Keyboard trouble in Toshiba Portege M100
The laptop senses that the CTRL key is being depressed all the time. This can be resolved by using the on screen keyboard and typing a few keys. But the problem resumes after each shut down
  • 5 more comments
  • Tryna Aug 14, 2008
    My toshiba also does this; the keyboard just locks up and I can't type
    anything. It shows that the ctrl keys are being held down, while I'm not touching them at all and it can't be food/such. At times when I go to task manager it shows 'Kenotify' and when I end it sometimes the keyboard unlocks. I was wonder kk did you find a solution for this?
  • cmiziumski Aug 26, 2008
    Same intermittant CTRL key problem w/ M100. "Sticks" open or - deactivating the keyboard - closed. When stuck open, a usb keyboard works, suggesting that the problem is in the keyboard or its connections.
  • Anonymous Nov 16, 2008
    yeah my keyboard malfuncion when idle for a minute. i must standby or restart my laptop first so the keyboar can be used again. i don't know what the problem is. as long as i always push my keyboard, the keyboard will be fine. what should i do??
  • Anonymous Dec 22, 2008
    My toshiba portege r 100 also have the same problem, but diffrent key. I think it's hardware probleme. but, very expensive to replace with the new one.
  • Anonymous Jan 14, 2009
    i can't type anything on my portege m100, it says that ctrl key being push down. Its weird, since i dont push anything.
  • sostboat Apr 16, 2009
    i have the same problem with keys randomly getting stuck. i have tried removing the keyboard but it still beeps as though a key is being pressed. so i believe its a problem with the motherboard.
    i'm using a toshiba satellite m100.
    Any leads would be much appreciated
  • fersango Apr 24, 2009
    I have the same problem with the "V" key randomly getting stuck. i have tried removing the keyboard but it still beeps and the V key continue being pressed . i believe its a problem with the keyboard control on the motherboard. Anyone have a manual or a schema of the Satellite M100 laptop to help me find that controller on the motherboard, send me information to
    Best Regards, Fernando
I was cleaning my keyboard (toshiba portege m100) the other day, with a baby wipe (a bit too vigorously i guess). When i turned on the laptop later, the keyboard stopped working. None of the keys would work. Any suggestions on what the problem might be and how to fix it?
Posted on Jul 10, 2010
  • 144 Answers
I think its a keyboard problem.Best is to try to change and see or remove internal keyboard cable and use external USB keyboard to check.
Posted on May 03, 2008
I had the same problem and did two things
1. install toshiba common modules
the problem dissappeared for some weeks and came back
2. i removed the whole keyboard from the motherboard and re attatched it
problem fixed
i think the problem is with th cable from the keyboard to the motherboard.
the morons who designed it decided to bend it twice before it gets to the motherboard.
now my problem is that a lot of keys are virtually stuck in all the time so constant beeping from
system speakers.
crappy piece of hardware
Posted on Sep 21, 2008
Toshiba portege m100 hardwares not starting
Yes the CMOS battery needs to be changed. Then you can go into the BIOS and set the Date & Time.
The CMOS/BIOS will be set back to the defaults when you remove the CMOS battery and this may fix your problems.
Sep 05, 2012 | Toshiba Portege M100 Notebook
Keyboard not working
You should be able to use an external keyboard....just plug a usb keyboard in and boot up...this is probably your cheapest solution and will get you up and running again quickly :-)
Aug 27, 2012 | Toshiba Portege M100 Notebook
Toshiba Portege M780 - THe F10 light is on & the keyboard won't work. I have tried hitting Fn F10 to toggle but it does nothing.
Press the Fn-F10 combination to deactivate the overlay keyboard (numerical pad). The Fn key is the one to the right of the Left CTRL key.
Jun 27, 2011 | Toshiba Portege M780S7220 Tablet PC Intel...
I want sound driver for toshiba m100
if you upgraded to windows 7 driver files are in windows.old folder
Nov 09, 2010 | Toshiba Portege M100 Notebook
The keyboard of my laptop is not working properly.. i cannot type anything using the keyboard and when i press the backspace it will just type IIIIIIIII instead... how can i fix the problem... thanks
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one.
Oct 16, 2010 | Toshiba Portege M100 Notebook
Toshiba Potege R500 - neither control key works
I would pop the 2 keys oiff and make sure the rubber boot under the key is still there, did you buy this laptop used?
Oct 04, 2009 | Toshiba Portege S100-S1133 Notebook
Toshiba Portege 3500 keyboard not responding
Well, yes you do have another option.
Just press and hold the CTRL key and press the K key that should help you with your concern. If call the Toshiba hotline 1800-457-7777 to send your NB to the DEPOT.
Aug 21, 2009 | Toshiba Portege 3500 Tablet PC
Computers & Internet Logo
2,444 people viewed this question
David Payne
David Payne
