Question about Mitsubishi Televison & Video
I have a HDTV 1080 and the power to our neighborhood went out over the night and now the green light on the TV just blinks. I can't get the TV to turn on. I have reset the system reset button on the from adn nothing happened. I have reset the breaker and still a blinking green light. Is There a resent on the back I have built in this tv into a space and it is a big deal to roll it out? In the past the green light has timed out after a few minutes but not this time.
Try this ... if there is a reset button on your 'front' control panel..maybe 2 - 3 positions to the left of your blinking timer light..
try inserting the tip of a mechanical pencil or tip of a straighten paperclip into the 'tiny hole' of th ereset button ...hold pressure on that button until yout blinking light starts blinking RAPIDLY .. this
rapid blinking should continue for several seconds or a minute.
then it should stop .. may even go off ... now ..hopefully.. you will be able to turn your set on
Posted on Aug 22, 2010
"i have a mitsubishi HDTV
The green blinking light is telling you the error code. count the number of blinks and make note of any sequence. Then google your make and model with blink codes added to the end. This will lead you to sights that will tell you what the error or blink code means.
Aug 20, 2011 | Mitsubishi Televison & Video
I have a mitsubishi 1080 series tv. I turned the tv off and then I went to go turn it on, now the little green light on the tv stays on for 2 sec. and then goes away without the piture ever coming on.
A hint--if the green power light comes on for a few moments and goes off do the self check this set has.
On the front of the set press and hold BOTH THE MENU AND INPUT (OR DEVICE) BUTTONS BOTH FOR AT LEAST 5 SECONDS. Release both buttons and look at the power button.
If this is the case the power light will blink a two digit error code--most common in this case is 2 blinks, a pause and 2 blinks--it will repeat the code up to ten times.
Let me know if you find an error code or the power light just blinks and never stops.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
1080 mitwubishi tv,cannot get to come on green light just blinks
I would say without taking voltage readings, your Regulator IC in the power supply has had it. It's still worth repairing if that's the only problem. Contact your local Service co. for an evaluation and an estimate first.
Apr 19, 2009 | Mitsubishi WS-65513 65" Rear Projection...
I have a mitsubishi 1080 projection tv. I wont turn on, the green light just keeps blinking.
Check the manual...blinking green light is normal. The unit is powering down cooling the lamp. It could have been a shut down command through pressing the off button by accident. If problem continues I would unplug tv and power on/off. Steady green. Next to the lights is a small indentation where you can reset the TV to the defaults. Take a paper clip ...power on..and put in the center. The green light will blink for a minute or two then go dark. THen power up.
Dec 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Lg. screen tv mitsubishi HDTV 1080 SERIES INTEGRATED
i went to turn on the tv and the power button don't work
Jun 02, 2008 | Televison & Video
Help with green light blinking, HDTV integrated 1080
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
May 19, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
225 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
