
Good Luck
Oct 11, 2008 | Kenmore 24032\24036 Top Load Washer
Pav2200 model
Sounds like a transmission problem. It's locked in agitation mode. When it is in agitation mode you can't turn the drum or move the agitator. I'd check that out.
Jan 17, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
77 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
