Question about Acer Aspire 5920-6727 Notebook
On turning on ACER Aspire 5920G laptop the laptop goes through the process of booting up, ie all relevant LEDs on power come on. The screen does not load up with usual ACER whitescreen and comes up with a screen with coloured vertical strips with a big black vertical line in middle. The fan etc seem to work and i can measure voltages on electrolytics on mother board so i think PSU is ok. I am assuming the LCD monitor has failed. Can someone confirm this is the case
  • 560 Answers
Hi. Yes, it could be a failing LCD screen but I would suggest to check the ribbon that connects the LCD screen to mainboard and make sure that it is not damage and properly connected.
Posted on Aug 20, 2010
Testimonial: "Thanks i will have a look. Just downloaded the service guide for it now"
HOW DO I FIX ACER ASPIRE V5-571
Insert your system disc, boot from it and run rescue.
Aug 18, 2015 | Acer Computers & Internet
Acer aspire 5920G- wont switch on. I can't hear
Hi Lenny,
not god news Im afraid, it sounds as though either your screen or your graphics chip are faulty. Help is at hand though, you could try connecting to an external monitor, but as your laptop is switching off, it is unlikely that this will work any better. You can remove the hard drive any install it into another machine, this should be straight forward, although if the machine in question does not have the corect connections then you will need a caddy. these are pretty cheap and plug into usb allowing access to the data on the drive. Hope this helps.
Feb 18, 2013 | Computers & Internet
How do i reset my acer aspire one to factory defaults?
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps
Feb 06, 2011 | Acer Aspire One Netbook 8.9" Notebook
White lines on screen and flickering
I think this is the problem of LCD.if it is then u should go to nearest service center .
Sep 25, 2009 | Acer Aspire 5920-6727 Notebook
Acer 5920g screen problems
it is probably a loose or crimped LCD cable, either on the main board or on the back of the LCD panel itself.
Acer Aspire 5920G BLANK SCREEN
First of all you have to determine if the problem is the GPU (graphics processing unit) or a possible bad connection on the inverter.
To check this you will need to plug an external monitor to the laptop and use the keyboard toggle to switch screens, usually its hold down Fn and press F6 or the F key with a monitor icon on it.
If the external monitor comes on then the problem maybe the inverter.
To check this remove the screen bezel (plastic screen surround). At the bottom of the screen you will see an elongated piece of circuit board with wires coming from either end covered by frosted plastic.
That is the inverter, check the connections on the inverter (both sides) and power the laptop up to check the display, to remove it gently pull the plugs from each end and remove the screw from the middle and pull the board away.
Look on the back of the inverter itself for a copper coil, if you re-solder the solder points around the coil you may find it works again as components that suffer from extreme heat the solder joints dry causing bad connections, re-floating the solder solves the problem in 90% of cases.
Good luck.
Sep 14, 2009 | Acer Computers & Internet
Acer aspire 5920G will not turn on
It seem issue with the memory card, try reinstalling the memory card and then try booting.
Feb 27, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920G startup issues
If unit is not booting you cannot use the system restore tool. And if you have not created back up disks .................
At least you did not have the machine long enough to really load it up so reloading it will not be so bad. However, ......
Maybe you picked up some computer clap? Using another machine download the malware bytes program onto a usb stick and then boot up your vista machine via the F 8 prompt (desktop + networking) during bootup.
Then when on simple desktop, insert usb stick and navigate to the file downloaded and run the app from there. Good luck!!!
Mar 23, 2017 | Acer Aspire 5920-6727 Notebook
Hi, I have an Acer Aspire 5920G. My problem is when the laptop is switched on it sounds like it's booting but the screen stays blank? Have you any idea what can cause this? Regards, Dan Pook...
Hello
I think your graphics card or screen is broken on your Acer Aspire 5920G, one thing you can test is to connect at external monitor to your laptop. If you dont get any picture then its your graphic card broken, if you get picture it is your screen. also try to adjust the screen light.
Sep 15, 2008 | Computers & Internet
Acer Aspire 5920-6727 Notebook Logo
401 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
