Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Hi there... suddenly my USB Seagate Barracuda 7200.11 External Harddrive is not working any more... unknown device is the message of windows (WINDOWS 7)! The mistake code is Nr. 43! Could you please help me because I have got a lot of files on the drive...
    Brigadier General:
  • 10,406 Answers
Check that the power-brick is supplying power to the disk-drive.
Check that the "data" cable between the computer and the device is tightly connected, at both ends. Try a different cable.
Disassemble the casing, and remove the disk-drive, and connect it as a "slave" disk-drive in some desktop computer. If it is detected, then it is the USB-to-disk-drive adapter, inside the case, which has failed.
Search online for a professional "data recovery service".
For a large fee, they can repair your disk-drive, just long-enough to copy all your files to a working disk-drive.
Posted on Aug 20, 2010
Using Seagate Goflex Hard-drive 750 GB, upgraded Windows 7 to Windows 10. get message Seagate harddrive not supported on Windows 10. Is there a solution to fix this? Russ
Will My Hard Drive Work With Windows 10? - PC Magazine
www.pcmag.com > ... > Windows 10
PC MagazineJul 29, 2015 - Some drive manufacturers have gone through the Windows 10certification process, ... Seagate products are NOT compatible with Windows 10.
Seagate GoFlex not compatible with Windows 10 - Microsoft Community
answers.microsoft.com/.../windows/.../windows_10-hardware/seagate...n...
Aug 4, 2015 - Since, the Seagate Dashboard is not compatible with Windows 10, let's try ... 10 with my Seagate FreeAgent Go Flex Home 1T external hard drive - model ... Windows 10 Backup Not recognizing Seagate Desk External Drive ...
Aug 18, 2015
Windows 10 Install- Now Seagate External USB 3TB HardDrive ...
Aug 13, 2015
Seagate 3TB external hard disk not working with Windows 8 ...
Jan 26, 2013
More results from answers.microsoft.com
Dec 16, 2015 | Seagate Computers & Internet
Windows xp will not recognise the seagate freeagent desktop drive
Assuming you have tried other usb ports and had no change,remove the usb connection, then go back into device manager and select the usb controller, right click and select delete as this will erase any input driver the usb port recognises. Restart the pc and then the controller should be reinstalled automatically as it sounds as though the controller has become corrupt for some reason. Go back into device manager and check there are no exclamation marks, reconnect the drive and see if it's recognised.
Oct 05, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My Seagate 1TB FreeAgent external Harddrive is not working on my laptop which is running on XP. In Manage Hardware section this device is shoing as unknown hardware.
go here
And download for windows. You see most companies like you to download the software from their website for older operating systems for your computer to recognize it.
Thanks, Cody
Sep 11, 2012 | Seagate Freeagent Go 1 TB Hard Drive
My Seagate external hard drive is not showing up in the computer screen. It only shows up as unknown/unallocated on the windows computer management screen. i cant seem to access the hard drive what so...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jan 19, 2011 | Seagate FreeAgent Pro Desktop - 320GB -...
I have a Assembled Computer with Processor Intel Dual Core (R) @ 270 GHz, 3 GB of RAM equipped with Microsoft Windows XP Professional Edition version 2005 service Pack 3 with Wi-Fi Netgear 108 Mbps Lan...
yah you must buy a Y-USB cable for your external hardisk. this is connection both ends are one is for hardisk and the other two cable is for USB slot of computer. why it two wires connection to usb because one wire is for Data and the other is for Power. If doesn't work..it might be a problem in your Operating system. i recommend to you to reinstall your Windows OS.. theres a 4 reasons why it happen appear the error... deffective USB cable..corrupted driver of USB device for seagate, virus infected of your systems..and maybe your hardive is deffective. Please rate if this is HELPFUL..thanks
Aug 22, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
I require a driver for a seagate barracuda 7200.7 160GB hard drive
Seagate and Maxtor-brand External Hard Drives
External drives contain a standard computer hard drive in an enclosure that makes it possible to connect it to in of your computers external data ports (USB, FireWire or eSATA). This makes it easy to add a drive for backup or data storage to any computer with a compatible external data port.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">external hard drives
do not require additional drivers to function in Windows Vista
Microsoft Vista is the successor to Windows XP operating system. ', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Windows Vista
, Windows XP
Microsoft Windows XP is the successor to Windows 2000. ', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Windows XP
, Windows 2000
Microsoft Windows 2000 is the successor to Windows Me.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Windows 2000
, or Mac OS X
Mac OS X is the operating system that is produced by and comes standard on Apple computers.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Mac OS X
. These external drives are supported by the standard device drivers that are already included in these operating systems out of the box. Installing Serial ATA drives requires the installation of drivers from the Serial ATA motherboard. Click here for more information on this subject.
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=201413&NewLang=en
Oct 25, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate barracuda + usb harddrive enclosure cant access hard dive
First, neither of the links work. The amazon shows a power adapter and the Seagate defaults to their home page. But I think I get the idea. You purchased a usb drive enclosure and a new hard drive and now it doesn't work.
The problem is that the hard drive has not been initiated, formatted or assigned a drive letter.
Plug in the drive
Click on the Start button
Right click on Computer
Select Manage
A screen opens, click on Disk Management
All the drives known and unknown will appear on the right.
Find the drive that says unknown, right click over the text and select Initialize Disk.
When done, right click the blank space to the right labelled Unallocated and select new simple volume then follow the steps to format and assign a drive letter.
If you are only going to be using this drive on this computer then format ntfs, if it maybe be connected to other devices including Mac, you may want to use fat32 or exfat.
Whats the Difference Between FAT32 exFAT and NTFS
Mar 01, 2017 | Seagate USB 2.0 External Enclosure + 300GB...
Seagate 250GB USB external harddrive was working now it is not. Cannot see it in Disk Management. In Device Manager, USB controllers the harddrive shows up as Unknown Device when I plug it in. In...
unplug seagae usb external h/d
Device manager>Under usb= ,uninstall the device.
run: RESTORE, choose the last check point, reboot,then plug in the h/d in your usb.
May 06, 2008 | Computers & Internet
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
228 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
