Question about Raypak Versa 130,000 Btu Above Ground Natural Gas Heater
Rapak above ground pool heater is leaking from the bottom
    Champion:
  • 305 Answers
Leak is prolly from pressure switch connection or heat exchanger...... if from heat exchanger buy a new heater
Posted on Mar 13, 2014
3 Suggested Answers
john224
  • 1378 Answers
SOURCE: hayward h100id1 above ground pool heater has
Contact Hayward for a local warranty repair center since it is still under manufacturers warranty. http://www.haywardnet.com/locator/ Be sure to change the reason for search to repair/service.
Posted on Jun 12, 2009
johnsonr1
  • 91 Answers
SOURCE: I have a versa gas heater for my above ground
I have often found spiders or other **** nesting in the pilot tubes of these boilers which blocks the flow of gas. You will either need to have it professionally serviced or you can attempt to do it yourself, which I do not recommend.
Posted on Aug 22, 2009
Error message Fault. High Limit , upon attempting to use the heater for the first time this season
either not enough water flowing through heater or low gas pressure to overheat unit replace high limit in stack if not one replace one on bottom white unit with 2 white wires
May 26, 2016 | Jandy LRZ250EN Legacy LRZE Pool & Spa...
What holds the burners in the burner tray in my rapak pool heater?
there are mounting screws at bottom of burner tray
Aug 14, 2014 | Raypak Pool & Spa
Noise
is this heater is been install for above the ground pool it will be better either way to use a hard schedulle 40 pvc to prevent any checking in the hoses for future leak ,is the heater connections are correct in and out , mean from the return the filter go to inlet side the heater them the outlet side of the heter (HOT WATER) GO TO RETURNS of the pool ? also check if the pump got full prime not air,is the filter is clean? also check for any brocken parts inside the flowvalve control, after years low PH AND TA will destroy internal parts in heater include leaking heater exchangers.
Jun 09, 2013 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Hayward h100id leaking
if water 70 or below it is condensing and the water is dripping on the flame bar and sizzling if over 70 degrees check for leak in heat exchange if that is leaking you need a new one and check chemistry
Sep 09, 2012 | Hayward 100,000 BTU Pool Heater H100ID1 -...
I have a hayward H100ID above ground pool heater. Recently the heater is making a rattling sound and the in and out hoses are bucking or pulsating. The water is still being heated but somehting does not...
low water flow is making the heater knock, (PULSATE) clean filter or backwash, check pump and skimmer baskets and empty. if still low flow and knocking, check impeller on pool pump to make sure it isnt clogged.
Aug 30, 2011 | Hayward Pool & Spa
HOW TO WINTERIZE AQUAMATE ABOVE GROUND SWIMMING POOL PUMP
Open the plugs on the bottom front of the pump pot and on the pump housing itself. These two plugs will do the pump and just the pump. You should have simmilar plugs on the filter, heater, chlorinator and any other equiptment on the system.
Oct 13, 2010 | Hayward Sp1580x15 Power Flo Lx 1.5hp...
Raypak versa 130 above ground natural gas heater 40 days old leaking from the bottom
bad pool chemistry heat exchange leaking replace warranty will not cover
Aug 19, 2010 | Raypak Pool & Spa
Heater is shaking and making a loud noise when
not enough water flow if filters and pump ok check manual bypass for bad spring if ok see if plumbing bypass it should only be half way open
May 29, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
How to setup a diverter valve for above ground
If you want all your water going thru the solar heater before re-entering the pool, you'll need to plumb the end of your filter to the solar heater, then the water exiting from the solar heater would go where the filter hose did go back into the pool. Hope this helps.
May 25, 2010 | Fafco Deluxe Solar Panel Heating System 1...
I have a Raypak pool heater the pilot will lite but the unit will
My Rapak gas pool heater burner will not ignite. I changed the flame sensor and then the main gas valve (on a recommendation of a heating contracter) and after spending almost $300 on parts, I may have not needed, it still will not ignite. The water temp has been around 80 using the solar cover but now with the air temp in the 50's at night and only in the 70's in the day the water is a brisk 70 degrees. We would like run the heater now, so we can use the pool for a bit longer this fall.
Any ideas? Some people told me there is a valve that senses the proper amount of water is flowing around the boiler so it doesn't burn up, is this possiblely the problem that the valve is not opening?
Joe Snyder, Toledo, Ohio
Jun 22, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak Versa 130,000 Btu Above Ground Natural Gas Heater Logo
141 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
