Question about Sanyo EM-C1800 Microwave Oven
I am in Trinity n.c. I need apart for my me-c1800. It is the door latch. Where can I get it fast.
The door latch broke
Slightly different model, but this will help you fix it.
https://m.youtube.com/watch?v=JqeeGBhRwFw
Feb 06, 2016 | Samsung SMH2117S
Door will not stay close
Not much data to go on here. The latch on the door has a spring that holds it down in the locked position. when you pull the handle the latch goes up and you pull the door open. You will have to take the door apart and see if the spring broke or the plastic tab that holds the end of the spring is broken.
Feb 25, 2015 | Maytag Appliances Over-the-Range Microwave...
Why will door not stay latched ?
Check the door latches that stick out from the door. Push them up. Is there any resistance? If not, then the spring that pulls them downward either broke or came of its catches. You will need to call a repairman who will have to take the door apart and either replace or re-fasten that spring.
Jun 22, 2014 | Kenmore Microwave Ovens
Door will not latch
Why will my Kenmore model 401.85053010 mocrowave door will not latch?
Jun 11, 2014 | Kenmore Microwave Ovens
Sticking Door
The door latch release or latch itself is the fault---most shops can take apart and replace or repair this----a number of units the replacement part is better made.
Aug 28, 2012 | Microwave Ovens
Samsung microwave door won't latch
You will need a Samsung dealer repairman, the inner mechanism will need to be serviced because for some reason it is jammed or there are broken parts.
Apr 08, 2012 | Microwave Ovens
I need to replace the door latch and want to know is that a difficult thing to do? how long is the the door latch in terms of inches?
I have not worked on your particular model, typically, the latch is 1/2 to 2/3 the height of the door. Replacing the latch will be a challenge since you will likely have to take the door apart as well as getting involved with the innards of the main body. The spaces are small and there is little room for maneuvering. On the other hand, it is not an impossible job. I have dont it several times. Allow most of a Saturday afternoon for the job.
Thanks for considreing FixYa.com
Jan 29, 2011 | Panasonic NN-S540BF Microwave Oven
I'm trying to replace the lower latch on my ge microwave and don't know if I have to remove the door to disassemble it.
yes. in most cases you will need to take the internal ceramic wall apart form the door to show a small latch that needs to be unscrewed before you can continue.
Jun 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Sanyo EM-C1800 Microwave Oven Logo
19 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
tony denham
Level 1 Expert
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
