Question about Troy-Bilt Mtd Southwest Tb320bv "troy-bilt" Gas Blower Vac 31 Cc
Need to know fuel mixture - Troy-Bilt Mtd Southwest Tb320bv "troy-bilt" Gas Blower Vac 31 Cc
Posted on Nov 19, 2010
Lost the manual and need to know what the fuel and oil mixture ratio is
Hi Barney:
Fuel oil mix ratio for almost all newer 2 cycle motors is 50:1
Cheers
Apr 16, 2016 | Garden
What is fuel mixture on 25 cc craftsman weedwacker
This small engine needs a 40:1 ratio. Use only 2 cycle oil, not motor oil. If you are mixing one gallon of fuel use 3.2 ounces of the 2 cycle oil. This should give correct mixture so you do not get lots of smoke when you start. Take the time to measure. Note: there should be a marking somewhere on the engine about the mixture.
Sep 21, 2014 | Craftsman Convertible 25cc Curved Shaft...
What is fuel mixture on a 25cc craftsman weedwacker
I always mix it 40:1 so that the piston will always be lubricated and after I finish cutting I empty the gas tank and then restart machine so as to keep the fuel filter clean.
David
Sep 21, 2014 | Poulan Pro BVM200VS 25 cc Gas Powered...
How do I adjust the fuel mixture on the ford 460 efi
The mixture is not adjustable.
You have fuel injectors that are controlled by the computer.
If the check engine light is not on, I would look for a fuel pressure problem or a leaking injector.
Feb 06, 2013 | Cars & Trucks
How to ajust carb on a harley 1100 sportster need to know settings bike is jumps in 1 st & 2 nd gear after 2 nd runs good
Hi Deeprun5, on the right hand side of the carburator there is an idle adjusting screw with a spring behind it, turn screw clockwise to increase idle counter clockwise to decrease idle. There is also an air/fuel mixture screw inside a carb body lug that may or may not be plugged with an aluminum cap that's about 3/16" thick. This cap can be drilled out to acess the air/fuel mixture screw. Turning screw clockwise will lean out mixture and lower idle, turning screw counter clockwise will richen mixture and raise idle. You need to balance the two adjusting screws to obtain an idle of 950-1000 RPM then back out air/fuel mixture screw 1/4 turn, snap throttle to confirm responce, you may continue to back out air/fuel mixture screw untill desired throttle responce is achieved, if you see black smoke coming out of exhaust you have gone to far and need to turn screw back in 1/8 turn at a time, final adjustment should be made with the engine at normal operating temperature. Good luck.
Aug 20, 2011 | Harley Davidson XLH 1000 Sportster...
I have a 1987 gmc jimmy with a 5.7 litre fuel injection and it seems to be lack air or has to much i dnt know . and i want to know how to adjust my fuel air mixture
Unfortunately, most fuel injection engines don't have an adjustable fuel/air mixture by the technician.
The fuel/air mixture is controlled by a computer.
Jul 03, 2010 | 1987 GMC Jimmy
Fuel oil mixture
use a 32:1 mixture which is approx 4oz 2cycle oil to 1 gal of gas. you can also add an ounce or two of of a fuel sys cleaner to your fuel mixture for a good cleaning of the carb to remove any gum or varnish build up which could cause poor engine performance. hope this helps you
Aug 08, 2009 | Homelite Garden
Calculating power of a fuel/air mixture
You will need to know the BTU value of each type of fuel to compare the difference of each to one another. Nito methane is not a fuel as such, it does bring extra oxygen into the mix.
Aug 07, 2009 | Yamaha Electrical Supplies
I don't know where the air/fuel mixture screw is on my carb
There should be one screw (I'm assuming it's the Carter YF carburetor 1 barrel) that's by itself away from linkages etc, more to center at base of carb where it meets manifold, that is angled approx 45 degrees going in to base. That should be your mixture screw. What symptoms are you experiencing anyway?
Apr 03, 2009 | 1984 Ford F 150
Troy-Bilt Mtd Southwest Tb320bv "troy-bilt" Gas Blower Vac 31 Cc Logo
80 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
