Question about Lexmark E352dn Laser Printer
Lexmark e352dn-load manual plain letter message
  • 241 Answers
In most cases if the printer is asking for an unexpected manual feed it is because the paper tray is not set to the right paper size or type. To set the paper size to the most common size and type (letter size plain paper) use the following instructions.
1. Press the Menu button.
2. Press the right arrow key until Paper Menu then press Check Mark.
3. Press the right arrow key until Size/Type then press Check Mark.
4. Press the right arrow key until Tray 1 then press Check Mark.
5. Press the right or left arrow key until Letter then press Check Mark.
6. Press the right or left arrow key until Plain then press Check Mark.
7. Press the back button until Ready is displayed.
This will set up your printer tray for plain letter paper and should relieve the manual feed error unless yourcomputer is sending other paper size/type settings.
Posted on Aug 20, 2010
Told that this is a PCL5 type printer and can be used as a plug n'play, and no need to install a driver. It does work, but will not hold the programming. I only want to use Tray1.
the thing is that with plug and play equipment, when you plug it into the pc and turn it on Usb connections) , there is a small message just above the task bar which says installing driver for printer
it is the way that the pc recognizes the printer in a port
it may be best it you go to the control panel ,printers and devices , add a printer and install it properly
Oct 13, 2016 | Lexmark Office Equipment & Supplies
How do I install a Lexmark E352DN Photoconductor
Here's an article on How to Change the Photoconductor Unit/Kit on a Lexmark E250d(n), E350d, E352dn, or E450dn Printer. Just click on this link: http://bit.ly/aykTXL. This should give you an idea on how to install the photoconductor unit in the Lexmark E352dn printer.
NOTE: If you are replacing your old photoconductor unit with a new one, after installing it you will need to reset the photoconductor counter as well.
Aug 12, 2010 | Lexmark E 352dn Mono Laser Printer
Lexmark E352dn. After I've cleaned my printer I''ve got a message 'Load Tray 1 Plain A4'. Is there a sensor somewhere? Please explain to me where it is. Thanks
There's an input sensor but most likely that's not the problem. Usually, a specific error pops up if the printer does not detect the paper within a few seconds. In your case, most probably, it's just a no-pick issue. You can try reversing the tires of the pick rollers, turning it inside out or clean the rubber tiles with alcohol.
Jun 15, 2010 | Lexmark E 352dn Mono Laser Printer
Get the error message change tray to plain letter
Most probably the paper tray guide is not set properly. Here's a link to the Lexmark website to guide you on what to do when having an error like this. Just click on this link: http://bit.ly/c4AO17 . You can move the paper tray guide back and forth and setting it to the correct size.
Apr 08, 2010 | Lexmark Optra T610 Laser Printer
Our Lexmark E352dn printer displays a 'REMOVE PAPER/STANDARD BIN' error message. How can we fix this? I read another solution that talked about a small flap on the left-hand side of the output tray, but I...
Here's an article in the Lexmark website to guide you on what to do when having that error message on the printer. Just click on this link: http://bit.ly/a4odfK . It has some images to better understand the instructions.
Apr 05, 2010 | Lexmark E352dn Laser Printer
What is the product code for the Lexmark E352dn?
3S0500 is the Product Code for the Lexmark E352dn.
Apr 05, 2010 | Lexmark E350d Laser Printer
Service Manual Lexmark E352dn
Lexmark does not make the Service Manuals for its products available to the general public. Sales of this manual are restricted to authorised service technicians.
What problem are you trying to resolve, maybe I can help you?
Don
Sep 24, 2009 | Lexmark E352dn Laser Printer
Lexmark E352dn - 200 Paper Jam
you see your printer feed sensor or delivery sensor is open chack it
Jun 26, 2009 | Lexmark E352dn Laser Printer
Error 31 with new toner
please clean printer fuser or clean thermostator
May 15, 2009 | Lexmark E352dn Laser Printer
Lexmark E352dn Laser Printer Logo
1,094 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
