Question about HP OfficeJet 6110 All-In-One InkJet Printer
My hp 6100 all-in-one takes paper from the tray at normal speed then shoots it half way throught missing the start and gives me a paper jam error
  • mikew690 Aug 20, 2010
    This advise did not work.
    I have also tried the foactory default reset in manetenance.
    Uninstalled and reinstalled drivers and software.
  • HP Master
  • 11,800 Answers
The paper feeding in your printer is done by 2 motors that work in parallel. Their synchronicity is assured by sensors and is controlled by the processor of the printer. In your case that sync is gone and the misfeeding is detected by the sensors on the printing head as a paper jam. If doing a hardware reset hasn't solved it then the processor is defective. Since you must replace the entire board if the processor is dead it will by cheaper and way simpler just to get a new printer, this one has died.
Posted on Aug 20, 2010
    President:
  • 4,070 Answers
Hi! Please try this. Unplug the printer from power source then press hold the power button for 10secs. while unplugged. This should reset the printer's system. Plug the printer, turn it on and see how it goes. This should be working properly. Hope this helps and thank you for using FixYa!
  • dj_relly999
    dj_relly999 Aug 21, 2010
    Looks pretty much a calibration problem.
Printer says paper jam, But there is no paper jam.
I will ask where does the sheet of paper lie inside the printer when it jams or is there no sheet of paper to be seen. Next question does the printer actualy pick up a sheet of paper. if not may be worn\ missing grey rollers, which can be seen by removing paper tray and looking in and up. There are 3 main sensors usually one at the paper pickup from tray, next one half way through( under a plate which is under the toner cartridge) and the last one is on the fuser at the rear, although the last one normally gives the alarm message " jam in fuser area" check these sensors out for sticking or not free.
Dec 22, 2014 | Lexmark Office Equipment & Supplies
Tip
Paper Jams
The most common error message is the notorious paper jam message. You do a quick look and then determine there is no jam. What next? Well here is a tip that will save you possible a service call. If you find a sheet of paper that has jammed, look at it closely. It is all together as one piece or is there the tinest of pieces missing? It only takes a tiny piece to cause a jam error. Pull the print cartridge out and with a flashlight look inside the printer and especially at each roller and see if there is any hint of a piece of paper. Look closely because you can miss something. Next open the paper tray and make sure the paper guide is firm against the paper. This will cause a jam. Just drove an hour and a half this week for this issue. The paper guide was not up against the paper causing the jam. If you have a small vacuum I suggest you vacuum out the printer because there are times that the sensors can get covered with paper dust causing them to fail. Hope this helps!
on Oct 26, 2011 | HP Office Equipment & Supplies
Hp2300 jams half way out of tray 1 and tray 2
1. Up to where paper traveled.. If its reached up to Fuser assembly & curl folds accrued under cartridge.. replace Teflon sleeve or Fuser assembly.
2. If paper traveled up to Fuser out(near 2-3 inch)...Clean/replace/flag Fuser out paper sensor
3. If paper traveled up to registration assembly:Clean registration sensors/flags.
4. Check pickup rollers.
Feb 20, 2013 | HP LaserJet 2300 Printer
HP P3015N tray two paper pickup issue
Issue is worn out feed rollers. There are three. One in the tray itself and two after you remove the tray. Look up into the printer from where you removed the tray and replace those two rollers
Jan 09, 2013 | HP LaserJet Enterprise P3015d BW laser...
13.01.00 Jam in Tray 2 error when no jam exists
Check Tay2 paper sensor flag, located at tray2 pick up roller, its its stucked shoot the fault
Mar 24, 2011 | HP LaserJet P3005 Printer
Printer tried to take half of the stack of paper and jammed up. Can't get the paper unstuck.
Unlatch and pull out the paper tray. Try pulling out the sheets in the middle of the "half stack" first. You should have less friction there. While you have the paper tray out, examine the rectangular cork paper separator strip on the right-hand side of the back corner. If it's worn or missing, that would explain how the jam got started.
Dec 06, 2010 | HP DeskJet 820Cse Printer
HP Photosmart C6280 Will not feed paper correctly
Please onsult this HP support article and follow the steps outlined there to clean the rollers, etc. Frequently this roller cleaning and possibly a reset is all that's required to clear the jam error. (If you have access to compressed air, you can gently blow air throught the printer to clear out paper dust and debris from inside.
Also be sure to follow the instructions in the manual or here to load the paper correctly, fan sheets before loading, and if the problem continues, try flipping the stack of loaded paper upside down and reloading, or try another kind of paper..
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 03, 2009 | HP Photosmart C6280 Printer
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
27 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
